Резултати от 1 до 3 от общо 3
Продвавам E-mu 0404 24/96 Music Production Digital Audio Sound Card Pci
    Oct 2011
    Lightbulb Продвавам E-mu 0404 24/96 Music Production Digital Audio Sound Card Pci
    Пълен комплект: кабели (brake-out) + дискове (8 бр.) + книжки
    Цена: 65лв.
    София, 0877 22 33 45
    Буксата на SPDIF OUT трябва да се смени ако ще се използва.
    Sample Rates: 44.1, 48, 88.2, 96, 176.4, 192kHz from internal crystal or externally supplied clock (no sample rate conversion)
    Bit Depths: 24-bit I/O, 32-bit processing
    PCI Specification:
    - PCI 2.2 Compliant
    - Form Factor: Universal Keyed, Short PCI Card
    - 3.3V I/O, 5V Tolerant
    - PCI Bus-Mastering DMA subsystem reduces CPU usage
    E-MU E-DSP: 32-bit DSP with 67-bit accumulator (double precision w/ 3 headroom bits)
    Processing: Hardware-accelerated, 32 channel mixing, and multi-effects processing
    Hardware monitoring: Zero-latency direct hardware monitoring w/effects
    Drivers: ASIO2, WDM/MME/DirectSound, and 64-bit Drivers
    Anti-Pop speaker protection: Minimizes noise during power on/off
    Ultra-low jitter clock subsystem: < 1ns in PLL mode (44.1kHz, Opt. S/PDIF Sync)
    Analog Line Inputs (2):
    Type: DC-coupled, low-noise input circuitry
    A/D converter: PCM1804
    OpAmp: NJM2068
    Level: -10dBV nominal, 6dBV max (unbalanced)
    Frequency Response (20Hz-20kHz): +0.20/-.10dB
    Dynamic Range (1kHz, A-weighted): 111dB
    Signal-to-Noise Ratio (A-weighted): 111dB
    THD+N (1kHz at -1dBFS): 100dB (.0001%)
    Stereo Crosstalk (1kHz at -1dBFS): < -120dB
    Analog Line Outputs (2):
    Type: Low-pass, 3-pole low-pass differential filter
    D/A converter: AK4396
    Frequency Response (20Hz - 20kHz): 0.05/-.010dB
    Dynamic Range (1kHz, A-weighted): 116dB
    Signal-to-Noise Ratio (A-weighted): 116dB
    THD+N (1kHz at -1dBFS): -100dB (.0001%)
    Stereo Crosstalk (1kHz at -1dBFS): < -109dB
    Digital I/O:
    S/PDIF:
    - 2 in/2 out optical or coaxial (transformer coupled)
    - AES/EBU or S/PDIF format (software selectable)
    MIDI:
    - 1 in, 1 out
    Synchronization:
    Internal crystal sync: 44.1, 48, 88.2, 96, 176.4, 192kHz
    External sample rate sync: - S/PDIF (opt. or coax 44.1 - 96kHz)
    SMPTE/LTC/MTC (via optional Sync Daughtercard):
    - 24, 25, 30 drop-frame, 30 non-drop
    - SMPTE to MTC, MTC to SMPTE Conversion
    - SMPTE Striping
    - Flywheel/Jam/Regenerate
    Oct 2011
    Отговор: Продвавам E-mu 0404 24/96 Music Production Digital Audio Sound Card Pci
    Нова цена: 55лв
    Oct 2011
    продадено!
  1. Продавам KEF Coda III, SB X-Fi Xtreme Music и USB Audio DAC
    От Creep във форум Приключили продажби
    Отговори: 12
    Последно: 24-07-12, 21:39
  2. 5.1 CH Dolby Digital DTS AC3 Sound Audio Decoder
    От lasho във форум Аудиотехника
    Последно: 15-12-11, 17:15
  3. HDV-18A 5.1 Digital Audio Decoder Dolby Digital DTS AC3
    От martosblack във форум Аудиотехника
    Отговори: 18
    Последно: 11-12-10, 14:02
  4. Sound Card
    От DENITO във форум Общ - софтуер
    Отговори: 13
    Последно: 11-09-07, 10:15
  5. Multi media card или Secure digital card
    От Big Bug във форум Общ - хардуер
    Последно: 24-06-03, 19:50
