Здравейте!
Вчера ми прекараха дигитална ТВ и нет от Евроком. ИЕ 8, обаче не отваря нищо. Слагам стария кабел (Lan) на досегашния доставчик и няма проблеми. Еврокомският нет върви супер с Опера и Мозила, но не и с ИЕ, а аз си искам него. Помагайте!
Здравейте!
Виж дали не ти е настроено някакво прокси на Интернет Експлорера и от там да идва проблема.
Auto reset link (download&run!):
http://go.microsoft.com/?linkid=9646978
Reset manual:
Close any Internet Explorer or Windows Explorer windows that are currently open.
Open Internet Explorer by clicking the Start button , and then clicking Internet Explorer.
Click the Tools button, and then click Internet Options.
Click the Advanced tab, and then click Reset.
Select the Delete personal settings check box if you would like to remove browsing history, search providers, Accelerators, home pages, and InPrivate Filtering data.
In the Reset Internet Explorer Settings dialog box, click Reset.
When Internet Explorer finishes applying default settings, click Close, and then click OK.
Close Internet Explorer.
Your changes will take effect the next time you open Internet Explorer.
Notes
If you close all visible windows, but still get an error message when trying to reset, you might have programs running that are not visible. Restart Windows, open Internet Explorer, and try resetting again.
To back up your home page or home page set before resetting Internet Explorer defaults, see Back up your home page or home page tabs.
If any of the categories fail to reset, it is because Internet Explorer could not access a file or registry setting. This can be caused by insufficient security privileges, files or settings being used by another program, or low memory or high CPU usage. You can either continue to use Internet Explorer without restoring these settings, or restart your computer and try to reset again.
If you are using Internet Explorer on a server and have turned off Enhanced Security Configuration or hardening (stronger security settings for use on servers), reset will go to client level security. You must reinstall hardening if you want the increased security level. For more information on Enhanced Security Configuration, see Enhanced Security Configuration for Internet Explorer online.
To re-enable add-ons, see Internet Explorer add-ons: frequently asked questions.
Was this helpful?What's this?
Ах, само как обичам англопишещите тука!Цитат:
Първоначално публикувано от dash
Ето превод през Гугъл:
Авто възстановите връзката (изтегли & бягай!):
Проучване за употреба:
Затворете Internet Explorer или Windows Explorer прозорци, които са отворени в момента.
Отворете Internet Explorer, като щракнете върху бутона Старт и после щракнете върху Internet Explorer.
Щракнете върху бутона Инструменти, а след това щракнете върху Опции за Интернет.
Щракнете върху раздела Разширени и след това щракнете върху Нулиране.
Изберете Изтрий лични проверите настройките отметка, ако искате да премахнете историята на сърфирането, търсене доставчици, ускорители, начални страници и InPrivate филтриране на данни.
В Reset Internet Explorer диалоговия прозорец Настройки, щракнете върху Възстанови.
Когато Internet Explorer завършва прилагане на настройките по подразбиране, щракнете върху Затвори и след това щракнете върху OK.
Затворете Internet Explorer.
Промените ще влязат в сила от следващия път, когато отворите Internet Explorer.
Отбелязва
Ако затворите всички прозорци видими, но все още получите съобщение за грешка, когато се опитвате да възстановите, може да имате програми, които не са видими. Рестартирайте Windows, отворете Internet Explorer, възстановяване и опитайте отново.
За да архивирате вашата начална страница или на началната страница, определени преди нулирането Internet Explorer по подразбиране, вижте Архивиране на началната страница или разделите началната страница.
Ако някоя от категориите, не успяват да възстановите, то е защото Internet Explorer не може да получите достъп до файла или определяне на системния регистър. Това може да бъде причинено от недостатъчното привилегии за сигурност, файлове или настройки се използва от друга програма, или недостатъчно памет или високо натоварването на процесора. Можете да продължите да използвате Internet Explorer, без да възстанови тези настройки или да рестартирате компютъра си и се опитайте да възстановите отново.
Ако използвате Internet Explorer на сървър и сте изключили Засилено Security Configuration или втвърдяване (силна настройките за сигурност за използване на сървъри и т.н.), ще отида да възстановите сигурност клиент ниво. Вие трябва да преинсталирате закаляване, ако искате увеличеното ниво на сигурност. За повече информация за по-голяма сигурност за конфигурация, вижте по-голяма сигурност за конфигурация за интернет онлайн Explorer.
За да активирате отново добавки, вижте Internet Explorer добавки: често задавани въпроси.
