Резултати от 1 до 2 от общо 2
Ъпдейт на фърмуера на Popcorn Hour А-500
    Dec 2001
    Съжалявам, че темата може да дойде малко безсмилена, но току виж подам идея на някой по-компетентен и с повече време от мен.
    Контекста е, че имам един вехт плеър, от който съм супер доволен, не бих искал да го заменя. Уви, напоследък трябва да съм по-внимателен какво свалям, тъй като плеъра не поддържа DolbyVision и Атмос.
    Та, това е въпроса, който зададох на Перплексити (безплатен LLM, или - както му викат по модереному - AI).
    Hi. I have a PopcornHour A500 media player. Unfortunately the vendor went out of business and its firmware is not being updated anymore. What would I need to do if I want to have the firmware reverse engineered and updated?
    Answer
    To reverse engineer and update the firmware of your PopcornHour A500 media player, you will need to follow a series of technical steps. Here’s a structured approach to guide you through the process:
    Understanding Firmware Reverse Engineering
    Firmware Extraction:
    • Identify the Chipset: First, determine the specific hardware components used in your A500, particularly the CPU and memory chips. This information is crucial as it dictates the tools and methods you'll use for extraction.
    • Accessing Firmware: Depending on the device's architecture, you may need to use a JTAG interface or other debugging tools to read the firmware directly from the memory chip. If the firmware is stored in flash memory, tools like flashrom can be used to read it if the chip is accessible.
    Tools for Analysis:
    • Binwalk: After extracting the firmware binary, use Binwalk to analyze it. This tool helps identify embedded files and structures within firmware images, which can provide insights into how the firmware operates1
    • Disassemblers: Use disassemblers like IDA Pro or Ghidra to convert the binary data into assembly language, which can help you understand the logic and functions of the existing firmware3
    Modifying and Updating Firmware
    Modifying Code:
    • Understand Assembly Language: Familiarize yourself with assembly language for the specific architecture of your device (e.g., ARM, MIPS). This knowledge is essential for interpreting disassembled code and making modifications3
    • Development Environment: Set up a development environment where you can compile and test your modified firmware. You might need cross-compilation tools if your development machine's architecture differs from that of the device.
    Testing Changes:
    • Create a Backup: Always keep a backup of the original firmware before making any changes.
    • Flash Modified Firmware: Once modifications are complete, flash the new firmware back onto the device using appropriate tools (e.g., flashrom or custom scripts for flashing).
    Legal Considerations
    Be aware that reverse engineering firmware may violate terms of service or warranty agreements, depending on local laws and regulations. Ensure that you understand these implications before proceeding.
    Community Resources
    Engage with online communities such as forums dedicated to home theater systems or reverse engineering (e.g., AVS Forum or Reddit) to seek advice and share progress with others who have experience in similar projects4
    6.
    This process requires a solid understanding of electronics and programming, so be prepared for a steep learning curve if you are new to firmware development and reverse engineering.
  3. Member Аватара на Shimbadze
    Sep 2004
    Отговор: Ъпдейт на фърмуера на Popcorn Hour А-500
    Общи приказки е върнал "интелекта".
    Накратко, ако чипът на тоя плейър не поддържа хардуерно Dolby Vision/Atmos,
    няма как да го накараш, хеле пък ако и му е заключен буутлоудърът и разни специфични библиотеки.
    Ако пък поддържаше - някой вече щеше да е изплющял нов фърмуер.
    Та,
    това толкоз си може.
    Купувай новото.
  1. Popcorn Hour A-200
    От kirretto във форум Приключили продажби
    Последно: 02-02-14, 19:03
  2. Popcorn Hour A-300 + 1.5TB HDD
    От popcornhour във форум Приключили продажби
    Отговори: 10
    Последно: 29-09-13, 20:14
  3. Popcorn Hour A-210
    От Svetun във форум Купува
    Последно: 16-02-13, 11:17
  4. Popcorn Hour A-200
    От kirretto във форум Купува
    Последно: 08-01-13, 09:46
  5. Popcorn Hour A-100
    От lazarus18 във форум Продава
    Последно: 04-06-09, 11:42
