Искам да попитам, за 6 такива колони, какъв усилвател да си купя?
2x6'' 100V Installation Speaker System
Frequency Response (-10dB) 62 - 20000 Hz
Sensitivity 1W/1m 94 dB
Max. SPL / 1m (calc) 122 dB
Coverage (nominal -6dB) H° 100 °
Include Mounting Bracket Kit
Coverage (nominal -6dB) V° 80 °
Nominal impedance 8 ohms
Color Black
Input Connections Spring Terminal
Outdoor
Chassis Size 6 inches
Speaker Type Fullrange, Mid-High, Two-Way
Weight Net 5.3 kg ( 11.68 lbs )
Dimensions 419 x 228 x 298 mm
(16.5" x 8.98" x 11.73")
Transformer Taps (Transformer Version Only) 70V/100V:15W, 30W, 60W, 8 ohm Bypass
