Продавам Ресийвър Yamaha RX-V595 5.1 Channels Receiver
Усилвателя е в отлично техническо състояние без забележки.Има оригинално дистанционно което може да се ползва като универсално след като се вкара кода на конкретната марка.
Цена 190лв. Ресийвъра се намира в София.
Тел. за контакт 0889/299383
5 Speaker Configuration Main: 70 W + 70 W (8?) RMS Output Power, 0.04% THD, 20 Hz – 20 kHz Center: 70 W (8?) RMS Output Power, 0.04% THD, 20 Hz – 20 kHz Rear: 70 W + 70 W (8?) RMS Output Power, 0.04% THD, 20 Hz – 20 kHz <Australia and China models> Main: 65 W + 65 W (8?) RMS Output Power, 0.04% THD, 20 Hz – 20 kHz Center: 65 W (8?) RMS Output Power, 0.04% THD, 20 Hz – 20 kHz Rear: 65 W + 65 W (8?) RMS Output Power, 0.04% THD, 20 Hz – 20 kHz
? Digital Sound Field Processor
? Dolby Digital Decoder
? Dolby Pro Logic Surround Decoder
? CINEMA DSP: Theater-like Sound Experience by the Combination of Dolby Surround and YAMAHA DSP Technology
SUPPLIED ACCESSORIES
?Information about DSP USING DIGITAL SOUND FIELD PROCESSOR (DSP)
?Advanced Information ADJUSTMENTS IN THE “SET MENU” MODE
?Remote Control Transmitter REMOTE CONTROL TRANSMITTER
? 6-Channel External Decoder Input for DTS and other future formats
? Automatic Input Balance Control for Dolby Pro Logic Surround
? Test Tone Generator for Easier Speaker Balance Adjustment
? Speaker Output Mode Changing Capability
? 40-Station Random Access Preset Tuning
? Automatic Preset Tuning
? Preset Station Shifting Capability (Preset Editing)
? Video Signal Input/Output Capability
? SLEEP Timer
? Universal Remote Control Transmitter with Preset Manufacturer Codes
Продавам и тонколони CERWIN VEGA MX 250
DESCRIPTION: 12" 3-Way Loudspeaker
FREQUENCY RESPONSE: 30 Hz - 20 kHz
POWER HANDLING: 250 Watts RMS
SENSITIVITY: 107 dB (1 Watt @ 1 Meter)
IMPEDANCE: 4 Ohms
LF DRIVER: 12" Die-cast Frame
MF DRIVER: 6" Cone
HF DRIVER: 1" Voice Coil Horn
PROTECTION: Circuit Breaker (Tweeter)
DIMENSIONS: 32" X 14.5" X 14.25" (H X W X D)
WEIGHT: 60 Lbs.
Колоните са в отлично състояние. Намират се в София.
Цена за чифт 500лв.
Тел. за котакт 0889/299383
