Благодаря за бързия отговор! За футбол кои матрици са по-добри IPS или VA? И коя от двете има по-добра рязкост и контраст? Знам че отговора на тези въпроси е субективен, но бих искал да чуя точно твоето мнение. Предварително благодаря.
Internet / браузър
PVR (запис на HDD)
VOD - възможност за наемане на филми
Music Service
3D
Възможност за изтегляне на приложения
Възпроизвеждане на IPTV (Stream TV)
Touchscreen
Други
Не знам / не мога да отговоря
Повтаряли сме го десетки пъти...
VA - по-добър контраст, по-малък зрителен ъгъл, малко по-бърза като реакция(с 1 мс)
IPS - по-голям зрителен ъгъл, по-малък контраст, малко по-бавна като реакция
http://www.tftcentral.co.uk/articles...chnologies.htm
LCD Type matrix
specificationName
········· Nickname······················· Summary······································· Positives······································· Negatives······································· Typical Spec·······································
FeaturesTN Twisted Nematic Produced by most manufacturers
Dominate smaller screen market almost exclusively (15 - 19")
Also available in larger sizes up to 27" max
Low cost to produce, low retail costs for screensResponsive especially since introduction of overdrive - key choice for gamer screens
Can natively support 120Hz+ refresh rates
120Hz+ screens often feature LightBoost backlight systems for improved motion blurMost restrictive viewing angles, especially in vertical plane
Not great for colour critical work due to viewing angles primarily
Movie noise problematic, especially where overdrive used1 - 2ms G2G response time
1000:1 contrast ratio (realistic)
170/160 viewing angles (unrealistic in vertical field)
16.7m colour depth through 6-bit+FRC panels
Fairly light AG coating used
120Hz+ refresh rate support from someVA Vertical Aligment Early MVA panels designed to improve on TN Film. Offered improved viewing angles but very slow response times
Later P-MVA and S-MVA panels offered improved response times. Also improved contrast ratios to 1000 - 1200:1 typically
Modern AMVA panels from AU Optronics. Improved response times further and contrast ratios now 3000 - 5000:1Contrast ratios very high with >3000:1 common in practice
Response times adequate for most users and vastly improved over older generations of MVA
8-bit colour depth
Some now support 120Hz refresh rateResponse time still normally slow compared with TN Film and IPS offerings.
Off-centre contrast shift inherent to all MVA panel generations. Not ideal for colour critical work
Viewing angles not as wide as IPS/PLS. Some improvements in very recent generations
No current 10-bit panels5 - 6ms G2G response time (in practice mostly much slower)
5000:1 contrast ratio (figures over 3000:1 common and realistic)
178/178 viewing angles (somewhat unrealistic considering contrast shifts and off-centre contrast issue)
60Hz refresh rate generally
Some 120Hz support emerging
16.7m colour depth through 8-bit panels
Light / semi-glossy AG coating usedPVA Patterned Vertical Alignment Early PVA panels designed as alternative to MVA, very similar performance overall
Later S-PVA and cPVA panels offered improved response times. Also improved contrast ratios to 2000- 4200:1 typically
PVA now rarely used or produced in desktop monitor market. Samsung seemingly concentrating on PLS instead.Contrast ratios pretty high with >1200:1 common in practice
Response times adequate for some users where overdrive is used (S-PVA, cPVA generations mostly)Response time still slow compared with TN Film and IPS offerings.
No support for native 120Hz+ refresh rates
Off-centre contrast shift inherent to all PVA panel generations. Not ideal for colour critical work
No 10-bit panels available8ms G2G response time (in practice mostly much slower)
16.7m colour depth through 8-bit panels mostly, some 6-bit+FRC used
Light / semi-glossy AG coating usedIPS In Plane Switching Early IPS panels designed for colour enthusiasts
S-IPS improved response times somewhat. Contrast ratio still an issue
H-IPS changed pixel structure, improved response times with overdrive, contrast ratio improved
e-IPS and other variants of H-IPS helped drive down production costs and make IPS more mainstream
p-IPS developed to offer 10-bit colour depth support
AH-IPS is current generation being produced
Alternative IPS-like technologies introduced by Samsung (PLS) and AU Optronics (AHVA) to compete.
Contrast 850:1<Viewing angles are widest of the technologies. Reduced contrast and colour shift. Freedom from off-centre contrast shift seen from VA matrices
Response times of modern generations now very good, better than VA
10-bit panels availableNo support for native 120Hz+ refresh rates
Older variants criticised for grainy AG coating
Distracting white glow from an angle when viewing dark content (IPS glow)5ms G2G response time (in practice a little slower)
1000:1 contrast ratio (typically achieving 800 - 1000:1 now)
178/178 viewing angles (mostly realistic)
16.7m colour depth common through 8-bit panels mostly, some 6-bit+FRC used
1.07b colour support available from 8-bit+FRC and 10-bit panels
Many older panels have grainy AG coating
Lighter AG coating used on most modern AH-IPS panelsLCD matrix
Този пост е редактиран от hristoslav2; 20-12-14 в 23:11.
Значи VA е "моята" матрица щом реагира по-бързо се надявам на бързи кадри по-малко да замазва. След това заключение по метода на изключването дилемата се стеснява до Самсунг 6410 или Панасоник 640.
Този белият 6410..половинката ти ли го избра? питам защото жените си падат по беличко, розовичко....
Doshisha - Vivid color 23-inch LCD TV models | AkihabaraNews
Хаха да, на нея цвета и хареса повече а на мен стойката. Не че това е от голямо значение , но при еднакви праметри... и това играе роля.
Между другото мисля че има още една разлика - 6410 има тунер за сателитна телевизия.
Чудно ми е, кой българин е допълнил последният линк от тази статия в уикипедия..
Sharp Aquos - Wikipedia, the free encyclopedia
Smart TV 2015
Brand
OS Platform..............................
OS Developer..............................
Smart TV Platform...............................
LG
WebOS LG Silicon Valley Lab LG Apps TV Developer LGE Panasonic Firefox OS Stingray project Viera Connect Apps Panasonic IPTV Apps DEVELOPERS Samsung Tizen OS Linuxfoundation
TizenasotiationSamsung Apps Samsungdforum Sharp OS based upon Linux Kernel -- Netrange -- Sony Android TV OS Android developers Yahoo Connected TV Platform Yahoo Developer network Philips Android TV OS Android developers AppsOnTV -- Toshiba OS based upon Linux -- Symbaloplaces --
Забележки:
Android OS няма да се прилага във всички серии на Philips и Sony TV(Sony ще намалят сериите в модели 2015).
Новата WebOS 2.0 изглежда ще се приложи само в горните серии на LG TV 2015.
Същото ще важи и за новата OS на Panasonic.
LG webOS | webOS TV, Tablet, Phone Forum
SDK Download(Software development kit) - Samsung Smart TV Apps Developer Forum
::: LG Developer | webOS TV :::
Import your bookmarks to Symbaloo
https://internet.sony.tv/customer/
https://wiki.mozilla.org/FirefoxOS/S...idget_Approach
http://forum.xda-developers.com/andr...id-tv-t2935545
Как да инсталираме приложение на нашият Philips Android TV
1. Устанавяваме на тв от плеймаркета Developer Tools
2. Влизаме в Developers settings и поставяме чавка на "Отладка по USB". В никакъв случай не поставяйте чавка на "Show more apps in Google Play"!!! Това ще доведе до закритие на достъпа от вашият акаунт. Лекува се с връщане на завдскоте настройки на тв и презареждане.
3. Сваляме и установяваме на компютъра JDK http://www.oracle.com/technetwork/java/javase/downlo…oads-2133151.html
4. Сваляме и устанавяваме на компютъра Android studio. Свалих си го от тук http://developer.android.com/sdk/index.html.
5. Намираме папка platform-tools, при мен беше тук C:\Users\Andrii\AppData\Local\Android\sdk и за удобство я копираме в ядрото на диск C (не е задължително, но в режим команден ред така е по-удобно)
6. Трябва в в уиндоус да отредактирате системните переменные. Тук http://www.4tablet-pc.net/reviews-a-articles/143-pro…-system-user.html в п.3 описано как да се направи
7. Запускаем в винде режим командной строки и преминаваме в папка platform-tools
8. Пишем команда adb connect айпи адреса на телевизора. Може да го видите в настройките на тв Мрежа->преглед на параметрите на мрежата. Ако всичко е направено правилно, то трябва да се появи надпис connected to айпи телевизора:5555
9. После нужният apk файл копираме в папка platform-tools и го установяваме на тв, с команда adb install название файла.apk
Този пост е редактиран от hristoslav2; 21-12-14 в 19:09.
Привет на всички отново!
Подавам обратна информация - от вчера в хола се нанесе един нов Самсунг 40Н7000! На първо четене всичко е ок, само сега предстои заиграване с настройките му. Свързването към интернета на виваком стана без проблем. Само дето нещо не ми е активен браузъра... Искам да благодаря на всички взели отношение по моите въпроси! Също много полезно е нещото, прочетено тук, но не помня на кого беше поста-с други думи да се опитаме да спечелим служител от магазина на наша страна. От опит да ви кажа има полза! Жената, с която говорих няколко пъти в ТП излезе голям 'пич' и 'угаждаше' на всичките ми 'прищевки'. Успех на всички избиращи нов тв!
от колко метра ще ги гледаш тези 40". Иначе поздрави, един от най-добрите тв тази година.
Вчера в Технополис харесах това LG 40UB800V и ще помоля за отзиви за него. Има ли смисъл от Ultra HD на тези 40"? Телевизорът ще се използва най-вече за гледане на ТВ (Булсат), филми от флашка или PC, от време на време футбол - от около 2,5 м. 3Д не ми е приоритет, смарт функциите също, но то май няма как да се избяга от тях...
Извинявам се, сега видях, че питането ми е за друга тема, ще го пусна там
