Резултати от 1 до 9 от общо 9
java script menu
    Oct 2005
    java script menu
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
    <html>
    <body>
    <head>
    <title>Untitled</title>
    <SCRIPT language="JavaScript1.4" type="text/javascript">
    function PlaySound(strFileName)
    var soundfile = eval("document." + strFileName);
    try
    soundfile.Play();
    catch (e)
    soundfile.DoPlay();
    </SCRIPT>
    <SCRIPT language="JavaScript">
    function SwapImage()
    var doc=document, args=arguments;
    doc.$imgSwaps = new Array();
    for(var i=2; i<args.length; i+=2)
    var elem=FindObject(args);
    if(elem)
    doc.$imgSwaps[doc.$imgSwaps.length]=elem;
    elem.$src=elem.src;
    elem.src=args[i+1];
    function FindObject(id, doc)
    var child, elem;
    if(!doc)
    doc=document;
    if(doc.getElementById)
    elem=doc.getElementById(id);
    else
    if(doc.layers)
    child=doc.layers;
    else
    if(doc.all)
    elem=doc.all[id];
    if(elem)
    return elem;
    if(doc.id==id || doc.name==id)
    return doc;
    if(doc.childNodes)
    child=doc.childNodes;
    if(child)
    for(var i=0; i<child.length; i++)
    elem=FindObject(id,child);
    if(elem)
    return elem;
    var frm=doc.forms;
    if(frm)
    for(var i=0; i<frm.length; i++)
    var elems=frm.elements;
    for(var j=0; j<elems.length; j++)
    elem=FindObject(id,elems);
    if(elem) return elem;
    return null;
    </SCRIPT>
    </HEAD>
    <BODY bgcolor="#FFFFFF" text="#000000">
    <TABLE>
    <TR>
    <TD align="left" valign="top" width="100" height="23"><A href="http://" target="_parent"><IMG id="img00010" src="file:///C|/Programme/aaa/navbar/button14.gif" alt="http://" valign="top" border="0" width="100" height="23" onmouseover="SwapImage(1,0,'img00010','img00010_over.bmp');PlaySound('3.wav')" onmouseout="SwapImage(0,0,'img00010','img00010.bmp')"></A></TD>
    <TD width="4"></TD><TD align="left" valign="top" width="100" height="23"><A href="http://" target="_parent"><IMG id="img00011" src="file:///C|/Programme/aaa/navbar/button14.gif" alt="http://" valign="top" border="0" width="100" height="23" onmouseover="SwapImage(1,0,'img00011','img00011_over.bmp');PlaySound('3.wav')" onmouseout="SwapImage(0,0,'img00011','img00011.bmp')"></A></TD>
    <TD width="4"></TD><TD align="left" valign="top" width="100" height="23"><A href="http://" target="_parent"><IMG id="img00012" src="file:///C|/Programme/aaa/navbar/button14.gif" alt="http://" valign="top" border="0" width="100" height="23" onmouseover="SwapImage(1,0,'img00012','img00012_over.bmp');PlaySound('3.wav')" onmouseout="SwapImage(0,0,'img00012','img00012.bmp')"></A></TD>
    <TD width="4"></TD><TD align="left" valign="top" width="100" height="23"><A href="http://" target="_parent"><IMG id="img00013" src="file:///C|/Programme/aaa/navbar/button14.gif" alt="http://" valign="top" border="0" width="100" height="23" onmouseover="SwapImage(1,0,'img00013','img00013_over.bmp');PlaySound('3.wav')" onmouseout="SwapImage(0,0,'img00013','img00013.bmp')"></A></TD>
    <TD width="4"></TD><TD align="left" valign="top" width="100" height="23"><A href="http://" target="_parent"><IMG id="img00014" src="file:///C|/Programme/aaa/navbar/button14.gif" alt="http://" valign="top" border="0" width="100" height="23" onmouseover="SwapImage(1,0,'img00014','img00014_over.bmp');PlaySound('3.wav')" onmouseout="SwapImage(0,0,'img00014','img00014.bmp')"></A></TD>
    <TD width="4"></TD><TD align="left" valign="top" width="100" height="23"><A href="http://" target="_parent"><IMG id="img00015" src="file:///C|/Programme/aaa/navbar/button14.gif" alt="http://" valign="top" border="0" width="100" height="23" onmouseover="SwapImage(1,0,'img00015','img00015_over.bmp');PlaySound('3.wav')" onmouseout="SwapImage(0,0,'img00015','img00015.bmp')"></A></TD>
    </TR>
    </TABLE>
    </DIV>
    </BODY>
    </html>
    Някаде в този скрипт е оказан пътя към файла : 3.wav* *самоче каде ?* искам да си го направя при mouseOver да издава звук и картинката на менюто да се сменя
    Dec 2003
    Re: java script menu
    Цитат Първоначално публикувано от connect
    try
    soundfile.Play();
    catch (e)
    soundfile.DoPlay();
    </SCRIPT>
    Някаде в този скрипт е оказан пътя към файла : 3.wav самоче каде ?
    Aми пробвай да заместиш червените в цитата по-горе с 3.wav
    Само че за това в синьо не съм много сигурен дали е наред или трябва да се замести с нещо друго...
    Промяна: ...и никак не би било зле да махнеш тия двете неща в лилаво, щото иначе надали ще ти тръгне скрипта.
  4. Senior Member Аватара на Bibi
    Nov 2004
    Да, ама не в описанието, а там, където я вика:
    onmouseover="SwapImage(1,0,'img00012','img00012_over.bmp');PlaySound('navsound2')"
    "Синьото нещо" е един глобален обект, който си е добре, не се сменя той.
    А и "лилавото" нека си седи. То не пречи!
    Слага се, за да не се побъркват старите браузери...
    Oct 2005
    Пак ми дава грешка ... незнам дали не трябва да се окаже пътя до файла ,ама там откадето го взех не беше оказан...
    а за смяна на картинката неще да я сменя при mouseOver ,някои ако има подобен скрипт ако може да ми го даде, този нещо не работи както трябва.Можеби проблема ,е че го взех от един генератор и го сложих в друг... самоче не ми е ясно кое точно трябва да се промени за да работи...
  6. Senior Member Аватара на Bibi
    Nov 2004
    А каква грешка дава?
    И защо нямаш отварящия таг за таблица, а за компенсация два пъти затваряш "body"?
    Нещо не си копирал както трябва, така мисля.
    Защото май това document.navsound2 никъде не си го дефинирал за сега?
    Виж, почети някакви обяснения:
    http://www.google.com/search?hl=en&q...=Google+Search
    //ДОБАВЕНО
    ...сега е по-добре поне като синтаксис...
    Но все пак потърси в мястото, от което копираш, всички места, на които се среща navsound2.
    За смяната на картинката:
    Някъде имаш едни ей-такива
    onmouseover="SwapImage(1,0,'img00010','img00010_over.bmp')" onmouseout="SwapImage(0,0,'img00010','img00010.bmp')"
    Първото би трябвало да е името на картинката, която се показва при доближаване с мишката, а второто - името на алтернативната.
    Aug 2005
    огледай се от мястото от където копираш дали няма някаде оказани допалнителни .js файлове да се "инклудват". трябва и тях да добавиш...
    Oct 2005
    Редактирах си първия пост с новия вече редактиран скрипт ... самоче грешката си остава когато мишката мине върху менюто и ми изкарва грешка: ред:13
    * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * ред:4
    * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * очакване: ';'
    * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * код:0
    * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * превод от Немски незнам до колко е сполучлив
    Незнам за document.navsound2 по прицип всичко го взех от генератора,когато му дам preview и си прави менюто и си работи ... самоче когато го премествам в другия генератор почват грешките
    относно .js файлс нито един не намерих
  10. Senior Member Аватара на Bibi
    Nov 2004
    Защо не оставиш само един бутон в началото, докато тестваш?
    Останалите можеш да ги изкоментираш временно.
    Пробвай да добавиш ; накрая на първото:
    onmouseover="...PlaySound(...);"
    Oct 2005
    Проблема според мен идва от това ,че втория генератор в който местя скрипта не може да намери картинките за менюто и sound ... самоче незнам как да му ги покажа пробвах с image src=<> , пробвах и това което казахте без напредък ... само като махна play sound грешката изчезва... както и звука при картинката успях да го накарам да покаже първоначалната но като направя mouseOver изчезва и не се връща и при mouseOut
  1. CD Menu
    От LZ4 във форум Общ - софтуер
    Последно: 05-03-08, 23:48
  2. Java Script Drop Down меню
    От CreatoR във форум Уебдизайн и 3D
    Последно: 01-12-06, 14:31
  3. XP-boot menu
    От xas във форум Windows
    Последно: 28-06-03, 00:20
  4. Kak da si sloja menu na bul
    От simbata във форум Смартфони, телефони
    Последно: 07-06-03, 23:06
  5. tree menu
    От devil във форум Уебдизайн и 3D
    Последно: 07-06-02, 17:53
