5 Прикачен файл(ове)
 Продавам Ресивър Сони СТР-ДЕ425 Receiver Sony STR-DE425 5.1 домашно кино
  Ресивъра е в перфектно външно и техническо състояние! Аз съм си го купувал от България и съм първи собственик. Долби съраунд пролоджик 5.1 и RDS на тунера. Върви с всичко към него, дистанционно, кашон, книжка, АМ антена! Европейско производство е!
цената му е 190лв
тел. за връзка 0879887797
ето и малко характеристики:
Amplifier section Power output Stereo mode (DIN 1 kHz, 4 ohms) 90 W + 90 W
Surround (DIN 1 kHz, 4 ohms) mode Front: 90W/ch Centre: 90W (only in PRO LOG IC MODE) REAR: (DIN 1 kHZ, 8ohms) 45 W/ch 5.1/DVD Front: 90 W/ch
INPUT * mode (DIN 1 kHz, 4 ohms) Centre: 90 W (DIN 1 kHz, 4 ohms) Rear: 45 W/ch (DIN 1 kHz, 8 ohms)
Frequency PHONO: RIAA response equalization curve ±0.5 dB TV / LD, CD, TAPE / MD, VIDEO, 5.1/DVD INPUT: 10Hz - 50kHz ±1dB Input Sensitivity Impedance S/N (Weighting network, input level) PHONO 2.5mV 50 74 dB (MM) kilohms 72 dB** (A, 2.5 mV) CD, 5.1/DVD 200 mV INPUT* 50 82 dB TAPE/MD, kilohms 82 dB** TV/LD, 150 mV (A, 150 mV) VIDEO **’78IHF Outputs TAPE/MD REC OUT: Voltage: 150 mV, Impedance: 10 kilohms VIDEO AUDIO OUT: Voltage: 150 mV, Impedance: 10 kilohms WOOFER/MIX AUDIO OUT: Voltage: 2V Impedance: 10 kilohms PHONES: Accepts low and high impedance headphones Muting Full mute BASS BOOST +10dB at 70 Hz TONE ±8dB at 100 Hz and 10 kHz
FM tuner section Tuning range 87.5 – 108.0 MHz Aerial terminals 75 ohms, unbalanced Sensitivity Mono: 18.3 dBf, 2.2μV /75 ohms Stereo: 38.3 dBf, 22.5μV /75 ohms Usable sensitivity 11.2 dBf, 1V /75 ohms (IHF) S/N Mono: 76 dB Stereo: 70dB Harmonic Mono: 0.3 % distortion at Stereo: 0.5 % 1 kHz Separation 45dB at 1 kHz Frequency 30 Hz – 15kHz +0.5 dB response Selectivity 60 dB at 400 kHz –2 — Continued on next page — AM tuner section Tuning range 531 – 1602 kHz Aerial Loop aerial Usable sensitivity 50 dB/m (at 999 kHz) S/N 54 dB(at 50 mV/m) Harmonic 0.5%(50 mV/m, 400Hz) distortion Selectivity 35 dB Video section Input VIDEO 1, 2, TV: 1 Vp-p 75 ohms Output VIDEO 1, 2, MONITOR: 1 Vp-p 75 ohms General System Tuner section; PLL quartz-locked digital synthesizer system Preamplifier section: Low-noise NF type epualizer Power amplifier section: Pure-complimentary SEPP Power 230 V AC, 50/60 Hz requirements Power 230 W consumption AC outlets Switched 100 W (except for the U.K. model)
     Отговор: Продавам Ресивър Сони СТР-ДЕ425 Receiver Sony STR-DE425 5.1 домашно кино
    4 Прикачен файл(ове)
  Продавам тонколони Тонакс 10. Модел Тонакс 10, 4ома 100Вата номинал 150Вата макс, 40Херца-25килохерца. Тонколоните са в перфектно външно и техническо състояние! Вижда се и по снимките. Купени са от Благоевградски завод Високоговорители преди 7-8 години. Свирили са много малко и не са пресилвани. Нищо не е пипано по тях, гарантирам за това! Тонколоните са като нови и смея да твърдя че възпроизвеждат много по-добре музиката от всички китайски боклуци които се продават по маркетите а и струват повече пари на всичкото отгоре от цената която търся аз!
тел. 0889534744
от Любимец
цена 225лв
Линк с характеристиките:
 Tonax 10
    Отговор: Продавам Ресивър Тонколони Тонакс 10 перфектни
  нова цена на тонколоните 215лв
