Страница 102 от 110 ПърваПърва ... 5292100101102103104 ... ПоследноПоследно
Резултати от 1,516 до 1,530 от общо 1644
Like Tree328Одобрявам
SONY телевизори 2016
  1. Senior Member Аватара на KI_YOOU
    Nov 2014
    Русе
    #1516
    Отговор: SONY телевизори 2016
    Потвърждавам, на малкия от подписа ми SD каналите са шит. Имай едно на ум.
    #1517
    LG 40UF7707 ?
    Кои програми и от какво разстояние?
    Sony KDL-32WD750 – test – TV TEST
    Sony UHD TV 2016 - european models
    Series
    Model
    _________________
    UHD
    Premium
    _____
    Dolby Vision
    ____
    Hybrid Log Gamma
    (HLG)
    _____
    HDR 10
    3 fundamental HDR
    building blocks:
    ST2084 (EOTF PQ),
    ST2086 (static metadata)
    ST2094 (dynamic metadata)
    _________________
    The measured values of the brightness in Windows
    2/5/10/15/20/100%
    Videopanel
    _______________________
    Type LCD matrix,
    Bits of color,
    (Operating frequency of T-Con board of the panel)
    Curvature,
    Index,
    Screen Uniformity
    Anti-reflective filter
    Supported Resolutions
    __________________________
    Frame per seconds
    24, 25, 30, 50, 60, 100, 120 p/i
    Chroma subsampling
    4:4:4
    4:2:2
    4:2:0
    Backlight Unit
    Type backlight
    Local Dimming zone
    Type LED
    MEMC
    Backlight Scanning
    Black Frame Insertion
    Pulsе Wide Modulation
    Measurements
    _______________________________
    DCI P3
    Rec.2020
    Delta E
    Gamma
    Color Temperature
    Measurements
    ANSI Contrast
    With local dimming
    Without local dimming
    White level
    Black level
    Viewing angle
    __________
    Horizontal & Vertical
    (°cone)
    Motion resolution
    Product
    _____________
    Input Lag
    Audio
    ___________________________________
    Built in Media Player
    Supported file systems
    Image file formats
    Audio file formats/codecs
    Video file formats
    Subtitles
    Hardware & Software
    Operating System
    Board
    Central Processing Unit
    System on Chip
    Instruction set
    Graphic Processor Unit
    RAM
    Total memory
    Networks
    __________________
    Conectors
    Tuners
    ______________
    Opportunities for
    calibration
    Note
    ______________________________________________________________________________
    Pros & Cons
    Product
    ZD9
    (Flat - active 3D)
    KD-100ZD9 BAEP
    KD-75ZD9 BAEP
    KD-65ZD9 BAEP
    No No No ? 100"- max 1900cd/m2
    75"- max 1900cd/m2
    65"- max 1800cd/m2
    100% - 788cd/m2
    50% - 1019cd/m2
    40% - 1146cd/m2
    30% - 1396cd/m2
    20% - 1721cd/m2
    15% - 1605cd/m2
    10% - 1800cd/m2
    5% - 1605cd/m2
    1% - 1198cd/m2
    Yes
    SMPTE standarts
    ST2084, ST 2086
    100" - ? , 10-bit, 120/100Hz
    75" - AMVA, 10-bit, 120/100Hz
    65" - AMVA, 10-bit, 120/100Hz
    Flat
    Motionflow XR 1200
    Glossy...
    Protective layer of sapphire
    Coated with low reflection for deep black and fluorite glass
    4096 x 2160 / 60P(displayed as 3840x2160)
    4096 x 2160 / 24P(displayed as 3840x2160)
    3840 x 2160 / 24P
    3840 x 2160 / 25P
    3840 x 2160 / 30P
    3840 x 2160 / 50P
    3840 x 2160 / 60P / 4:4:4
    1920 x 1080 / 120Hz - ??
    1920 x 1080 / 24P (Only HDMI)
    1920 x 1080 / 30P (Only HDMI)
    1920 x 1080 / 60P (HDMI / Component)
    1920 x 1080 / 50P (HDMI / Component)
    1920 x 1080 / 60I
    1920 x 1080 / 50I
    1366 x 720 / 24P (Only HDMI)
    Up to 18Gbps
    4K 60p, 4:4:4, 8bit
    4K 60p, 4:2:2, 8,10,12bit
    4K 60p, 4:2:0, 8,10bit
    HDR included in HDMI 2/3
    100" - FALD, 1508 (52 x 29) ?
    75" - FALD, 858 (39 x 22) ?
    65" - FALD, 646 (34 x 19)
    Motion Clarity Frame Interpolation
    PWM - ?
    100"- 96% /
    75"- 96% / 66% /
    65"- 96% / 66% /
    Triluminos Display
    phosphorus-based diodes for a wide gamut close to the DCI 4K
    (Blue Led + Red/Green phosphorus)
    Super Bit Mapping with 14-bit signal processing
    (RGB - Led's ??)
    100" -
    75" -
    65" - 3231:1 / 120cd/m2 / 0.003794cd/m2
    100" - °
    75" - °
    65" - °
    100" -
    75" -
    65" - 1080 Horizontal lines with MF
    400 without [Motion Flow]
    ZD9
    100", 75", 65"
    September 2016
    100" - Game mode
    75" - Game mode
    65" - Game mode 42ms / by default 64ms
    65ZD9,75ZD9 - 2ch, Full Range (30 x 80 mm) x 2 /
    100Z9D - 2ch, Two way speaker [Tweeter (30mm) + Woofer (40 x 100mm)] x2
    Speaker Position - Down Firing
    Speaker Type -
    65ZD9,75ZD9 - Bass Reflex / 100Z9D - Long Duct
    Dolby Plus,
    Dolby Pulse
    DTS
    Clear Phase Speaker
    Compatibility
    Wireless Subwoofer(SWF-BR100);3D Glasses(TDG-BT500A)
    65" only - Wallmount Bracket(SU-WL450 without tilt function)
    Audio post-processing is powered by a dedicated ARM11 processor with L2 cache and two ADSPs. Its dedicated processor ensures always-ready performance for the latest Dolby MultiStream Decoders MS12 DAPv2 and DTS Studio Sound II (TheaterSound 3D ver 4) that encompasses the breadth of Dolby and DTS consumer audio formats.
    FAT16, FAT32, NTFS and exFAT
    JPEG, GIF, PNG, MPO
    FLAC , M4A, MIDI, MP3, WMA, WAV, LPCM
    AVI, DivX, H.263
    H.264 / MPEG4 Part 10 / AVC Video
    H.265 / MPEG-H Part 2 / HEVC
    MKV, Quick Time, M2TS, MP4, WebM, WMV, XviD
    .srt,
    There is no possibility for setting the position and size.
    OS: Android 6.0.1 Marshmelow (Sony Edition)
    Board: BRAVIA_ATV2
    SoC: MediaTek MT5891 (Cortex A53 - ARMv8)
    Core architecture: 4 x Cortex A53
    Instruction set: 64-bit ARM-A53
    Operating at up to 1.1GHz
    GPU: ARM Mali-T860 MP2
    OpenGL ES 3.1 Mali-T860
    RAM: 2GB
    Total memory: 1593 MB
    Available memory: 521 MB
    Internal storage total space: 8358 MB
    Internal storage free space: 8105 MB
    Lan (100BASE-TX/10BASE-T)
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    WiFi Direct
    DLNA
    Blietooth (NFC) Ver.4.1 HID/HOGP/3DSP/SPP
    (for keyboard and mouse, no Bluetooth audio)
    2 x USB 2.0 (DC 5V MAX 500mA)
    2 x USB 3.0 (DC 5V MAX 900mA)
    1 x Ethernet RJ45
    4 x HDMI - (ARC, CEC, MHL)
    1 x Satelite In (Main: F-type female)
    1 x Satelite In (Sub: F-type female)
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x Optical Audio Out (AAC/PCM/AC3)
    1 x 3.5mm Audio Out
    1 x Antena (RF) (female)
    1 x CI+ 1.3
    1 x RS.232
    (Only inputs 2 and 3 are HDMI 2.0a which means they can accept 4K/60p, HDR and HDCP 2.2. The other two HDMI inputs are listed to 4K/30p)
    SW update to HDMI 2.1
    Twin Tuners
    DVB-T/T2/C/S/S2
    DiSEqC version 1.0
    PIP, Timeshift % PVR
    MPEG2, MPEG4
    HEVC H.265, VP9
    HEVC/VP9 10-bit color with HDR, up to 4K UHD 60 fps. This is suitable for internet TS/IPTV streams, Netflix or YouTube. Meanwhile worldwide demodulation capabilities include ATSC / DVB / DTMB / ISDBT.
    White balance - 2/10 points
    Gamma - 10 points
    ISF - no
    3 gamuts (Rec.709, DCI, Rec.2020)
    but no CMS (Color Management System) to calibrate these gamuts
    ZD9
    XD9405
    (Flat)
    KD-75XD9405 BAEP
    successor model X9405C
    No Informaly No No ? 75"- max 740cd/m2
    100% - 360cd/m2
    Yes HDR10
    SMPTE standarts
    ST2084, ST 2086
    75" - AMVA3, 10-bit, 120/100Hz
    Flat
    Motionflow XR 1200
    Very good; mild darkening along edges on full-field rasters
    Semi-mate
    1920 x 1080p / 60Hz / 4:4:4: Yes
    1920 x 1080p / 120Hz: Yes
    3840 x 2160 / 30Hz / 4:4:4 : Yes
    3840 x 2160 / 60Hz : Yes
    3840 x 2160 / 60Hz / 4:4:4 : Yes
    4096 x 2160 / 24P (HDMI/2/3)
    3840 x 2160 / 24P
    3840 x 2160 / 25P
    3840 x 2160 / 30P
    3840 x 2160 / 50P
    3840 x 2160 / 60P
    1920 x 1080 / 50P (Only HDMI)
    1920 x 1080 / 60I
    1920 x 1080 / 50I
    Most common PC inputs are accepted. As with other Sony TVs, little artifacts (flashing lines) are seen when a 1080p / 120Hz signal is being displayed. 'Game' or 'Graphics' picture mode as to be selected at that refresh rate to get a sharp picture. To get chroma 4:4:4 (for sharper text) at 1080p / 60Hz, use the 'Graphics' picture mode. For 4k / 60Hz / 4:4:4, turn on 'Enhanced HDMI' for the input in use.
    75" - FALD - 96 zones (12x8)
    Backlight Scanning
    PWM Freq. 120/100Hz
    75"- 95.7% / 65% /
    Triluminos Display
    Super Bit Mapping which upsample colors in 14-bit internal processing
    75" - Black(4x4 ANSI) 0.052 cd/m2 with [Auto Local Dimming] on
    75" - 67°
    75" - 1080 Horizontal Lines
    with [MotionFlow] “Clear & Custom“
    XD9405
    75"
    наследник на X9405C
    75" - Game mode 34.9ms / by default 64ms
    75" - 2x7.5W + 2x7.5W
    2xTweeter (12x85mm)
    2xWoofer (65mm)
    2 CH Down firing
    Bass reflex
    Dolby Digital
    Dolby Plus
    Dolby Pulse
    DTS
    Compatibility
    Wireless subwoofer (SWF-BR100)
    JPEG, GIF, PNG, MPO
    AVI, DivX, H.263
    OS: Android 5.1.1 Lolipop
    Board: SVP4KDTV15
    SoC model: MediaTek MT5890
    Core architecture: 2 x ARM Cortex 17(ARMv7)
    Instruction set: 32-bit ARMv7
    GPU: ARM Mali T624 triple core
    Open GL ES 3.1
    RAM: 1,5GB
    Total memory: 1508MB
    Available memory: 390MB
    Internal storage total space: 8363MB
    Internal storage free space: 7542MB
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    Bluetooth (NFC) Ver.4.1 HID/HOGP/3DSP/SPP
    1 x USB 3.0 (DC 5V MAX 900mA)
    1 x Ethernet RJ45
    4 x HDMI 2.0a - HDCP2.2 (ARC, CEC, MHL)
    1 x Satelite In (Main: F-type female)-
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Twin tuners
    DVB-T/T2/C/S/S2
    DiSEqC version 1.0
    PIP, Timeshift & PVR
    MPEG2, MPEG4,
    HEVC H.265, VP9
    White balance- 2/10 points
    Gamma - 10 points
    ISF - no
    The out-of-the-box image accuracy was excellent before calibration and reference afterwards, with impressive black levels and a highly effective local dimming system. The video processing was also very good, as was the motion handling and the XD94 delivered the goods with both standard and high definition content. Sadly the Sony wasn't as impressive when it came to 3D, with excessive crosstalk ruining an otherwise good image. The HDR performance was largely very good with a great dynamic range and a decent level colour accuracy. However the peak brightness was limited to around 760nits, which would explain why the XD94 doesn't have Ultra HD Premium certification and the display was also clipping test patterns and certain HDR 10 content. XD94
    XD9305
    (Flat)
    KD-65XD9305 BAEP
    KD-55XD9305 BAEP
    successor model X9305C
    No No No 65"- 1098cd/m2
    2% - 1045cd/m2
    5% - 1153cd/m2
    10% - 740cd/m2
    50% - 550cd/m2
    387cd/m2 (SD)
    55"- 1265cd/m2
    2% - 987cd/m2
    50% - 650cd/m2
    Yes HDR10
    SMPTE standarts
    ST2084, ST 2086
    65" - AMVA3, 10-bit ?, 120/100Hz
    55" - AMVA3, 10-bit ?, 120/100Hz
    Flat
    MotionFlow XR 1000
    Light bleed from 4 corners; one faint thin vertical band
    Semi-mate
    4096 x 2160 / 24Р (НDМІ/2/3)
    3840 x 2160 / 24Р
    3840 x 2160 / 25Р
    3840 x 2160 / 30Р
    3840 x 2160 / 50Р
    3840 x 2160 / 60P
    1920 x 1080 / 24P (Оnlу HDMI)
    1920 x 1080 / 50P (Оnlу HDMI)
    1920 x 1080 / 60P (HDMI / Cоmponеnt)
    1920 x 1080 / 50P(HDMI / Componеnt)
    1920 x 1080 / 60І
    1920 x 1080 / 50I
    1366 x 720 / 24P (Оnlу HDMI)
    65"- Edge Led (8x4) 38 zones
    55"- Edge Led (7x4) 28 zones
    Edge led - Left & Right side
    Horizontal Dimming
    PWM Freq. 120/100Hz
    65"- 94.7% / 72% / Delta E 1.3 /Gamma 2.2 / 7270K
    55"- 88.0% / 64% / Delta E 1. /
    Triluminos Display
    65" - 4000:1/ 0.036cd/m2
    55" - 2600:1/ 0.046cd/m2
    with Local Dimming - 0.01cd/m2
    65" - 45°
    55" - 44° / 36°
    65" - 1080 Horizontal Lines
    55" - 1080 Horizontal Lines
    with [MotionFlow] "Clear & Custom"
    Responce Time - 11ms
    XD9305
    65" (64.6), 55"
    наследник на X9305C
    65" - Game mode 51.0ms / with MotionFlow 82ms
    55" - Game mode 35.7ms / with motionFlow 68ms
    65" - 2x7.5W + 2x7.5W
    55" - 2x7.5W + 2x7.5W
    2xTweeter (12x85mm)
    2xWoofer (65mm)
    2 CH Down firing
    Bass reflex
    Dolby Digital
    Dolby Plus
    Dolby Pulse
    DTS
    Compatibility
    JPEG, GIF, PNG, MPO
    AVI, DivX, H.263
    Board: SVP4KDTV15
    Open GL ES 3.1
    RAM: 1,5GB
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    Bluetooth(NFC)Ver.4.1 HID/HOGP/3DSP/SPP
    1 x Ethernet RJ45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Twin tuners
    DVB-T/T2/C/S/S2
    DiSEqC version 1.0
    MPEG2, MPEG4
    HEVC H.265, VP9
    Gamma - 10 points
    ISF - no
    THX no
    but no CMS (Color Management System) to calibrate these gamuts.
    There is also adjusting the gamma, black level adjustment, contrast and backlight. The Pro Cinema mode is still the cheapest cardboard output with colorimetry with Delta E average of 1.93, but differences can mount a delta E of 3 in the last gray levels. It can therefore be used like that, without calibration, but for the more demanding it is still advisable to have provided an effective probe, because with so few differences, a cheap probe could do more harm than good.
    The display also supports HDR10 open-source standard out of the box, with accurate PQ tonemapping (from 4K Blu-ray) and a peak brightness surpassing 1000 nits.
    In the Japanese TV maker’s pursuit of ultra-slim aesthetics however, backlight uniformity seemed to have taken a hit: 65XD9305 review sample suffered from flashlighting from all four corners of the screen, although there’s always a chance that other units in the wild may fare better. The Sony XD93 suffers quite marked light leakage in the 4 corners of the slab that degrade color uniformity and the perceived contrast. Twitch gamers will also be disappointed to learn that input lag has increased by 16ms (i.e. one frame) from last year’s Sony Bravia Ultra HD models. As for the UHD upscaling XD93 is simply the best of the market, above the TV Panasonic, LG, Samsung and others. If I had made reservations at the launch of the 2015 range, meanwhile, Sony proposed updates that have greatly improved the quality of upscaling and sharpness of the image. The upscaling offers a very natural, with a rich texture and an image with a dive with great precision. The multimedia part is much too unstable and unusable for my hand by the simple fact that the videos are stretched, distorted and that the demosaicing is not correct.
    • + Great picture quality for movies
    • + Great motion handling
    • + Very bright
    • + Image processing
    • + One of the best upscaling UHD market
    • + Reality Creation: the most efficient video post-processing market
    • + Simple calibration, fast and efficient!
    • + A more responsive interface, many bugs have been fixed, but there are still too ...
    • + HDR better performance than the 2015 X93C
    • + Colour rendering and Color Range
    • + Dual tuner DVB-T2 / S2 compatible with 4K channels, PVR and PIP functions
    • - Local dimming is not always optimal
    • - Alternating contrast
    • - Blooming
    • - too soft slab may be veiled
    • - Not enough areas Local Dimming for HDR
    • - ABL (Auto Bright Limit) too strong in HDR
    • - Inputlag a little too high on 65 "(49.8ms)
    • - No ISFccc, or Color Management System (CMS)
    • - Still too many bugs with Android TV (videos stretched in multimedia playback, frequent reboot, frequent losses HDMI signal with devices HDCP 1.1, remote control does not respond fairly regularly, concern for synchronizing 3D glasses, saccades with KODI, no bitstream audio with 5.1 KODI, bad die-stamping with videos played via USB / DLNA, HDR mode losses in multimedia playback, etc.
    • - Too many applications not optimized for Android TV
    • - Lacks a little power for a better experience with Android TV
    • - No compatibility Dolby Vision
    • - Loss of saturation at an angle
    • - Average-high input lag
    • - Media player ignores aspect ratio
    XD93
    SD85
    (Curved)
    KD-65SD8505 BAEP
    KD-55SD8505 BAEP
    successor model S8505C
    No No No 65" - max - 450cd/m2
    55" - max - 450cd/m2
    Yes HDR10
    SMPTE standarts
    ST2084, ST 2086
    65" - AMVA3, 8-bit+FRC, 120/100Hz
    55" - AMVA3, 8-bit+FRC, 120/100Hz
    Curvature: 55", 65" - 4200R
    MotionFlow XR 1000
    Semi-mate
    3840 X 2160 / 30Hz / 4:4:4: Yes
    3840 X 2160 / 60Hz: Yes
    3840 X 2160 / 60Hz / 4:4:4: Yes
    1080p / 120Hz: Yes
    3840 x 2160/24Р
    3840 x 2160/25Р
    3840 x 2160/30Р
    3840 x 2160/50Р
    3840 x 2160/60P
    4096 x 2160/24P (HDMI 2/3)
    1080/24P (Оnlу HDMI)
    1080/30P (Оnlу HDMI)
    1080/60P (HDMI / Componеnt)
    1080/50P (HDMI / Componеnt)
    1080 / 60I
    1080 / 50I
    720/24P (Оnlу HDMI)
    65" - Edge Led (below)
    55" - Edge Led (below)
    (Blue Led)
    Frame Dimming
    PWM - ?
    65"- / Delta E 1.8 / Gamma 2.1 / 6685K
    55"- 85% / 63%
    Triluminos Display
    65" - 3810:1 / 0.04cd/m2
    55" -
    65" - °
    55" - °
    65" -
    55" -
    Responce Time - 9.8ms
    SD85
    (CURVED)
    65", 55"
    наследник на S8505C
    65" - Game mode - 36ms / with MotionFlow - 64ms
    55" - Game mode -
    65" - 2x10W
    55" - 2x10W
    Dolby Digital
    Dolby Plus
    Dolby Pulse
    DTS
    Compatibility
    Wireless subwoofer (SWF-BR100); bracket for wall mounting (SU-WL450: 60,20 mm)
    JPEG, GIF, PNG, MPO
    AVI, DivX, H.263
    Board: SVP4KDTV15
    Core architecture: 2xARM Cortex 17(ARMv7)
    RAM: 1,5GB
    Available memory:
    Internal storage space:
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 ac
    Wi-Fi Direct
    DLNA
    1 x Ethernet RJ45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Twin tuners
    DVB-T/T2/C/S/S2
    DiSEqC version 1.0
    MPEG2, MPEG4
    HEVC H.265, VP9
    Gamma - 10 points
    ISF - no
    THX no
    TV can not solve the very first step also correctly (17/255) SD85
    XD85
    (Flat)
    KD-85XD8505 BAEP
    KD-75XD8505 BAEP
    KD-65XD8599 BAEP
    KD-65XD8577 SAEP
    KD-65XD8505 BAEP
    KD-55XD8505 BAEP
    KD-55XD8599 BAEP
    KD-55XD8588 BAEP
    KD-55XD8577 SAEP
    copy of last year's X850xC, but redesigned with IPS panel and without 3D
    No No No 85" -
    75" -
    65" - 400cd/m2
    55" - 2% - 369cd/m2
    Compatible
    HDR Processing
    (missing hardware for playback HDR)
    85" - AS-IPS, 8-bit+FRC, 120/100Hz
    75" - AS-IPS, 8-bit+FRC, 120/100Hz
    65" - AS-IPS, 8-bit+FRC, 120/100Hz
    55" - AS-IPS, 8-bit+FRC, 120/100Hz
    Flat
    8577/8588/8599 - MotionFlow XR 1000
    8505/75"/85"- MotionFlow XR 800
    There is no visible difference!
    Semi-mate
    1080p / 120Hz: Yes
    3840 X 2160/24P
    3840 X 2160/25P
    3840 X 2160/30P
    3840 X 2160/50P
    3840 X 2160/60P
    4096 X 2160/24P (HDMI 2/3)
    1080/24P (Only HDMI)
    1080/30P (Only HDMI)
    1080/60P (HDMI / Component)
    1080/50P (HDMI / Component)
    1080 / 60I
    1080 / 50I
    720/24P (Only HDMI)
    Most resolutions are accepted. To get chroma 4:4:4, select 'Game' or 'Graphics' picture mode. For 4k / 60Hz / 4:4:4, you also need to set the HDMI input to 'Enhanced format' (under 'External inputs' menu). Just like with last year's Sony TVs, 1080p / 120Hz produces little artifacts (lines), but this shouldn't be too bothersome while gaming. The 'Graphics' picture mode has fewer of these little artifacts.
    85" - Edge led (below)
    75" - Edge Led (below)
    Quantum Dots (+ Blue Led)
    Frame Dimming
    No PWM
    85"-
    75"-
    65"-
    55"- 86% / 63%
    Triluminos Display
    85" -
    75" -
    65" -
    55" - 850:1 / 0.12cd/m2
    85" - °
    75" - °
    65" - °
    55" - 58° / 67°
    85" -
    75" -
    65" -
    55" -
    Responce Time - 9.5ms
    XD85
    (8505, 8577, 8599)
    85", 75", 65", 55"
    копие на миналогодишният X850xC, но с нов дизайн, с IPS панел и без 3D
    85" - Game mode 36ms / with MotionFlow 68ms
    75" - Game mode 35ms / with MotionFlow 67ms
    65" - Game mode 35ms / with MotionFlow 67ms
    55" - Game mode 35.5ms / with MotionFlow 66.5ms
    85" - 2x10W
    65" - 2x10W
    55" - 2x10W
    Dolby Digital
    Dilby Plus
    Dolby Pulse
    DTS
    Magnetic Fluid Speaker & Clear Phase
    Compatibility
    55", 65" - Bracket for wall mounting (SU-WL450)
    JPEG, GIF, PNG, MPO
    AVI, DivX, H.263
    Android TV : 6.0,1 Marshmelow (Sony Edition)
    Board : SVP4KDTV15
    SoC model: MediaTek MU5890
    Core architecture: 2xARM Cortex-17(ARMv7)
    Instruction Set : 32-bit ARMv7
    RAM:1,5GB
    Available memory: 8363MB
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    1 x Ethernet RJ45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Twin tuners
    DVBT/T2/C/S/S2
    DiSEqC version 1.0
    MPEG2, MPEG4
    HEVC H.265
    Gamma - 10 points
    ISF - no
    THX - no
    There are also several preset gamma, black level adjustment, contrast and backlight. The Pro Cinema mode is still the mode plus the near Cinema colorimetry with Delta E of 2.5 average on the gray scale (for rap, below 3 is considered the excesses are not visible) but spreads may rise to 4 in the last gray levels. The color space is also very fair with an average Delta E of 2.8 on the Color Checker and 3.7 on saturations. The average color temperature is 6770K or 6500K very close to the search. Gamma, meanwhile, is 1.8 by default, so more to view in bright room, but as the Advanced Mode Improvement of Contrasts (ACE) is enabled by default, we see that it is not at all linear. Moreover, this measure gamma is interesting because it shows that this mode does not clog blacks, but whites are still burned, so we lose grayscale. That said, calibrating the XD85 we were able to maintain a linear gamma with ACE enabled to Low or Medium. The XD85 can therefore be used like that, without calibration, but for the more demanding it is still advisable to have provided an effective probe, because with so few differences, a cheap probe could do more harm only good.
    In Europe it will exist in three design variants named
    ,KD-XD8505B (black) ,KD-XD8577S (silver) , ,KD-XD8588B (black) ,KD-XD8599B (black).
    What differences between references XD8505, XD8577 and XD8599? Let me be clear: no! This is simply references marketed only to please some signs that make large volumes of sales, so they do not suffer from competition on the Internet. You will probably see a little difference, often on the index of fluidity XR1000 instead of XR800, but these are purely marketing indices. There is no visible difference between a Motionflow XR800 and XR1000.
    ACE (Advanced Contrast Enhancer), the famous setting "Improvement of Advanced Contrast" could be compared to a very efficient dynamic contrast. Still, I always advise to disable dynamic contrasts, but that ACE is not like the others. Note that I do not say it is faultless, but it brings so many dynamics of the image on an IPS panel that is difficult to do without. Moreover, it enables up to 1200: 1 ANSI contrast. Its main strength is that it can offer a hyper dynamic image, without clogging the black (it is the opposite, it opens totally black and greatly improves readability in dark scenes). In lit room or in daylight, the illusion is so perfect, you'd swear that this TV has a contrast very powerful, even more powerful than some VA panels. Better, this ACE is devilishly effective with UHD Blu-ray because it totally transforms HDR rendering. No, the HDR seems bland, uninteresting and bridled, while if it is active, HDR rendering is very nice.
    Indeed, despite a very limited coverage Rec.2020, the XD85 offers one of the best colorimetric market through its IPS panel and its algorithm Triluminos remastered colors in Wide Gamut very effectively maintaining a natural. Only the DX900 who offered me a better colorimetry thanks to its LED red phosphorus that help provide intense red that IPS while retaining the advantages of a VA panel. In addition, Sony XD85 offers colorimetry very fair cardboard output and angles very open visions that allow the whole family to enjoy a good image regardless of his place on the couch.
    However, this TV is clearly not recommended for those who watch their movies in dark room. Besides, if you watch your movies in darkened room, there is absolutely no reason to buy the XD85, since the X85C offers exactly the same functionality, but with a VA panel and a very good contrast. True, the colors will be slightly less beautiful but dark room contrast is still paramount.
    The Sony XD85 is limited to enjoy the UHD Blu-ray, with a slab 8 bit HDR rendering flanged (bright peak at 425 cd / m², whatever the size of the target HDR), but again, the ACE saves setting and can offer an ultra dynamic image, very pleasant to look lit room. Nevertheless, the IPS puts his HDR limits with enough gray black, which can amount to more than 0.30 cd / m² at the brightest images, so again, you better watch Blu-ray UHD illuminated room .
    • + Reality Creation: very efficient video post-processing of HD content / UHD
    • + one of the best upscaling UHD market
    • + Motionflow: best motion compensation market
    • + The ACE (Advanced Improvement Contarstes) boosts the dynamics, especially in HDR.
    • + A perceived contrast and amazing dynamic to an IPS panel
    • + A really beautiful color matching, very fair cardboard output in Rec.709 as HDR
    • + Viewing angle twice as wide a VA panel
    • + ghosting time very good, good precision in movements
    • + Inputlag reduced (35ms) + Quick rémance time (9.6ms), excellent for play
    • + The possibilities offered by the Android OS TV
    • + A more responsive interface, many bugs have been fixed, but there are still ...
    • + HDMI 2.0a compatible HDR10, 4K/60, 1080p/120Hz, BT.2020
    • + Excellent performances in lit room
    • + honorable and good audio quality sound power
    • - Contrast too feeble for viewing in dark room
    • - Some visible leaks if it is set too high or too low relative to the center of the slab
    • - Clouding some, though not visible in lit room
    • - Average video processing with SD sources
    • - Finish and manufacturing quality rather average
    • - No Local Dimming
    • - The abandonment of 3D on an IPS panel (passive 3D slab UHD is wearing beautiful)
    • - A HDR too restrained, too narrow gamut Rec.2020
    • - No 10 bit panel
    • - Still bugs with Android TV (videos stretched in multimedia playback, reboot, frequent loss of signal with HDMI devices HDCP 1.1, remote control does not respond fairly regularly, saccades with KODI, no audio bitstream with 5.1 KODI)
    XD85
    XD83
    (Flat)
    KD-49XD8305
    KD-43XD8305
    successor model - X830xC
    No No No 49"
    43" -
    Compatible
    HDR Processing
    49" - AS-IPS, 8-bit+FRC, 120/100Hz
    43" - AS-IPS, 8-bit+FRC, 120/100Hz
    Flat
    MotionFlow XR 800
    Semi-mate
    3840 x 2160/24P
    3840 x 2160/25P
    3840 x 2160/30P
    3840 x 2160/50P
    3840 x 2160/60P
    1080 / 60I
    1080 / 50I
    720/24P (Only HDMI)
    720/30P (Only HDMI)
    720 / 50P
    720/60P
    576 / 50I
    576 / 50P
    480 / 60I
    480 / 60P
    49" - Edge Led (below)
    43" - Edge Led (below)
    Phosphorus-based diodes
    Frame Dimming
    PWM - ?
    49" -
    43" - DCI P3 - 93% / rec2020 - 72%
    Delta E - 1.62 - 0.32
    Gamma - 2.24 - 2.18
    Triluminos Display phosphorus-based diodes for a wide gamut close to the DCI 4K
    49" -
    43" - 3877:1 / 100.8cd/m2 / 0.026cd/m2
    49" - °
    43" - °
    49" -
    43" -
    XD83
    (flat)
    49" - Game mode
    43" - Game mode
    49" - 2x10W
    43" - 2x10W
    Dolby Digital
    Dolby Plus
    Dolby Pulse
    DTS
    Compatibility
    JPEG, GIF, PNG, MPO
    AVI, DivX, H.263
    OS: Android TV : 6.0.1 Marshmellow
    Board : SVP4KDTV15
    SoC model: MediaTek MT5891
    Core architecture: 4x ARM Cortex-A53(32-bit)
    GPU: ARM Mali T860 two core 700MHz
    (47.6 GFLOPS)
    RAM: 2GB
    Total memory: 16GB
    Available memory: 1576MB
    Internal storage total space:1983MB
    Internal storage space: 8258MB
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    1 x Ethernet RJ45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x Optical Audio Out(AAC/PCM/AC3)
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Twin tuners
    DVB-T/T2/C/S/S2
    DiSEqC version 1.0
    MPEG2, MPEG4
    HEVC H.265
    Gamma - 10 points
    ISF - no
    TV can not solve the very first step also correctly (17/255) XD83
    XD80
    (Flat)
    KD-55XD8005 BAEP
    KD-49XD8099 BAEP
    KD-49XD8088 BAEP
    KD-49XD8077 SAEP
    KD-49XD8005 BAEP
    KD-43XD8099 BAEP
    KD-43XD8088 BAEP
    KD-43XD8077 SAEP
    KD-43XD8005 BAEP
    No No No 55" -
    49" - max -
    43" - max -
    Compatible
    HDR Processing
    55" - S-IPS, 8-bit+FRC, 60/50Hz
    49" - S-IPS, 8-bit+FRC, 60/50Hz
    43" - AMVA3, 8-bit+FRC, 60/50Hz
    Flat
    8099/8088/8077 - Motionflow XR 400
    8005 - 49 & 43" - Motionflow XR 200
    Black uniformity is relatively good. There is a bit of clouding on the test picture, but it should not be too noticeable during normal viewing.
    1080p / 120Hz: No
    3840 x 2160 / 30Hz / 4:4:4: Yes
    3840 x 2160 / 60Hz: Yes
    3840 x 2160 / 60Hz / 4:4:4: Yes
    The XD800 accepts a 120Hz signal, but has a 60Hz panel so it can only display half of the frames. It supports chroma 4:4:4 at up to 4k / 60Hz. To display 4:4:4, set the scene to 'Graphics' or 'Game'. This results in an input lag of 33.3ms. It accepts a 4k / 60Hz / 4:4:4 signal only HDMI 2 and 3, and requires 'Enhanced HDMI' to be enabled in the input settings.
    55" -
    PWM - ?
    55" -
    49" -
    43" -
    55" -
    49" -
    43" -
    55" -
    49" - °
    43" - 21°
    55" -
    49" -
    43" -
    XD80
    55", 49", 43"
    49" - Game mode
    43" - Game mode 33.3ms / with MotionFlow 49.1ms
    49" -
    43" -
    Dolby Digital
    Dolby Plus
    Dolby Pulse
    DTS
    JPEG, GIF, PNG, MPO
    AVI, DivX, H.263
    OS: Android TV 6.0 Marshmellow
    Board:
    SoC model: MediaTek MT5891 dual core
    Corе Аrсhitecturе: 4 x АRM Cortех-A53
    Instruсtion Set: 32-bit АRMv7
    GPU: АRM Маli-T860 two core 700MHz (47.6 GFLOPS)
    RAM: 2GB
    Total memory: 16GB
    Internal storage tоtаl mеmоrу: 1983 MB
    Іntеrnаl stоrаgе space: 8358 MB
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    2 x USB 2.0 (DС 5V MAX 500mА)
    1 x USB 3.0 (max 0.9A)
    1 x Еthеrnеt RJ45
    4 x HDMI 2.0 - HDCP2.2 (АRС,CEC,MHL)
    1 x Sаtеlіtе in(Main:F-tуpe fеmаlе)->
    1 x SCART
    1 x Compositе іn (Video+L/R)
    1 x Cоmponеnt in (YPbPr+L/R)
    1 x Optical Аudio Оut(AAC/PCM/AC3)
    1 x 3.5mm Аudio Оut
    1 x Аntеnа (RF) (Fеmаlе)
    1 x CI+1.3
    DVB-T/T2/C/S/S2
    DiSEqC version 1.0
    MPEG2, MPEG4
    HEVC H.265
    XD80
    SD80
    (Curved)
    KD-50SD8005 BAEP
    successor model - S8005C
    No No No 50" - max - 450cd/m2
    Compatible
    HDR Processing
    (missing hardwdre for playback HDR)
    (Firmware Update Later)
    50" - AMVA3, 8-bit+FRC, 60/50Hz
    Curvature: 50" - 4200R
    MotionFlow XR 400
    Semi-mate
    1080p / 120Hz: No
    3840 X 2160/24P
    3840 X 2160/25P
    3840 X 2160/30P
    3840 X 2160/50P
    3840 X 2160/60P
    1080 / 60I
    1080 / 50I
    720/24P (Only HDMI)
    720/30P (Only HDMI)
    720 / 50P
    720/60P
    576 / 50I
    576 / 50P
    480 / 60I
    480 / 60P
    50" - Edge led (below)
    PWM - ?
    50" - 64% /
    50"-
    50" - °
    50" -
    SD80
    (curved)
    50"
    наследник на S8005C
    50" - Game mode
    50" - 2x10W
    Clear Phase
    Dolby Digital
    Dolby Plus
    Dolby Puls
    DTS
    Compatibility
    JPEG, GIF, PNG, MPO
    AVI, DivX, H.263
    Board:
    SoC model: Mediatek MT5891
    Core architecture: 2xARM Cortex-A17(ARMv7)
    GPU: ARM Mali-T860 two core
    RAM: 2GB
    Total memory:
    Available memory:
    Internal storage total memory:
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    2 x USB 2.0 (DC5 V MAX500mА)
    1 x Еthеrnеt RJ45
    4 x HDMI2.0a (АRС,CEС,MHL)
    1 x Sаtеlitе in(Maіn:F-type fеmаlе)->
    1 x SCART
    1 x Cоmpositе in (Video+L/R)
    1 x Сompоnеnt in (YPbPr+L/R)
    1 x Opticаl Аudio Оut(AAC/PCM/AC3)
    1 x 3.5mm Аudio Оut
    1 x CI+1.3
    Twin tuners
    DVB - T/T2/C/S/S2
    DiSEqC Version 1.0
    MPEG2, MPEG4
    HEVC H.265
    • -- Media player ignores aspect ratio
    SD80
    XD75
    (Flat)
    KD-65XD7505 BAEP
    KD-65XD7504 BAEP
    No No No 65" - 500cd/m2
    Compatible
    HDR Processing
    65" - ? , 8-bit, 120/100Hz
    Mitionflow XR 800
    1080p /120Hz: No
    3840 x 2160 / 30Hz / 4:4:4: yes
    3840 x 2160 / 24Р
    3840 x 2160 / 25Р
    3840 x 2160 / 30Р
    3840 x 2160 / 50Р
    3840 x 2160 / 60P
    4096 x 2160 / 24P (HDMI 2/3)
    1920 x 1080 / 24P (Оnlу НDMI)
    1920 x 1080 / 60І
    1920 x 1080 / 50I
    1920 x 1080 / 30P (Оmnlу HDMI)
    1920 x 1080 / 50P (HDMI / Cоmponеnt)
    720 / 30P (Оnlу HDMI)
    720 / 50P
    720 / 60P
    576 / 50I
    576 / 5PР
    480 / 60І
    480 / 60P
    To display Chroma 4:4:4 set the scene to 'Graphics' or 'Game'. HDMI ports 2 and 3 accept a 4k / 60Hz / 4:4:4 signal, but only when 'Enhanced HDMI' is enabled in the input settings. The 65XD750 does accept a 1080p / 120Hz resolution, but can only display half of the frames, since it is a 60Hz TV.
    65" - Direct Led
    Phoshorus-based diodes
    PWM - ?
    65" -
    65" -
    65" - °
    65" -
    XD75
    7505
    65"
    65" - Game mode
    65" - 2x10W RMS
    Dolby Digital
    Dolby Plus
    Dolby Puls
    DTS
    Compatibility
    JPEG, GIF, PNG, MPO
    AVI, DivX, H.263
    OS: Аndroid TV : 5.1.1 Lоlipop
    Board : SVPDTV15
    SoC model: MediaTec MT5891
    Core architecture: 2xАRM Cortех-A17(АRMv7)
    Instruсtion Set : 32-bit АRMv7
    CPU SoC: МеdіaTek MT5890 duаl corе
    GPU: АRM Маli T624 triplе corе
    RAM: 1,5GВ
    Intеrnаl stоrаgе tоtаl space: 8,36GВ
    Lan
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    Wi-Fi Direct
    DLNA
    1 x Ethernet RJ45
    4 x HDMI 2.0a (ARC, CEC, MHL)
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out (YPbPr+L/R)
    1 x CI+ 1.3
    DVB-T/T2/C/S/S2
    MPEG2, MPEG4
    HEVC H.265
    TV can not solve the very first step also correctly (17/255) XD75
    XD70
    (Flat)
    KD-55XD7005 BAEP
    KD-55XD7004 BAEP
    KD-49XD7005 BAEP
    KD-49XD7004 BAEP
    No No No 55" -
    49" -
    Compatible
    HDR Processing
    55" - AS-IPS, 8-bit, 60/50Hz
    49" - AS-IPS, 8-bit, 60/50Hz
    MotionFlow XR 200
    3840 x 2160 / 24P
    3840 x 2160 / 25P
    3840 x 2160 / 30P
    3840 x 2160 / 50P
    3840 x 2160 / 60P
    1920 x 1080 / 60I
    1920 x 1080 / 50I
    1920 x 1080 / 30P (Omnly HDMI)
    720 / 30P (Only HDMI)
    720 / 50P
    720 / 60P
    576 / 50I
    576 / 50P
    480 / 60I
    480 / 60P
    55" - Edge Led
    49" - Edge Led
    Global Dimming
    PWM - ?
    55"-
    49"-
    55"-
    49"-
    55" - °
    49" - °
    55" -
    49" -
    XD70
    55", 49"
    55" - Game mode
    49" - Game mode
    55" - 2x10W RMS
    49" - 2x10W RMS
    Clear Phase
    Dolby Digital
    Dolby Plus
    Dolby Puls
    Compatibility
    JPEG, GIF, PNG, MPO
    AVI, DivX, H.263
    OS: Android TV: 6.0 Marshmellow
    Board:
    SoC model: MediaTek MT5891 quad core
    Instruction Set: 32-bit АRMv7
    GPU: АRM Маli-T680 two cores
    RAM: 2GB
    Intеrnаl stоrаgе space: 8358 MB
    Lan
    Wi-Fi
    802.11 b
    802.11 g
    802.11 n
    Wi-Fi Direct
    DLNA
    1 x Ethernet RJ45
    4 x HDMI 2.0a HDCP2.2 (ARC, CEC, MHL)
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x Antena (RF)(female)
    1 x CI+ 1.3
    Twin tuners
    DVB-T/T2/C/S/S2
    HEVC H.265 2160p/60
    TV can not solve the very first step also correctly (17/255) XD70
    Series
    Model
    UHD
    Premium
    Dolby Vision
    Hybrid Log Gamma
    (HLG)
    HDR 10
    _______________
    In Windows
    2/5/10/20/100%
    Videopanel
    Type LCD matrix,
    Bits of color,
    Curvature,
    Index,
    Screen Uniformity
    Backlight
    Type backlight
    (Local Dimming zone)
    Type LED
    MEMC
    Backlight Scanning
    Color Space
    ____________
    DCI P3 / Rec.2020 / Delta E
    Contrast
    White & Black level
    ____________
    ANSI
    With local dimming
    Viewing angle
    __________
    ( ° cone)
    Motion resolution
    Product
    Input Lag
    Audio
    SoC
    CPU
    GPU
    Software
    OS
    Networks
    Conectors
    Tuners
    Opportunities for
    calibration
    Note
    Pros & Cons
    Product
    Този пост е редактиран от hristoslav2; 06-12-16 в 17:06.
    #1518
    Ако е на Булсат - нормално
    iveto одобрява това.
  5. Senior Member Аватара на iveto
    Jan 2013
    #1519
    Точно така...зависи от оператора....аз съм на Близу с Ка модул и Нова телевизия си излиза съвсем прилично...от бг телевизиите гледам само нея....
    Oct 2004
    #1520
    Здравейте колеги,
    Може да е обсъждано вече, но не го намирам по темите.
    Мисля да купувам едно сони KD-55XD8577, въпорса ми е свързан с това как седи въпроса за гаранцията когато има изгорели пиксели.
    Аз съм малко карък и винаги на мен се падат
  7. Junior Member
    Sep 2005
    #1521
    То гаранция и да има, по-добре да избегнеш връщането в магазина още на следващия ден, като тестваш на место преди да го платиш
    Аз така преди години се отказах от един Самсунг - взех го неразпечатван от Техномаркет , цяла вечер си играх да го настройвам, и по едно време като му пуснах черно, точно в средата светна един ... Добре че се навиха да ми го сменят за Филипс, който още работи и съм доволен
    Иначе да не ти убивам хатъра, аз от 3 дни го имам телевизора, взех го заради добрата пакетна цена с PS4, първо Сони ми е, досега съм имал 3-4 Филипса, и все си мислех че купувам най-доброто за под 3000 лв, но някой неща ме карат да мисля че не е така
    То всъщност ако държиш на Андроида, както е в моя случай, нямаш голям избор , само две марки
    Най-добре иди в някой магазин (в Сони центъра на Сердика със сигурност има изложен модела) , разцъкай го, там имат реален ТВ сигнал
    Sep 2008
    #1522
    Да ви кажа, това че един производител вижда нещата различно от друг не означава, че е по-лош. Говоря за много неща, дали дистанционното няма да ви хареса, дали очилата ще са скъпи, дали тв гайда няма да изглежда както на вас ви е угодно, или пък телевизора има лаг в менюто за цифровата настройка... Винаги ще се намери някой и нещо, което да се хареса на някого. Това не прави въпросната стока по-лоша от друга такава...
    Между Сони и Филипс избора винаги ще е един и същ, между Сони и Самсунг за мен избора винаги ще е един и същ, между Сони и други марки - по добре да не купувам нещо, отколкото да купувам нещо, което вече знам , че няма да ми хареса...
    Имам Сони от 2007-ма, в момента в който хванах дистанционното на новото вече знаех кое копче къде е, дистанционното ми е супер удобно и единствената съществена разлика спрямо старото е , че цифровата клавиатура е в горния край. Жена ми само ми обяснява, как тв-то било скапано заради това.... Друг СЪЩЕСТВЕН проблем с тези тв-та е когато се ползват в стаята в която се спи. Това животно свети като прожектор, сутринта като се включи прави в стая ден, дори и на минимум всички настройки. Дори се чудя да влизам в сервизното и да търся да намалям още яркостта... ЛЕД Лампа с диагонал 55 инча си е голям прожектор в стаята нощно време...
    #1523
    Очаквайте от 7 Декември (утре) и нататък, ъпдейт вероятно до Android 6.0
    https://sony-paa-pa-en-web--paa.cust..._id/168015/kw/
    Вярно, че сайтът е за Азия, но според мен с ъпдейта са заредени всички регионални сървъри на Sony.
    Ако на някой му се рови може да провери в европейският такъв
    http://sony-eur-eu-en-web--eur.custhelp.com/
    http://sony-eur-eu-bg-web--eur.custhelp.com/
    И един въпрос към собствениците на модели 2015/2016: телевизорите ви, поддържат ли кодек VP9 ?
    (преди година, сони обещаха да го добавят с ъпдейт...)
    https://www.youtube.com/watch?v=VzV5lnfoWOc
    https://www.youtube.com/watch?v=0aK4XjXDTZk
    Този пост е редактиран от hristoslav2; 06-12-16 в 21:42.
    stensy, svetlio1, podredko и 1 други харесват това.
    #1524
    Това беше ползваният в YouTube нали - моят 49Х8309С няма проблеми с възпроизвеждане на 4К клипове там ... освен слабия нет дето ги имам
    hristoslav2 одобрява това.
  12. Senior Member Аватара на iveto
    Jan 2013
    #1525
    stensy и hristoslav2 харесват това.
  13. Junior Member
    Oct 2004
    #1526
    Цитат Първоначално публикувано от bobybc Виж публикацията
    Насочил съм се точно към тази промоция, сподели какво не ти харесва. Мен ме притеснява, че ще го гледам от 2 метра и незнам как ще е с SD каналите, в магазина на Сердика казаха, че нямат SD сигнал за да ми го демонстрират
    #1527
    Могат да ти го пуснат на цифрова ефирна - Нова ТВ...Един метър кабел свързан към антенният вход е достатъчен като антена.
  16. Member Аватара на Сидеров
    Feb 2016
    #1528
    В тея метални хамбари с термо панели по някога не стига. По добрия вариант е да се отиде на място с една флашка и 480p клипове и още няколко такива с бързи сцени.
  17. Junior Member
    Oct 2016
    #1529
    Калибрация за SONY 55 SD 8505
    Този пост е редактиран от jimmitoo; 07-12-16 в 14:40. Причина: искам да го пусна като тема
  18. Junior Member
    Jul 2016
    #1530
    Аз имам KDL43W805C. Кой от новите модели е съпоставим като хардуер и качество на картината? От старите почти никъде няма вече. А новите гледам, че са 200 или 400Hz.
  1. Избор на климатик 2016 г.
    Отговори: 3492
    Последно: 01-01-17, 17:50
  2. Квалификации Евро 2016
    От iihtiandar във форум Спорт
    Последно: 10-06-16, 08:03
  3. SONY телевизори 2015
    Отговори: 866
    Последно: 02-01-16, 07:36
  4. Отговори: 0
    Последно: 25-10-10, 11:26
  5. Отговори: 4
    Последно: 27-05-08, 07:30
