Продавам мрежов диск 1ТB
Продавам диск, състоящ се от кутия Pluscom (чипсет RDC 3282) и твърд диск Samsung Spinpoint F3 1TB SATAII Internal Hard Drive 3.5" 7200 RPM (HD103SJ)
Цена 200лв 0878 272 111.
И двете са като нови - използвани са 2-3 месеца. Харддиска е с гаранция (3години без 3 месеца , а кутията е от чужбина).
Работи самба, торент клиент, фтп, медиа сървър, усб2.0... Всичко тествано и работи стабилно!
Features:
Ethernet & USB2.0 combination interface
Supports 3.5" SATA HDD
Supports FTP and DHCP
UPNP AV: XBOX 360 / PS3 / iTunes
Supports XBOX 360/PS3/iTunes through UPNP AV
DLNA iTunes Media Server Apple
Supports Bit Torrent download
Supports Print Server
Supports SAMBA Server on LAN
USB 2.0 Storage
Throughput: Read ±9MB/s, Write ±10MB/s
Supports sleep mode for HDD
Data transfer is twice as fast as competing models
Compatible with DSL routers/modems
Supports DHCP server, DHCP client or fix IP
Data Transfer rate: Ethernet up to 100Mbps, USB 2.0 up to 480 Mbps
Supports one 10/100Mbps Ethernet port under network environment
Password management provides secure access to HDD and web management
Hot USB available for external enclosure, disk and HUB devices
Drive enclosure made of aluminium alloy good for heat dissipation
Power Activity LED light
USB host can connect to another USB enclosure, easy to expand storage
Software: Web based disk access management software
Supports Plug-play and Hot-plug
Specifications:
Interface: 1X 10/100 Base-TX Auto MDI/MDI-X; 1X USB2.0 Ports
Data transfer Rate: Ethernet up to: 100Mbs; USB2.0 up to: 480Mbs
Suitability: 3.5" SATA HDD I or II
Hot Plug: Supports Plug-play and Hot-plug
Power: AC input: 100 - 240V ~50/60Hz
DC output: 12V/3A,26W
Material: Aluminium - Plastic
