| characteristic | LG Display
2022 | Samsung Display
2022 | LG Display
2023 | Samsung Display
2023 |
| Aplication Detail |
| Type display | AMOLED 2.0
(EX Technology)
Bottom Emission (BE-OLED) Deuterium Blue
Personalized Algothms | QD-OLED 1.0
Top Emission (TE-OLED) Intellisense AI (v1.0) | AMOLED 3.0
(EX+META Technology)
Bottom Emission (BE-OLED) “Micro Lens Array” (MLA)
“META Booster”, a brightness-enhancing algorithm | QD-OLED 2.0
Top Emission (TE-OLED) Hyper efficiency EL / Deuterium Blue
Intellisense AI(v.2.0) |
| Color Filter | Conventional Color Filter
Red, Green, Blue, White | Low-pass blue Color Filter QD emissive layer (6-7nm Red) QD emissive layer (2-3nm Green) Transmissive light diffuser (Blue)
[inkjet deposition] | Conventional Color Filter
| Emitter Stack | Blue (FL-OLED) Red (FL-OLED) Yellow/Green (FL-OLED) Green (FL-OLED) Blue (FL-OLED) | Green EML(PH-OLED) Blue EML(FL-OLED) Blue EML(FL-OLED)
Blue EML(FL-OLED) | Blue EML(FL-OLED) Red EML(FL-OLED) Yellow/Green (FL-OLED) Green (FL-OLED) Blue (FL-OLED) | Green (PH-OLED) Blue (FL-OLED) Blue (FL-OLED)
Blue (FL-OLED) |
| TFT | IGZO | - ? - | IGZO | - ? - |
Spectral Power Distribution
Wavelight λ [nm] | blue - 456
green - 550
red - 625 | blue - 452
green - 532
red - 640 | blue -
green -
red - | blue -
green -
red - |
| Diagonal Size | 42, 48, 55, 65, 77, 88, 97 | 55, 65 | 42, 48, 55, 65, 77, 97 | 55, 65, 77 |
| Operating Temp. | 0 ~ 45 °C | - ~ - °C | 0 ~ 45 °C | - ~ - °C |
| Panel Lifetime | LT97 = 18.000 h
LT95 = 30.000 h
LT90 = 60.000 h
LT80 = 120.000 h
LT70 = 180.000 h
LT60 = 240.000 h
LT50 = 200.000 h | LT97 = ? h
LT95 = ? h
LT90 = ? h
LT80 = ? h
LT70 = ? h
LT60 = ? h
LT50 = ? h | LT97 = ? h
LT95 = ? h
LT90 = ? h
LT80 = ? h
LT70 = ? h
LT60 = ? h
LT95 = ? h
LT90 = ? h
LT80 = ? h
LT70 = ? h
LT60 = ? h
LT50 = ? h |
| Frequency | 48-120 Hz | 48-144 Hz | 48-120 Hz | 48-144 Hz |
| Mechanical Details |
| Pixel Features |
| Resolution | 3840(RGBW)×2160, UHD | 3840(RGB)×2160, UHD | 3840(RGBW)×2160, UHD | 3840(RGB)×2160, UHD |
| Panel Architecture | Bottom emission (3S4C) | Top emission (4S2C) | Bottom emission (?) | Top emission (4S2C) |
| Pixel Format | RGB Vertical Stripe | RGB Triangle | RGB Vertical Stripe | RGB Triangle |
| Subpixel type | WRGB (b/r+y+g/b OLED - r/g/b CF) | RGB (b+b+b/g OLED - r/g QDCC) | WRGB (? OLED - r/g/b CF) | RGB (? OLED- r/g QDCC) |
| Treatment | Antiglare (Haze 1%)
Hard coating (2H)
Reflection 1.0-1.2% (Max.) | Antiglare (?)
Reflection ? (Max.) | Antiglare (?)
| Optical Details |
| Basic Information |
Luminance | 150 cd/m² (Typ.), HDR1000 | -- cd/m² | -- cd/m² | -- cd/m² |
D65
1%
3%
5%
10%
25%
50%
75%
100% | -
980 cd/m²
1000 cd/m²
1000 cd/m²
980 cd/m²
650 cd/m²
350 cd/m²
2xx cd/m²
160 cd/m² | -
1400 cd/m²
1400 cd/m²
1300 cd/m²
1000 cd/m²
800 cd/m²
580 cd/m²
250 cd/m²
200 cd/m² | -
- cd/m²
~15xx cd/m²
- cd/m²
1514.5 cd/m²
- cd/m²
- cd/m²
- cd/m²
209.8 cd/m² | -
- cd/m²
- cd/m²
- cd/m²
1313 cd/m²
- cd/m²
- cd/m²
- cd/m²
249.5 cd/m² |
Viewing Angle
Luminance maintenance L60°/L0°
Color Shift WAD Δ u'v' @ 60° | 60/60/60/60 (Min.)
53%
0.020 | --/--/--/-- (Min.)
81%
0.012 | 80/80/80/80 (Min.)
0.0? | --/--/--/-- (Min.)
0.006 |
| Contrast | 150000:1 (Typ.) (Transmissive) | -- | -- | -- |
| Response time | 0.1ms(Typ.)(G to G); 0.8 (Typ.)(MPRT) | 0.1ms (Typ.)(G to G); 8 (Typ.)(MPRT) | 0.1ms(Typ.)(G to G); 0.8 (Typ.)(MPRT) | 0.1ms (Typ.)(G to G); 0.8(Typ.)(MPRT) |
| Color Performance |
Native Color
temperature | 9966K | 9---K | 9966K | 9558K |
| Display colors | 1.07B (10-bit)
1.07B (8-bit + Dithering) | 1.07B (10-bit)
? | 1.07B (10-bit)
| White Coordinate | X:0.281; Y:0.288 | -- | -- | X:0.2841: Y:2895 |
| 1931 Color Gammut |
| NTSC ratio | 96% | --% | --% | --% |
| Adobe RGB | 90% coverage | --% | --% | --% |
| Rec.2020 | 72% coverage | 90.8% coverage | 75.48% | -- % coverage |
| DCI-P3 | 97% coverage | 99.8% coverage | 99.18% | -- % coverage |
| sRGB | 100% coverage | 100% coverage | 100% coverage | --% coverage |
| 1931 Color Volume |
| DCI-P3 @ CIELAB | 80% | 123% | --% | --% |
| Rec.2020 @ CIELAB | 52% | 80% | --% | --% |
| White Variation | 1.25/1.43 (Typ./Max.)(9 points) | -- | -- | -- |
| Black depth | <0.0001 cd/m² | <0.0005 cd/m² | <0.0-- cd/m² | <0.0-- cd/m² |
