Lacinema Classic HD Firmware downgrade
   :016: Имам проблем с firmware downgrade на Lacinema Classic HD, след ъпдейт на FW 3.22 to 3.25 (latest), wi-fi dongle (Netgear N) не може да се разпознае повече, работело е добре с 3.22, в ъпдейт на фърмуера има 3 файла:
imp555.bin
imp555.fff
imp555.ver - txt file
Ako някой знае нещо повече по въпроса да помага :) - Благодаря предварително ...
     Re:Lacinema Classic HD Firmware downgrade
  Downgrade Instructions:
Download HexEditor:
 http://mh-nexus.de/en/downloads.php?product=HxD
Open imp555.ver with Notepad=>Change version (example 3.22 downgrade from 3.25 current) from 3.22 to higher than current (3.25) (used 3.27 in example)=>Save file
Run HexEditor and Open imp555.fff=> Find version (3.22) and Modify to 3.27 (higher than current 3.25)=>Save file
Load all 3 files on empty fat32 formated flash drive=> plug into lacinema hd back USB port=> allow system to load=>Follow step to Update (Downgrade in our case)after new firmware Update is recognized
