Продавам широкоекранен LCD монитор AL1916Ws (сребрист) в отлично състояние и кондиция. С упътване, кутия и захранващ кабел. Не си спомням дали още не е в гаранция, но ще я потърся. Купих го от "Плесио" преди година и нещо.
Ето параметрите:
Display Size & Type: 19" Wide thin flim transitor Resolution: 1440X900 Panel Technology:TN + film Brightness: 300 cd/m2 Color: 16.7M Contrast Ratio: 700:1 Response Time: 5ms Horizontal Frequency: 24~80KHZ Vertical Frequency: 56~60HZ Horizontal Viewing Angle: 160° Vertical Viewing Angle: 160° Video Signal: Analog (D-sub) Video Support Mode: VGA, SVGA, XGA, SXGA, NEC, Apple and VESA Plug & Play: DDC1 & DDC2B Power Manangement: VESA DPMS On:36W Standby:2W Off:1W (max.) Power Input: Internal AC adaptor 100 - 240 VAC, 50/60 Hz Front Panel Controls: brightness, contrast, picture position, pixel clock frequency, color select and adjust, 5 lanuages reset mode,power on/off sw,power led,function +/-,adjust +/-, Tilt & Base Rotation: Tilt: +5° ~ -25°, Swivel: +45° ~ -45° Weight: Net : 4kgs Dimensions (WXHXD): 462 x 385x 180mm Wallmount (VESA):Supported, 75mm X 75mm Kensington Lock:Supported Certifications: UL, CUL, TUV/GS, T-Mark, ISO9241-3/-7/-8, FCC/B, VCCI, CE, TCO99, TCO 03, C-tick,BSMI,WHQL, ISO 13402-6 Chasis Colour: Silver
Цена: 200 лева
тел. за връзка
GSM: 0888-996-229
Намира се в София.
