Performans насройки на BIOS!
  Fast Gate A20 Option    : ENABLED
Video BIOS shadowing    : DISABLED
Video BIOS cacheable    : DISABLED
xxxxx - xxxxx Shadow    : ALL DISABLED
IDE prefetch mode      : ENABLED
Init Display First     : AGP or PCI (SELECT YOUR CARD TYPE)
IDE HDD Block Mode     : ENABLED
IDE 32-bit transfer mode  : ENABLED
Assign IRQ for USB     : DISABLED (UNLESS YOU USE USB DEVICES)
Assign IRQ for VGA     : ENABLED
PCI/VGA palette snoop    : DISABLED
PNP OS Installed      : ENABLED (WINDOWS XP CAN HANDLE PNP BETTER THAN BIOS)
Resource Controlled By   : AUTO (UNLESS YOU WANT TO MANUALLY ASSIGN IRQs AND DMAs)
AGP aperture size      : 256 (USE LOWER VALUE IF YOU HAVE TEXTURE PROBLEMS)
AGP master 1 WS write    : DISABLED ***
AGP master 1 WS read    : DISABLED***
Bank 0/1, 2/3 DRAM timing  : TURBO ***
CPU to PCI write buffer   : ENABLED
Delayed Transaction     : DISABLED ****
DRAM speculative leadoff  : ENABLED ***
DRAM Data Integrity Mode  : NON-ECC (UNLESS YOU HAVE ECC MEMORY)
Delay DRAM read latch    : (THE LOWER, THE FASTER) ***
Fast Writes         : DISABLED (ENABLED FOR RADEON 9600 OR ATHLON64 SYSTEMS)
Memory parity/ECC check   : DISABLED ***
Passive Release       : DISABLED
PCI Concurrency       : ENABLED
PCI master 0 WS write    : ENABLED ***
RAS active time       : (THE LOWER, THE FASTER) ***
RAS to CAS delay      : (THE LOWER, THE FASTER) **
Read around write      : ENABLED
SDRAM Bank Interleave    : 4-bank/way
SDRAM CAS Latency Time   : 2 **
SDRAM cycle length     : 2 **
SDRAM Precharge control   : ENABLED
Spread spectrum (modulation): DISABLED
System BIOS cacheable    : DISABLED
Video RAM cacheable     : DISABLED
8 bit I/O Recovery Time   : 1
16 bit I/O Recovery Time  : 1
Turbo frequency       : ENABLED
Това е тук , благодарение на " http://www.omegadrivers.net/mb_bios.php"
