Продавам ресивър Marantz SR4320
Ресивърът е в перфектно състояние, в комплект с дистанционно и книжка.
Цена 280 лв. намира се в Бургас, за останалите градове - Еконт с опция "Пробвай преди да платиш".
Тел. 0888/30 20 84
Характеристики:
TECHNICAL SPECIFICATIONS
FM Tuner Section
Frequency Range ................................................ 87.5 –108.0 MHz
Usable Sensitivity ............................................ IHF 2.0 μV/17.3 dBf
Signal to Noise Ratio .................................. Mono/Stereo 70/65 dB
Distortion ..................................................... Mono/Stereo 0.2/0.3%
Stereo Separation ....................................................... 1 kHz 40 dB
A.C.S .................................................................... ±400 kHz 50 dB
Image Rejection ................................................... 98.1 MHz 70 dB
Tuner Output Level ............................ 1 kHz, ±75 kHz Dev 500 mV
AM Tuner Section
Frequency Range ................................................... 520 –1710 kHz
Usable Sensitivity ....................................................... Loop 400 μV
Signal to Noise Ratio ............................................................. 50 dB
Distortion ................................................... 1 kHz, 30% Mod. 1.0%
Selectivity ............................................................... ±10 kHz 40 dB
Audio Section
Rated Power ............................... 40 Hz – 20 kHz 8 ohms 80 W/Ch - 4Ch
40 Hz – 20 kHz 6 ohms 100 W/Ch - 4Ch
THD ................................................ 40 Hz – 20 kHz 8 ohms 0.08%
Input Sensitivity/Impedance
Linear .............................................................. 200 mV/47 kohms
Signal to Noise Ratio (IHF A)
Linear .................................................................................. 95 dB
http://lh5.ggpht.com/_eSrQQ4Dho4c/TM...Q/DPP_0001.JPG
Re:Продавам ресивър Marantz SR4320
Първоначално публикувано от dante68
Оглед на място става ли
Дори без никакви ограничения за начините на изпробване. :)
Продавам ресивър SONY STR-DG700
Ресивъра е в перфектно състояние, в комплект с книжка, дистанционно и оригиналния микрофон за калибриране на тонколоните.
Трябва да е в гаранция още една година, но гаранционната му карта липсва, така че тази опция за съжаление отпада.
Има 5 оптични и 2 коаксиални цифрови аудио входа както и 2 HDMI такива.
Цена - 220 лв. Намира се в Бургас, за останалата част от страната - Еконт с опция "Пробвай преди да платиш".
А това са инструкциите за употреба и технически данни http://pdf.crse.com/manuals/2680065113.pdf
0888/30 20 84
_________________________________________________[color=red]слети поредни публикации на: [time]1329907140[/time]_________________________________________________
Ресивърът SONY е запазен.
_________________________________________________[color=red]слети поредни публикации на: [time]1329921823[/time]_________________________________________________
Ресивър MARANTZ - продаден!
И двата ресивъра са продадени. Моля модераторите да заключат/изтрият темата!
