Re: Проблем с Lite-On DVDRW
Първоначално публикувано от Niakoi
Записвачката не знам точно кой модел е. В Device manager пише: ATAPI DVD DW 8X16X8X16X / JO1003V LOD828V SCSI CdRom Device. И някъде четох, че точно това DVD било някакъв Philips, но се продава като Lite-On (или нещо такова :)).
Най-вероятно е BENQ DW1650. Индикации:
- firmware L.01
- модел DVD8801 - на горния капак
- PBSD (Philis BenQ Storage Division) - пак там!
Тогава можеш да го "кросфлашнеш" до BenQ, защото BenQ имат повече версии firmware, които да оправят проблема. Това, ако не се притесняваш, че ще ти отпадне гаранцията.
Все пак, можеш да пуснеш log-a на Неро с грешката тук. :)
Това ще свърши ли работа:
5.9.2007
CD-ROM (ISO)
19:31:52 #1 Text 0 File Isodoc.cpp, Line 6410
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
19:31:52 #2 Text 0 File Burncd.cpp, Line 3007
Seamless Link activated
19:31:52 #3 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 81920KB of Memory
19:31:52 #4 Text 0 File Reader.cpp, Line 124
Reader running
19:31:52 #5 Text 0 File Writer.cpp, Line 113
Writer G: ATAPI DVD DW 8X16X8X16 running
19:31:52 #6 ISO9660GEN -11 File Geniso.cpp, Line 3304
First writeable address = 0 (0x00000000)
19:31:52 #7 Text 0 File Burncd.cpp, Line 3301
Turn on Disc-At-Once, using CD-R/RW media
19:31:53 #8 Text 0 File DlgWaitCD.cpp, Line 277
Last possible write address on media: 359846 ( 79:59.71)
Last address to be written: 268364 ( 59:40.14)
19:31:53 #9 Text 0 File DlgWaitCD.cpp, Line 289
Write in overburning mode: NO (enabled: CD)
19:31:53 #10 Text 0 File DlgWaitCD.cpp, Line 2568
Recorder: ATAPI DVD DW 8X16X8X16
19:31:53 #11 Text 0 File DlgWaitCD.cpp, Line 456
>>> Protocol of DlgWaitCD activities: <<<
19:31:53 #12 Text 0 File ThreadedTransferInterface.cpp, Line 846
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 268365 (268365) = #268365/59:38.15
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 268365 blocks [G: ATAPI DVD DW 8X16X8X16]
19:31:53 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1058
Prepare recorder [G: ATAPI DVD DW 8X16X8X16] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 549918720, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
268365 | lead-out | 1 | 0x41 | 0x00
19:31:53 #14 Text 0 File SCSIPassThrough.cpp, Line 34
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
19:31:53 #15 Phase 24 File dlgbrnst.cpp, Line 1724
Caching of files started
19:31:53 #16 Text 0 File Burncd.cpp, Line 4129
Cache writing successful.
19:31:53 #17 Phase 25 File dlgbrnst.cpp, Line 1724
Caching of files completed
19:31:53 #18 Phase 36 File dlgbrnst.cpp, Line 1724
Burn process started at 24x (3600 KB/s)
19:31:53 #19 SPTI -1189 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1189)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 12 00 00 00 00 30 02
Buffer x04ab5600: Len x4000
19:31:53 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2669
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:31:53 #21 Text 0 File MMC.cpp, Line 16828
StartDAO : CD-Text - Off
19:31:53 #22 Text 0 File MMC.cpp, Line 21541
Set BUFE: Seamless Link -> ON
19:31:53 #23 Text 0 File MMC.cpp, Line 17059
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 3b 28 0f
19:32:11 #24 SPTI -1135 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 22 00 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 12 00 00 00 00 0C
Buffer x04f30000: Len x10000
0xBB 3B BE A1 7E 92 0A 72 54 47 8B FF D8 BE F7 07
0x48 AC 39 76 6B 20 01 7B 79 6C 7B 39 3A 8F 73 F1
0xDF 2E 0C 4F 48 A7 09 CC 86 0D C5 7E 70 75 23 8E
19:32:11 #25 CDR -1135 File Writer.cpp, Line 302
Write error
19:32:11 #26 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
19:32:11 #27 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
19:32:11 #28 Phase 38 File dlgbrnst.cpp, Line 1724
Burn process failed at 24x (3600 KB/s)
Existing drivers:
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 04.8.2004 г. 00:59:42 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
От това, което виждам ме навежда на мисълта, че дисковете не са подходящи за това устройство. Пробвай с други! Историята помни и Verbatim - ментета.
