Продавам 1080P HD 2.0MP Onvif Network IP Camera 36 IR Nightvision
Камерата е чисто нова, работила е няколко часа за да я тествам. Перфектна картина, богат набор от настройки.
1. Sony IMX 222 sensor
2.HI3516C processing chip. DWDR, BLC
3.2.0 Megapixel 1080P Full HD (1920*1080) resolutions.
4.H.264 video encoding,support dual stream.
5.Mobile surveillance: Android,iPhone OS.
6 Mobile APP(IOS,Android):XMEye
7 Support P2P Cloud:xmeye net
8.Support ONVIF 2.0
https://forum.setcombg.com/attachmen...id=21170&stc=1 https://forum.setcombg.com/attachmen...id=21171&stc=1
СПЕЦИФИКАЦИЯ:
| Camera | Model | IPCX-BC28321080:2.0MP |
| Image Sensor | 1/2.8'' CMOS |
| DWDR, BLC |
| Minimum Illumination | 0.001Lux; 0Lux(IR on) |
| Electronic Shutter | Auto/Manual |
| Lens | 3.6mm standard |
| Day& Night | IR cut filter with auto switch |
| Digital noise reduction | 3D DNR, Anti FOG, BLC, DWDR |
| Synchronization | Internal Synchronization |
Compression
Standard | Video Compression | H.264 |
| Bit Rate | 0.1 Mbps ~ 6 Mbps |
| Dual Stream | Yes |
| Image | Max. Image Resolution | 1920x1080 (1080P) |
| 720p, D1, CIF |
| Frame Rate | 25/30fps |
| Image Settings | Saturation, brightness, contrast,sharpness adjustment |
| Backlight compensation | Auto |
| White Balance | Auto |
| Network | Remote operation | System settings,stream management, account management, network
management |
| Motion detection | Support |
| Protocols | TCP/IP, HTTP, DHCP, DNS, DDNS, RTP, RTSP, PPPoE, SMTP, |
| ICMP, FTP, 802.1X, HTTPS, NTP, UPnP, |
| Network Transmission | P2P penetrate automatic forwarding |
| System Compatibility | ONVIF 2.0 |
| Detection and alarm | Client alarm,E-mail alerm |
| Privacy Masking | Supports four block area block |
| Mobile Monitoring | Support Android,iPhone OS |
| Interface | Communication Interface | 1 RJ45 10M / 100M ethernet interface |
| General | Operating Conditions | -30 °C ~ 55 °C (-22 °F ~ 131 °F) |
| Humidity 10%~90% |
| Power Supply | DC 12V 1A or 2A (Not included) |
| Power Consumption | Max. 8 W |
| Waterproof | No |
| IR Range | 36 pcs LEDs, Up to 20 meters(65.6ft), Depends on the size of lens |
| Connector | RJ45 & 5.5mm DC Plug |
| Camera Weight / Size | 180g / 92*75mm(diameter*high) |
| Packing Weight / Size | 300g / 100×100×92 mm |
Цена - 69 лв.
Местонахождение - Варна - пращам по предпочитан от вас куриер с опция за преглед и тест.
Контакти - тук в темата, на ЛС или скайп patseafox. GSM - след контакт на предните способи.
Камерата е без захранване. Ако Ви е необходимо - предлагам 12V , 2A адаптер - ЦЕНА - 6 лв. - чисто нов.
Отговор: Продавам 1080P HD 2.0MP Onvif Network IP Camera 36 IR Nightvision
