LG Titan Deluxe Smart ASUW096MMS4
  Presentation and Recommendation
Представяне и препоръка
 This machine was produced in 2016. LG's high-end machine. High performance air conditioning. Let's try to introduce you.It's a super machine for me.
Тази машина е произведена през 2016 г. Машината от висок клас на LG. Високоефективна климатизация. Нека се опитаме да ви запознаем.Това е супер машина за мен.
 https://klimaforumu.com/attachment.php?aid=1746
 https://klimaforumu.com/attachment.php?aid=1749
 https://klimaforumu.com/attachment.php?aid=1750
 https://klimaforumu.com/attachment.php?aid=1753
 https://klimaforumu.com/attachment.php?aid=1754
 https://klimaforumu.com/attachment.php?aid=1757
copper pipe
This device is being launched at 9 000 B / h. But the interior unit we have seen and examined has a capacity of 18,000 b / h in many brands, with dimensions as large as the domestic capacity. It is a very fat machine. The plasma system of LG's Sirius Smart is also available on this screen (the advertising is abundant if I believe so much about these accessories). The biggest difference in this device is the front panel.Sirius ta filter is on the top only. The front cover slides upwards when the air conditioner is opened, relaxing air intake. These mechanisms are very well designed, but I am afraid of them being broken. The filter can be opened by slowly pushing it up manually to open the lid for cleaning. But again, you have to wait for it to shut down by pressing the emergency button or pressing the emergency button.
 Most of the functions are Sirius-like programs. Capacity limitation, inverter level indication, consumption etc. etc. All the LG's are now standard as well. The biggest difference of this machine from the others is the image and performance. Many other features are common with Sirius Smart.
 My biggest disadvantage is that the flaps move up and down. This is a plus, but it's an uncomfortable shape in the cold. If the heel is installed like under the beam, it's even more troublesome. I mean, every beauty is a flaw.
 So far we have our observations so much. We also provide information about operation and use, as well as sold, sold, assembled, and run.
All the pictures belong to me.
 https://klimaforumu.com/attachment.php?aid=1760
     Отговор: LG Titan Deluxe Smart ASUW096MMS4
  На това чудо външния топлообменник има около 50 метра медна тръба, колкото на старите ми Мидеи.
Би трябвало да топли зверски :)
Води се 9-ка, а вътрешното тяло е като на 18-ка, т.е би трябвало на най-ниската степен хем да има дебит, хем да не фучи ...
Сега ако кажеш и, че има аналог от БЕКО тази машина за примерно 1000лв :) .... ?!?
     4 Прикачен файл(ове)
Ventsislav Negentsov
    LG Titan original G.Korea production. Outdoor unit LG Sirius seride 18 000 BTC air conditioner same as outdoor unit. The compressor is Japan's Twin Rotary Toshiba. Compressor capacity Higher capacity than the Toshiba SKVP 10 series. Real super machine. This machine has nothing to do with Beko.
He's a monster.
 https://forum.setcombg.com/attachmen...id=25465&stc=1
 https://forum.setcombg.com/attachmen...id=25466&stc=1
 https://forum.setcombg.com/attachmen...id=25467&stc=1
 https://forum.setcombg.com/attachmen...id=25468&stc=1
  Може да не си видял, ще го повторя и в тази тема, за което се извинявам, но всеки си гони нещата.
mbirol , LG Titanium може ли да работи с минимална консумация на енергия 200W при външна температура примерно -5° C
Примерно, моят климатик работи така: външна температура +3°C.....+5°C и климатика работи непрекъснато без да изключва, но когато външната температура стане -3°C....-5°C започва да работи on/off. Включва и изключва като конвенционален климатик. Защо се получава това при някои инверторни климатици?
milanov
    Titan is a professional inverter. The condenser is too big. Defrost will do little. min capacity is very sensitive.
Titan = Toshiba SKVP = ME FH = Samsung Janfura = Fujitsu LUCA
Price / performance = LG Titan ( Turkey markets )
  И откъде да го купим и на каква цена?
Miro1972
    Не знам българския пазар. Но Турция също е много евтин LG Титан от други климатик супер инвертор. 30-40% огнена различна. Търсене в български сайтове с код на продукта.
LG е глобална марка. Различни модели се продават в България. Този модел е за мен.
  В България това се продава, като LG Athena H9AL и H12AL. Аз си купих такъв 12-ка :) За сега ми харесва, още ми е нов, не мога да дам някакво обстойно мнение, но не мисля, че сгреших с избора :)
     Re: LG Titan Deluxe Smart ASUW096MMS4
  А кой модел е с 42 кг външно тяло този е с 35 разликата от 7 кг е доста голяма
  Според мен не може да слезе на 17db. Предполагам, че повечето данни са различни от реалните.
