Има ли simbian приложение антирадар??????
Най-вероятно работи само с по-стари телефони, т.е. без цветен дисплей. Не можах да разбера от поста на Ghost какво е това "zkanka", но най-вероятно и той има предвид символа който излиза пред 5-те нули.
<font color="maroon">"zkanka" = знака</font id="maroon">
//edit
ок, не съм се сетил че може да е това.[Oops!][8D][:D]
LOL
De da znam kvo sum iskal da napisha tolkoz rano. Predpolagam "znaka" ili "ikonka" hahahahaha....
Parviat mi telephoen beshe BOSH i imashe razni hitrinki.
Izprobvah ukazaniata po-gore varhu nokia s achromatichen display, poiavi se za kratko znakche i nadpische ... i se varna kam normalno sastoianie.
Niakoi ima li predstva dali raboti?!
spored edin priatel
"znaka e za closed user group - vse edno familya ili firma..." t.e. ne e antiradar
ta otnovo pitam niakoi izprobval li e dali raboti ?!
`Your Nokia cell phone can be programmed to pick up radar speed traps, when programmed your cell phone picks up the radar and alerts you on the message alert tone.
1. Enter your menu
2. Select settings
3. Select security settings
4. Select closed user group
5. Select on
6. Enter 00000
7. Press ok
8. Clear back to normal, within a few seconds your phone will display a radar sign with five zero's next to it. It is now activated.
Unfortunately only Nokia phones have this function. Cell info display needs to be de-activated. Settings -> Phone Settings -> Cell Info display
Each time you turn off your phone, or even each time you loose contact with your carrier, you#180;ll have to activate it again... It is done by steps 1 through 5, but the number (00000) will be already on the field as default. If you put the number 500 in the closed user group, and you go out of a store with detection ports thy will go off.
Firmware version:
*#0000#
*#51x0# or
*#9999#
View Serial No., Date Made, Programming Date, Repaired:
*#92772689#
Thanks to Ben-Dov for this code
IMEI (International Mobile Equipment Identity) Code:
*#06#
Enhanced Full Rate (EFR):
*3370# to activate EFR. Makes calls sound better, but decreases battery life by about 5%.
#3370# to deactivate EFR
Half Rate Mode (HFR):
*4720# to activate HFR. Decreases call quality but increases battery life by about 30%.
#4270# to deactivate HFR.
Default Security Code:
12345
Warranty Code:
*#92702689# [*#war0anty#] asks warranty code. You can then type a number of codes (Thanks to Mike Pfaff for these codes):
6232 - Display date of manufacture
7332 - Display date of last repair
7832 - Display purchasing date
9268 - Display serial number
37832 - Set purchasing date to MMYY
87267 - Confirm Transfer, Related to firmware upgrades
#746025625# says SIM CLOCK STOP ALLOWED or similar, depending on your SIM card. Newer SIMs have a feature called 'clock stopping' that allows the phone to save energy -- it is a kind of sleep mode for SIM cards. Not all versions of software support this. You cannot turn the SIM clock on and off, the phone will do it automatically if the SIM supports clock stopping.
На 3310 нищо не става.
Когато антирадара на колата се къса да пищи - телефона си спи кротко и не реагира [:D]
Повече от ясно е, че няма да стане! Нашите радари работят на
10,525MHz (XBand) в пулсов режим - това си ни е наследство от
около 40! [:)] години. Вероятността това да заработи на вашият
телефон клони към 0% [;)] Най-много да засечете къде наблизо
има автоматични врати (те работят на честотата на американските
радари). [:P]
