Какво е NetBIOS?
    May 2004
    Какво е NetBIOS?
    Може въпросът ми да ви се струва тъп но някой може ли да ми каже какво е NETBIOS?
  3. Gadget
    Guest
    Какво е NetBIOS?
    NetBIOS (Network Basic Input/Output System) is a program that allows applications on different computers to communicate within a local area network (LAN). It was created by IBM for its early PC Network, was adopted by Microsoft, and has since become a de facto industry standard. NetBIOS is used in Ethernet and Token Ring networks and, included as part of NetBIOS Extended User Interface (NetBEUI), in recent Microsoft Windows operating systems. It does not in itself support a routing mechanism so applications communicating on a wide area network (WAN) must use another "transport mechanism" (such as Transmission Control Protocol) rather than or in addition to NetBIOS.
    NetBIOS frees the application from having to understand the details of the network, including error recovery (in session mode). A NetBIOS request is provided in the form of a Network Control Block (NCB) which, among other things, specifies a message location and the name of a destination.
    NetBIOS provides the session and transport services described in the Open Systems Interconnection (OSI) model. However, it does not provide a standard frame or data format for transmission. A standard frame format is provided by NetBUI.
    NetBIOS provides two communication modes: session or datagram. Session mode lets two computers establish a connection for a "conversation," allows larger messages to be handled, and provides error detection and recovery. Datagram mode is "connectionless" (each message is sent independently), messages must be smaller, and the application is responsible for error detection and recovery. Datagram mode also supports the broadcast of a message to every computer on the LAN.
    Dec 2000
    Какво е NetBIOS?
    See also:
    1) SMB
    2) CIFS
    3) ;-ppppppppppppppppppppppp
  5. Pat
    Pat е офлайн
    Senior Member Аватара на Pat
    Oct 2003
    Какво е NetBIOS?
    Информация на английски в нета колкото искаш. Да ама не всички са с езикова гимназия. Информацията е ценна тогава, когато е поднесена в достъпно състояние. Нали УЖ държим на българския език в този форум? Иначе и аз мога да постна извадка от някой китайски саит ( на китайски) [], пък който иска да го разбира - да научи китайски [:D]
  6. Gadget
    Guest
    Какво е NetBIOS?
    //offtopic<font color="blue">
    По тази логика, защо ако искаш да се сертифицираш към Microsoft, Cisco и др. изпитът ти е на английски? Като бонус дават повече време на изпита заради неанглоезичната принадлежност на кандидата. Но това не помага на повечето кандидати, които изпитват затруднение като цяло с чуждите езици.
    По-добре да се свиква с английската терминология с помощта на речник до себе си, отколкото един ден да цъфнем като в небрано лозе
    Желателно е всеки тръгнал да се занимава с IT да понаучи и английски. За съжаление България, не е Франция, където си държат на езика.
    </font id="blue">
  7. Senior Member Аватара на Lupus
    Aug 2003
    Какво е NetBIOS?
    <font color="blue">//offtopic на @Gadget //offtopic
    1. Все пак това е форум, а не сертификационна комисия нали?
    2. Ако беше подкрепена идеята на Profita за ИТ енциклопедията (или по-точно към всеки раздел да има кратък речник на термините и съкращенията) и всеки добавя там по един два термина на седмица, този въпрос щеше да има вече отговор на български език.
    3. Съгласен съм, че английската терминология е в основата на ИТ, но не бива тия дето не го знаят да се чувстват невежи (или да останат такива) само по тази причина. Всяко нещо с времето си.</font id="blue">
    Jan 2003
    Какво е NetBIOS?
    @Pat
    Информация в нета имало на англиски. Ами има. Ама то превода и "сдъвкването" пари струват. Всеки чака всичко наготово. Ако може и с фунийка да му се налее в главата за да не се налага да чете. Ми не става. И на мене ми е трудно, ама се оптивам.
    Кофти е да не знаеш езика и да ти е трудно да се ориентираш ама който иска да се занимава с IT трябва да е наясно, че ще трябва и малко терминология да понаучи.
    May 2004
    Какво е NetBIOS?
    Благодаря за отоворите ви. Успях да добия горе долу представа. С английския нямам проблем така че ще ви бъда благодарен ако споменете някой линк откъдето да чета, дори и да е на английски.
  11. Gadget
    Guest
    Какво е NetBIOS?
    На който не му е ясно - ползва Google. На който му е ясно - ползва http://dockera.data.bg
  12. Pat
    Pat е офлайн
    Oct 2003
    Какво е NetBIOS?
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">@Pat
    <div align="right">Originally posted by Raziel*-*18/05/2004*:* 10:33:37</div id="right">
    .......Сега остава и ценоразпис да сложим...[:D]
    Съгласен съм, че всеки който се занимава с ИТ е желателно да знае английски, но точно ИТ форум не е най-подходящото място да се учи такъв.
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">//offtopic
    Когато става въпрос за професионална оринтация е нещо съвсем различно. И аз съм държал държавен изпит по английски.[]
  1. Отговори: 7
    Последно: 26-03-14, 18:29
  2. Отговори: 6
    Последно: 01-03-10, 12:59
  3. 100Мбит мрежа и NetBIOS въпрос ?
    От PCBrocker във форум Мрежи
    Последно: 01-03-04, 14:46
  4. netbios-ssn TIME WAIT
    От Gaby във форум Мрежи
    Последно: 26-05-03, 22:04
  5. Може ли file and print sharing без NETBIOS?
    От hipo във форум Мрежи
    Отговори: 45
    Последно: 29-03-02, 11:12
