Продавам : Монито 19 Samsung SyncMaster 940BWр - 130лв.
 http://www.am4computers.com/images/s...0940bwbk_m.jpg
General:
  * Display Type LCD display / TFT active matrix
  * TFT Technology TN
  * Width 17.3 in
  * Depth 7.9 in
  * Height 14.2 in
  * Weight 9.3 lbs
  * Enclosure Color Black
Display:
  * Diagonal Size 19.0 in - Widescreen
  * Viewable Size 19.0 in
  * Dot Pitch / Pixel Pitch 0.285 mm
  * Max Resolution 1440 x 900 / 75.0 Hz
  * Color Support 16.2 million colors
  * Max Sync Rate (V x H) 75.0 Hz x 81.0 KHz
  * Video Bandwidth 135.0 MHz
  * Response Time 4.0 ms
  * Front Panel Controls Power on/off
  * Controls / Adjustments Contrast,
   Brightness,
   Gamma correction,
   Sharpness,
   H/V position
  * Video Output None
  * Signal Input DVI-D, VGA
  * Features MagicBright 2,
   Response Time Accelerator (RTA),
   MagicColor,
   MagicTune
Image:
  * Image Brightness 300.0 cd/m2
  * Image Contrast Ratio 500:1
  * Image Max H-View Angle 160
  * Image Max V-View Angle 160
Video Input:
  * Analog Video Signal RGB
  * Digital Video Standard Digital Visual Interface (DVI)
Audio Output:
  * Type None
Input Device
  * Type None
Expansion / Connectivity
  * Interfaces 1.0 x VGA - 24 pin digital DVI,
   1.0 x DVI-D - 15 pin HD D-Sub (HD-15)
Miscellaneous
  * Cables Included 1.0 x VGA cable - 6.0 ft
  * Flat Panel Mount Interface 75 x 75 mm
  * Features Security lock slot (cable lock sold separately)
  * Microsoft Certifications Certified for Windows Vista
  * Compliant Standards CE,
   DDC-2B,
   Plug and Play,
   TCO '03
Power
  * Form Factor Internal
  * Voltage Required AC 120/230 V
  * Power Consumption Operational 38.0 Watt
  * Power Consumption Stand by / Sleep 1.0 Watt
Software / System Requirements
  * Software type Driver,
   Natural Color,
   MagicTune
Environmental Parameters
  * Operating humidity range 20 - 90%
Sustainability
  * EPA Energy Star Compliant Yes
User manual Тук
В перфектно състояние.
Без изгорели пиксели.
Комплект кабели за видео и захр.
Цена: 130лв.
Куруера за сметка на купувача
Еконт с опция за преглед и тест до 15мин.
За контакти:
Бургас
Email: Alexy@abv.bg
skype: Alexybg
тел: 0884688610
     Re:Продавам : Монито 19 Samsung SyncMaster 940BWр - 130лв.
