Проблем с TV-Out pri Detonator 40xx
Popadnah na interesna statiq na www.neowin.net, moje na nqkoj da mu e ot polz:
With the release of the all new Detonator 40-series many user experience tv-output problems with it. We worked on that issue and discovered the reason. There are 3 different solutions to solve this problem.
Cause:
Refreshrate-tools like Refreshrate Fix MKII lead to this malfunction. The problem even occurs if one manipulates the refreshrate for 1024x768 though the tv is not able to display this resolution. We conclude that such tools cause changes the detonator 40 can't deal with.
Solution 1:
We recommend not using refreshrate-tools in order to avoid trouble. If there is such utility on your pc and you are not able to use the tv-output it might help to reinstall the Detonator-driver. In case you can't do without a refrechrate-fix in combination with a 40-series Detonator you should use Refresh-Lock only. This utility does not cause any changes in the registry and it will not harm your display-driver. However the program always needs to run in the background while playing Direct3D- and OpenGL Games
Sorry, no drugite 2 solution-a ne mojah da gi izteglq, problem sys servera... no vie moje da probwate i sami. URL: http://www.neowin.net/comments.php?c...y=main&id=7107
Аз този проблем съм го оправил като използвам нестандартната резолюция 720х576 за TVout и на нея не слагам да е на 100 херца като на другите, ами да си е на 60 по default и номера работи идеално.
По принцип този проблем го има не само на 40.хх ами на всички драйвери, които използват компресираното описание на резолюциите.
