Купувам преходник Compact Flash към 2.5" IDE ATA хард диск
За връзка П.М. или 0879406204
Compact Flash to 2.5" IDE Adapter
Ideal for industrial and diskless PCs, this device allows you to boot from a compact flash card.
* Fully compatible with Type 1 (3mm) and Type 2 (5mm) CF cards and IBM Microdrive
* Latest version H1 device
* Jumper to select Master / Slave mode
* Mini IDE 44 pin male connection
* This device is for compact flash cards only - NOT 1.8" hard drives
* No power connection required (power is provided through IDE cable)
* As this device connects to the IDE bus the CF cards are not hot swappable
http://www.picvalley.net/u/2080/2020...8SADxP2rxe.JPG
п.п. знам, че в Dealextreme го има, и струва 4лв. :) Аз го търся тук в БГ!
http://www.dealextreme.com/p/cf-to-i...ter-card-17834
Re:Купувам преходник Compact Flash към 2.5" IDE ATA хард диск
определено е много добра цена.
Аз го купих за 15 лв преди 6м.
