Продавам ISDN телефонна централа Compact 4410 USB удобна за малък офис. 500лв.
С параметри:
Dimensions (w x h x d) 301 mm x 243 mm x 86.5 mm
Operating voltage 230 V; +/-10 %; 50 Hz
Power consumption* 6.8 W min., 25 W max.
Exchange line* up to 2 S0 ports, point-to-multipoint/point-to-point connection (PTMP/PTP, Euro ISDN, DSS-1)
Analog subscriber ports for 10 devices, symmetrical, pulse/tone dialling, CLIP/CNIP capable (FSK)
Range of the analog subscriber ports 2 x 50 Ohm, approx. 790 m at O 0.6 mm;
Internal S0 ports up to 3 S0 ports, point-to-multipoint connection (PTMP, Euro ISDN, DSS-1);
Range of the S0 ports approx. 150 m;
Door intercom ports* 2 ports max., compliant with FTZ 123 D12-0;
Maximum load door opener relay 30 V AC, 1 A max.;
PC connection USB (Full-Speed V1.1, compatible with V2.0);
Module slots 1 slot for COMpact 2S0 Module, 2 slots for COMpact TS Module(s)
Housing plastic, chassis with cover and snap lid;
Weight* approx. 1,500 g (without expansion modules);
Safety CE;
* dependent from the PBX?s expansion configuration
Към централата има ръководство за работа и програмиране, а така също и софтуер за програмиране.
Бонус към централата са 5 телефонни апарата "BELGACOM MAESTRO-350", който са работили с нея.
За контакти тук, на ЛС, или тел. 052387588.
