Sound Blaster Live Drivers
zna4i iskam da vi pitam za sb live driverite.Ka4ih si win XP po vreme na install wina ka4va driveri koito sa prili4no dobri(hardware buffer,maj poddarjat EAX).ta da pitam s tqh li po dobre da ostana ili da ka4a liveware3 s updatetite mu tam za win2k ili vse o6te izdirvam onezi beta driveri za Audigy koito stavali i za drugata seria Live(dajte savet i ako predlagate Audigy driverite dajte link)
Izchakai oshte malko i vij sita ma Creative.
Ne se pipa neshto koeto raboti !
zna4i kojto iska eto linka:
http://file2.mydrivers.com/sound/UDA_beta.zip
taka:zna4i eto vi malko info ako ima jelae6ti da si ka4at AUdigy driverite na sb live karta za Windows XP (az sam s rc2):
1.-Remove existing SBLive drivers
-Start->Settings->Control Panel->System, or, right-click on My Computer icon
-Click on Hardware tab
-Click on Device Manager button
-Expand Sound, video and game controllers
-Right-click on SBLive WDM Basic device, select "Uninstall..."
-Click OK to uninstall
-Close Device Manager
-Rename SBLive INF and PNF files in the \WINNT\INF directory if not already done;
-Rename wdma10k1.inf to wdma10k1.inf.old
-Rename wdma10k1.pnf to wdma10k1.pnf.old
taka sega trqbva da si izteglite 1 patch ot sajta na mnogouvajavaniq Flex-2
http://free.techno-link.com/Flex-2
http://free.techno-link.com/Flex-2/W...by_j_sklar.rar
SBLive_Fix_by_j_sklar.rar (tova e imeto na patcha)
extracvate patcha nqkade na harda si i otivate kam stapka 2
2.FOR THE FOLLOWING STEP: it is reccomended to do this in another OS (another install of windows, DOS), or reboot to safe mode, although it may be possible to do this from Windows without rebooting, but i would NOT reccomend it.
Delete the following files from the System32 Folder in your Windows Directory:
ksproxy.ax
ksuser.dll
wdmaud.drv
Delete the following files from the Drivers Directory in your System32 folder:
ctljystk.sys
gameenum.sys
2gmgsmt.sf2
drmk.sys
emu10k1.sys
ks.sys
portcls.sys
stream.sys
Find Driver.cab in the Driver Cache folder in your Windows directory and rename it to something like Driver.cab.bak(C:\WINDOWS\Driver Cache\i386\driver.cab)
taka sled kato iztriete tezi fajlove kam stapka 3
3.Reboot to Windows XP. (you may notice that your cd/dvd/cdrw drives are not working, dont worry, they will after the next reboot!)sa6to kogato win vi pita da poso4ite driveri za noviq hard kojto e otkril natisnete cancel.(2pati vi pita)
taka sega extracvate UDA_beta.zip(tova sa AUdigy beta driverite)nqkade na harda si
sega trqbva da namerite Audio.ini(malko 6te go redaktirame :)))
uda_beta\Audio\English\Setup\Audio.ini (tuka trqbva da e)
i namirate "CardDetection = 1" kadeto [1] zamenqte s [0]
startirate "UDA_beta\Ctrun\Ctrun.exe" i sledvate slednite instrukcii:
3.Run the UDA installer from "UDA_beta\Ctrun\Ctrun.exe"
-Ignore "The drive cannot read the CD correctly" error message by clicking "Ignore"
-Allow installation to run through
-Re-boot
-Click cancel when Driver Wizard asks for drivers for Emu10k1 device
-Click cancel when Driver Wizard asks for drivers for Game Port for Emu10k1 device
zna4i vazmojno e (vaob6te da ne vi pita 1iq pat kato gi ka4vah me pita no vtoriq ne ako pita -CANCEL)
kato svar6i setupa moje o6te da nqmate sound togava pravite slednoto kopirvate fajlovete ot patcha [SBLive_Fix_by_j_sklar.rar] saotvetno fajlovete v system32 i v system32/drivers (vijte readme.txt v patcha za podrobnosti)
Pri kopirvaneto ako nqkoj ot fajlovete sa6testvuva ne go zamenqjte !!!!
taka se trqbva da preimneuvate driver.cab.bak otnovo na driver.cab
vse o6te moje da nqmate sound i cd-rom :))))
restartirajte i sled kato zaredi XP trqbva pone cd-roma vi da raboti
taka sega :
4.find and run UDA_beta\Audio\English\drivers\CTZAPXX.exe
Click OK to install drivers
-Click YES when asked whether to continue with installation of unsigned drivers for Emu10k1 device
-Click YES when asked whether to continue with installation of unsigned drivers for Emu10k1 Game Port device
-Re-boot
-Ignore Dr. Watson error (if any) on ReadReg application (pri mene ima6e)
-Enjoy (or remove & start over ;-)
am zna4i cql den se zanimavah s tiq driveri 2 preinstalirah windows
i za sega samo taka ba4kat dobre(ima malak problem pri Surround Mixer2 kato natisnete settings na speakers selection -no samo tova e)izbora na speakers v control panel ve4e ne vajat (samo ot Surround Mixer) ina4e ima novi efekti i glezotijku
ami tva e ako ima problemi i sled tezi instrukcii ne znam ve4e ...:)
Повелителю на Светлината, ти си маниак, Братче!!! Това е добре ама ако ти бачка добре ХРто що го човъркаш още???
Вече си ми симпатичен - и аз бях така докато не ми писна да си преинсталирам ОS...
'Shtot Bratcheda e vatre ;)
Az iskam da popitam za Creative Live !
pod Windows ME digital output si raboteshe bez problemi i direktno go vkarvah v Digital in na Subwoofera. Obache pod win 2000 i windows XP - build 2600 niama digital output, slagash go i nishto , inache na analogov output - sichko raboti. Ako niakoi e imal podoben problem neka kaje.
Govoria za Default Driverite na XP i 2000
