Link: безплатна колекция от мрежови инструменти
Net Tools е безплатна мощна и обемна колекция от всички възможни мрежови инструменти. Това, може би, е най-големия напълно безплатен пакет с програми за работа в мрежа, сформиран някога. Авторите прецизно са подбрали продуктите, които участват в този софтуерен алианс:
IP Address Scanner
· IP Calculator
· IP Converter
· Port Listener
· Port Scanner
· Ping
· NetStat (2 ways)
· Trace Route (2 ways)
· TCP/IP Configuration
· Online - Offline Checker
· Resolve Host & IP
· Time Sync
· Whois & MX Lookup
· Connect0r
· Connection Analysator and prtotector
· Net Sender
· E-mail seeker
· Net Pager
· Active and Passive port scanner
· Spoofer
· Hack Trapper
· HTTP flooder (DoS)
· Mass Website Visiter
· Advanced Port Scanner
· Trojan Hunter (Multi IP)
· Port Connecter Tool
· Advanced Spoofer
· Advanced Anonymous E-mailer
· Simple Anonymous E-mailer
· Anonymous E-mailer with Attachment Support
· Mass E-mailer
· E-mail Bomber
· E-mail Spoofer
· Simple Port Scanner (fast)
· Advanced Netstat Monitoring
· X Pinger
· Web Page Scanner
· Fast Port Scanner
· Deep Port Scanner
· Fastest Host Scanner (UDP)
· Get Header
· Open Port Scanner
· Multi Port Scanner
· HTTP scanner (Open port 80 subnet scanner)
· Multi Ping for Cisco Routers
· TCP Packet Sniffer
· UDP flooder
· Resolve and Ping
· Multi IP ping
· File Dependency Sniffer
· EXE-joiner (bind 2 files)
· Encrypter
· Advanced Encryption
· File Difference Engine
· File Comparasion
· Mass File Renamer
· Add Bytes to EXE
· Variable Encryption
· Simple File Encryption
· ASCII to Binary (and Binary to ASCII)
· Enigma
· Password Unmasker
· Credit Card Number Validate and generate
· Create Local HTTP Server
· eXtreme UDP Flooder
· Web Server Scanner
· Force Reboot
· Webpage Info Seeker
· Bouncer
· Advanced Packet Sniffer
· IRC server creater
· Connection Tester
· Fake Mail Sender
· Bandwidth Monitor
· Remote Desktop Protocol Scanner
· MX Query
· Messenger Packet Sniffer
· API Spy
· DHCP Restart
· File Merger
· E-mail Extractor (crawler / harvester bot)
· Open FTP Scanner
MAB Net Tools се разпространява напълно безплатно, без функционални или времеви ограничения.
Източник: http://www.download.bg/index.php?cls...fault&id=30463
Re: Link: безплатна колекция от мрежови инструменти
Изтеглих го.
Нещо не работи както трябва.
1. Пробвах RDScanner за адреси които със сигурност знам че са "отворени" за RD. Не ги разпозна като такива.
2. Пробвах Port Scanner. По същия начин не намери отворените портове.
3. Със собствения му advanced netstat забелязах, че прави някаква връзка нанякъде отвреме навреме, което хич не ми хареса (не открих троянски кон, но някъде в коментарите по линковете прочетох, че имало такъв)
4. Инсталира някаква калпава версия на WinPcap. Принудих се да си дръпна и инсталирам последната такава, надявайки се, че ще се оправи. Не се оправи.
5. Интерфейса не е никак удобен. поне да бяха по азбучен ред.
Като цяло, прилича на нескопосана работа
Първоначално публикувано от MitkoS
Изтеглих го.
Ами по-богата колекция събрана на едно място досега не съм виждал. Като всяка програма винаги може да не хареса на някой, а за препотъки и забележки има цяла страница contact с автора:
RDScanner и при мен не работи, сигурно и други от комплекта може да не работят коректно но засега е това! :Google:
P.S. Вярно е, че някой от тулсовете са по-стари верси!....но ако определен инструмент те заинтригува можеш да потърсиш повече инфо за него.... :Google:
A Top 100 Network Security Tools могат да се видят тук , като някой са включени в горният комплект!
