DSC PC6010 смяна на мастер кода
  Здравейте, колеги!
Имам горе посочената система на dsc pc6010 с клавиатура LCD6501. Знам как се променя инсталаторския код, но не мога да разбера как да променя master code. В документацията никъде не е посочено как става (говоря за installer manual-а), или поне аз не видях.
Ще бъда благодарен някои да сподели как става номера.
Благодатя предварително!
     Re:DSC PC6010 смяна на мастер кода
  Programming From a Keypad
To program the PC6010 using the menu system, you must have
installed and enrolled at least one keypad. See section 4 for
more information.
1. To program the system, you will first need to enter the
Installer’s Programming mode: enter[*][8][Installer’s Code] at
any keypad that is enrolled on the system.
By default, the Installer’s Code is [5555]. When you are in
Installer’s Programming, all LEDs on the keypad will be off.
To prevent unauthorized personnel from entering Installer’s
Programming, you should change the Installer’s Code from
the default setting. For more information, see “System
Section - Installer Options” in the Programming Manual.
2. To navigate through the menus, use the arrow keys (<>).
When you see the menu item you want, press the[*] key to
select it. Getting to the right programming section may
require scrolling and selecting items from several menus. To
return to previous menus, press [#].
Refer to the Programming Manual for an overview of the
menu structure, and descriptions of each programming
section.
NOTE: The YES, NO and CANCEL buttons do not work in
Installer’s Programming. If you press them in Installer’s
Programming, the keypad will sound an error tone.
3. Once you have entered Installer’s Programming, the first
menu consists of the items listed below. Use the arrow keys
(< >) to scroll to the area you wish to program, and press[*].
System Area - Use this section to program options that
affect the operation of the entire system. These options
include communications, downloading, printer options,
installer and master code programming, etc.
  Мерси колега, но не мога да намеря опция за промяна на кода в тази секция.  :help
Софтуерната версия на централата е 2.11
  Тук има 4 вида потребители:
 - Основен
 Напреднал
 Инсталаторски
 Мастер
Дефинирането на нови потребители е описано на стр.15 и 16 от Maintenance Manual
 http://cerber.pro/files/misc/PC6010mm.pdf
Може да се пробваш да създадеш нов мастер потребител и да изтриеш стария.
Другите мануали са тук:
 http://www.bkgrupe.lt/uploads/docs/A...1ymas%20EN.pdf
 http://www.walkerhomesecurity.com/ho...05176_r001.pdf
  Системата не позволява да се прави друг мастер потребител.
Тези мануали ги имам но нищо не пише по въпроса ... :help
  Пробвай така:
"actually you have the master. you can go *5, master code, 40, new master code, ##. or you can go *8, installer code, 007, new master code, ##. "
  Pat, това работи при PC5010, но тук не става за съжаление.
  Някакви други решение ? :help
  За съжаление аз нямам. Бих експериментирал ако беше при мен. Не може ли да се подключи към dls тази централа? От къде си я купувал? Пробвай в нашите DSC.
 http://www.dscbg.com/
Ето и един много хубав форум:
 http://www.diyalarmforum.com/board/
Има и отделна секция само за DSC, но аз съм баннат там.
