boot.ini еквивалент в Windows Vista
 Съществува ли boot.ini еквивалент в Windows Vista, който може да се редактира без да работи операционната система, а например с Live CD.
 Става въпрос за Dual OS - Windows 7 и Windows Vista, като Vista-та е основна (тъй като е лицензирана) и трябва да остане в C:/. Windows 7 е в D:/ и идеяата е при един евентуален формат на D:/, да може да се редактира boot menu-то, така че да не остава надписа Windows 7. В XP беше възможно с редактиране на boot.ini в notepad. Уловката е това да стане без да се boot-ва Vista-та.
     Re:boot.ini еквивалент в Windows Vista
  "No, it's changed for Vista.
From Vista Help:
In this version of Windows, the boot.ini file has been replaced with Boot
Configuration Data (BCD). This file is more versatile than boot.ini, and it
can apply to computer platforms that use means other than basic input/output
system (BIOS) to start the computer. If you need to make changes to BCD,
such as removing entries from the list of displayed operating systems, use
the command line tool Bcdedit, an advanced tool intended for administrators
and IT professionals.
If your computer is a multiboot configuration, you can still change which
Windows operating system opens by default, and how long to display the list
of operating systems, by using System in Control Panel.
1. Open System by clicking the Start button , clicking Control Panel,
clicking System and Maintenance, and then clicking System.
2. In the left pane, click Advanced system settings. If you
are prompted for an administrator password or confirmation, type the
password or provide confirmation.
3. Click the Advanced tab, and then, under Startup and
Recovery, click Settings.
4. Under System startup, choose a default operating system and
the amount of time to display the list of operating systems, and then click
OK.
More info about BCDedit at TechNet here:
 http://technet2.microsoft.com/Window....mspx?mfr=true
Full help topic at Windows Help and How-to online at:
 http://windowshelp.microsoft.com/Win...4ae731033.mspx
Andy Sweet
Windows User Assistance team"
  Здрасти,
Благодаря ти, но това го прочетох и не е решение на въпроса. Control panel-а, трябва да бъде редактиран с основната OS, в моя случай Vista-та, а аз искам с другата или с Live CD. Това е и причината умишлено да напиша "заданието" точно такова, след като прерових google естествено :)
