Домейн забрана
Здравейте!
Имам един кратък въпрос за администраторите от вас.
Как да направя така, че всеки един от юзерите в даден домейн и в даден момент да НЕ може да се логва на повече от една машина едновременно? :yikes С други думи - ако имаме user1, user2 и user3, да не е възможно user1 да се логне на mashina1 ако в момента е логнат на mashina2.
Благодаря!
Става въпрос за Win 2003 SE SP2.
Re: Домейн забрана
:016:
Ever needed to limit concurrent user logins in an Active Directory® domain? Ever wanted to keep track of information about every login in a domain? If so, LimitLogin is for you.
LimitLogin is an application written by Yossi Saharon, a Partner Technology Specialist with Microsoft in Israel, with help from Ofer Bar, an application development consultant. The application adds the ability to limit concurrent user logins and to keep track of all login information in an Active Directory domain. LimitLogin capabilities include limiting the number of logins per user from any machine in the domain (including Terminal Server sessions), displaying the login information of any user in the domain according to specific criteria, easy management and configuration through integration with the Active Directory Microsoft® Management Console (MMC) snap-in, the ability to delete and log off a user session remotely straight from the Active Directory Users and Computers MMC snap-in, and the ability to generate login information reports in CSV and XML formats.
While the main purpose of LimitLogin is to enforce concurrent login quotas, it can also be used purely as a login data capture solution that lets you manage your Active Directory environment more effectively. You can configure all users in the domain to have an unreachably high login quota and simply let the scripts do the work of updating your login data, without reaching the quota that was set. The UI tools allow you to set the login quota, and you can do so programmatically using the sample script code provided with the tool in Bulk_LimitUserLogins.vbs. You can also scope this script to an Organizational Unit level. The default script runs on all of the user accounts in the domain.
Re: Домейн забрана
Blagodarq!
Nqkoi da ima drugi predlojeniq?
