Безжична Wifi IP камера FullHD 2.0Mpx
Прикачен файл 16640
Прикачен файл 16641
| Model | YKDM-A111N3 |
| Camera |
| Main CPU | High Performance Ti Davinci Series DSP |
| Image Sensor | 1/2.8 inch Progressive Scan SONY Exmor CMOS Sensor,Low-light Colorful Image quality |
| Effective Pixels | 1920(H)x1080(V) |
| Shutter Speed | 1/25 Seconds~1/10000 Seconds |
| Min.illumination | Color:0.3Lux, B/W:0.01Lux/0Lux(IR On) |
| Optical Lens | 3.6mm(6mm Optional) |
| Angle of View | 51°(6mm lens)/90°(3.6mm lens) |
| Nightvision | Up To 98ft |
| Day/Night | IR Cut(ICR) Auto-switch |
| Video |
| System | Embedded Linux,Built-in Web Server,Remote Setup Enable |
| Compression | H.264 Encoding,Pure Hardware Compression,3D Image Noise Reduction Technology |
| Frame Rate | 2.0MP(1920*1080),1.3MP(1280*960),1.0MP(1280*720)adjustable,1~30FPS Adjustable; 0.1M~6Mpbs Adjustable |
| Main Stream | 1920*1080,1280*720 |
| Sub Stream | 640*360,480*360,480*270,CIF,QVGA,352*192,320*192 etc. |
| Image Function | Auto BLC/WB/GC |
| Application Function | Motion detection,Privacy Masking,Email Alarm,Title OSD,Image flip,Auto relink etc. |
| Remote Function | Setup Menu,Snapshots,Supervisory control etc. |
| Network |
| Ethemet | RJ45 10M/100M Ethernet interface |
| Application | P2P Cloud Service,ADSL,DDNS,UPMP,FTP,SMTP,Email etc. |
| Onvif | 2.0 Version ; Upgrade In Time |
| Remote View | IE Browser,Cloud Service Platform,Smart Phone Apps. |
| Smart Phone | Support iPhone,iPad,Android,Remote monitoring via Apps |
| Protocol | TCP/IP,RTSP/FTP/PPPOE/DHCP/DDNS/NTP/UPNP |
| General Parameters |
| Power Supply | DC 12V/2A |
| PoE Cable | Optional(Without Built-in POE module) |
| Power Consumption | 5~12W(IR on/off) |
| Operating Protection | -10℃~60℃,Humidity 90% or Less(Non-condnsing) |
| Ingress Protection | IP66 |
| Package Dimension | 220*125*115(mm) |
| Package Weight | 700g |
https://www.youtube.com/watch?v=OsI4-TO30cQ
https://www.youtube.com/watch?v=gXwn9nrA_tU
Камерата има един проблем. Или поне аз имам един проблем с нея - Не работи стабилно безжичната връзка, което се изразява в загуба и с рутера ми след 8-12ч. След рестарт на захранването на камерата всичко е ок в следващите 8-12ч. Когато камерата е закачена през RJ45 порта няма никакви проблеми.
Камерата я бях приготвил за наблюдение на задния двор, където извеждаме децата. Но седи от 1-2 месеца на балкона за тестове, а така и не успях да се организирам и да стигна до нея.
Цена 120лв.
София. Може и с Еконт.
скайп: imarh7805
o 888 ЧlЧЧЗЧ но рядко вдигам на непознати номера, така че най-добре тук.
Отговор: Безжична Wifi IP камера FullHD 2.0Mpx
Камерата си струва и цената става 110лв.:081:
Камерата няма да се продава на всяка цена и във всички случаи, ще изчезне в един момент. :081:
Отговор: Детско колело 16 цола
Проблема с камерата е решен(твърдо IP вместо dhcp), така че я свалям от продажба. Остава колелото.
Цената е добра на камерата но не поддържа ONVIF само по RTSP може да е разпознае софтуер а това е проблем за NVR-ите...
ivodivo
A цената беше повече от добра, но народа по форуми, базари и продавалници се присети като я свалих от продажба :cool:
Да не стане пак така и с колелото, макар че там съм по-разговорчив щом става дума за дете.
за това давай UP пред ден два да се види и от тези които влизат малко по рядко...
В колелцето има хляб и даже е оборудвано със светодиоден фар и стоп! А на детето може да му вземето друго със спестените 100лв. за ново колело! :21:
/Възможно ли е темата да се зачисти от модератор, така че да останат само постове свързани с колелото/
Продадено. Да се ползва със здраве.
