Продавам захранване Enermax, модел: EG565AX-VE (G)
Model: EG565AX-VE FMA 2.0
Active PFC: Yes
Maximum Power: 535W (support both 24pins and 20pins motherboards)
Input Voltage: 90V~135V or 90V~265V (auto switch)
Input Frequency Range: 47Hz~63Hz
Input Current: 40A/115V and 80A/230V max. during cold start
Hold up time: 17ms at 115VAC or 230VAC, full load
Over Voltage Protection: +5V: 5.5V~7.0V; +3.3V:3.76V~4.3V; +12V & +12V2: 13.4V~15.6V
Over Load Protection: 110~160% of max load
Over current Protection: +3.3V : 55A (max); +5V: 48A (max); +12V1 & +12V2: 20A (max)
Over Temperature Protection: Operating Ambient 10ºC~40ºC, Storage Ambient -40ºC~70ºC
Humidity:
Operating : to 85% relative humidity, non condensing at 25ºC
Storage: to 95% relative humidity, non condensing at 50ºC
MTBF: Greater than 100K hours at 70% of full rated load; 230VAC / 50Hz input; 25ºC ambient
EMC: EN55022 Class B, EN61000-4-2 Class B, EN61000-4-3 Class A, EN61000-4-4 Class B, EN61000-4-5 Class B, EN61000-4-6 Class A, EN61000-4-8 Class A, EN61000-4-11 Class B, FCC Part 15 & Part 2, CNS 13438 Class B
Safety: Approval UL, cUL, TÜV, CB
Dimension: W150 x H86 x D140 (mm)
За повече информация тук: http://www.enermaxusa.com/catalog/pr...products_id=72
Цена: 80лв. (може разумен коментар)
От София съм.
За контакт: на ЛС или на skype: ohoboho79
7. Коментари по цените не са добре приети в темата - по-добре ги коментирайте с продавача на PM.
