Sony камери и фотоапарати / FAQ -на първа страница, обсъждания, мнения
Как да разчитаме модела - например HDR-PJ260VE
HDR - hi definition recorder
PJ - серия с вграден проектор
- CX - серия без вграден проектор
260 - модел
V - означава че има GPS ?
E - регионално прадназначение - Европа
http://www.sony.bg/hub/fotoaparati-videokameri
http://www.sonycreativesoftware.com/...trials/photogo
Sony handycam 2012 |
МОДЕЛ
················································ | HDR-CX190E
························· | HDR-CX210E
························· | HDR-PJ200E
························ | HDR-CX260E
························· | HDR-PJ260VE
··························· | HDR-CX570E
························ | HDR-PJ580VE
················· | HDR-CX730E
·················· | HDR-PJ740VE
·················· | HDR-TD20E
| Exmor R CMOS сензор | Да | Да | Да | Да | Да | Да | Да | Да | Да | Да |
Резолюция
снимки/видео | 5.3M / 1.2M | 5.3M / 1.2M | 5.3M / 1.2M | 8.9M / 2.2M | 8.9M / 2.2M | 20.4M / 5M | 20.4M / 5M | 24.1M / 6.1M | 24.1M / 6.1M | 20.4M / 5M(x2) |
| Обектив | Zeiss | Zeiss | Zeiss | G wide angle 29.8mm | G wide angle 29.8mm | G wide angle 26.8mm | G wide angle 26.8mm | Zeiss | Zeiss | G wide angle 29.8mm |
| Оптично/разширено приближение | 25x / 30x | 25x / 30x | 25x / 30x | 30x / 55x | 30x / 55x | 12x / 20x | 12x / 20x | 10x / 17x | 10x / 17x | 10x / 17x
само 2D |
| Стабилизация по изображението | Steady Shot Active | Steady Shot Active | Steady Shot Active | Optical Steady Shot Active | Optical Steady Shot Active | Optical Steady Shot Active | Optical Steady Shot Active | Balanced Optical Steady Shot | Balanced Optical Steady Shot | Optical Steady Shot Active |
Вграден прожектор
яркост в лумени | - | - | Да / 10 lux | - | Да / 13 lux | - | Да / 13 lux | - | Да / 20 lux | - |
| Размер на прожектираното изображение | - | - | 60"(152cm) | - | >60"(152cm) | - | >60"(152cm) | - | 100"(254cm) | - |
Вградена памет
време за запис | - | 8GB / 2.5h
AVCHD(LP) | - | 16GB / 6h
AVCHD(LP) | 16GB / 6h
AVCHD(LP) | - | 32GB / 10h
AVCHD(LP) | 164B / 5h
3D MVC 28M |
| Аудио запис | Аuto Wind noise reduction
DD 2.0ch | Аuto Wind noise reduction
Clear voice
Clear voice
DD 5.1ch | Аuto Wind noise reduction
Clear voice
Clear voice
Clear voice
Clear voice
Clear voice
DD 5.1ch |
| Вграден USB кабел | Да | Да | Да | Да | Да | Да | Да | Да | Да | Да |
| Включени аксесоари |
| Батерия NPFV | 30 | 30 | 30 | 50 | 50 | 50 | 50 | 70 | 70 | 70 |
| HDMI кабел | - | Да | Да | Да | Да | Да | Да | Да | Да | Да |
| Дистанционно | - | - | - | - | Да | - | Да | Да | Да | Да |
Sony compact camera 2012 |
МОДЕЛ
················································ | S5000
························· | W610
························· | W620
························ | W630
························· | W690
··························· | WX50
···················· | WX100
··················· | TX20
···················· | H90
·················· | HX10V
···················· | HX20V
···················· | HX200V
| Сензор | Super HAD CCD | Super HAD CCD | Super HAD CCD | Super HAD CCD | Super HAD CCD | Exmor R
CMOS sensor | Exmor R
CMOS sensor | Super HAD CCD | Exmor R
CMOS sensor |
| Брой ефективни пиксели | 14.1 M | 14.1 M | 14.1 M | 16.1 M | 16.1 M | 16.1 M | 18.2 M | 16.2 M | 16.1 M | 18.2 M | 18.2 M | 18.2 M |
| Широкоъгълен обектив | 28 mm | 26 mm | 28 mm | 25 mm | 25 mm | 25 mm | 25 mm | 25 mm | 24 mm | 24 mm | 25 mm | 27 mm |
| Оптично приближение | 5x | 4x | 5x | 5x | 10x | 5x | 10x | 4x | 16x | 16x | 20x | 30x |
Разширено приближение
(при пълна резолюция) | | | | | | 10x | 200x | 8x | | 32x | 40x | 60x |
| Обектив | Sony | Sony | Sony | Carl Zeiss | G | Carl Zeiss | G | Carl Zeiss | G | G | G | Carl Zeiss |
| Размер на LCD дисплея | 2.7" / 6.7" | 2.7" / 6.7" | 2.7" / 6.7" | 2.7" / 6.7" | 3" / 7.5" | 2.7" / 6.7" | 2.7" / 6.7" | 3" / 7.5" | 3" / 7.5" | 3" / 7.5" | 3" / 7.5" | 3" / 7.5" |
| Резолюция на LCD дисплея | 230k | 230k | 230k | 230k | 230k | 460k | 460k | 921k | 460k | 921k | 921k | 921k |
| Стабилизация на изображението | Електронна | Електронна | Електронна | Оптична | Оптична | Оптична | Оптична | Оптична | Оптична | Оптична | Оптична | Оптична |
| Интелигентно разпознаване на сцени и лица | Да | Да | Да | Да | Да | Да | Да | Да | Да | Да | Да | Да |
| Режим Superior Auto | | | | | | Да | Да | Да | | Да | Да | Да |
| 10 кадъра в сек. с пълна резолюция | | | | | | Да | Да | Да | | Да | Да | Да |
| Дефокус на задният план | | | | | | Да | Да | Да | | Да | Да | Да |
| Снимки от ръка в здрач | | | | | | Да | Да | Да | | Да | Да | Да |
| Корекция на фоновата сметлина HDR | | | | | | Да | Да | Да | | Да | Да | Да |
| Екстра висока чувствителност | | | | | | Да | Да | | | Да | Да | Да |
| Бърз АФ при слаба светлина | | | | | | | Да | | | Да | Да | Да |
| GPS / Компас | | | | | | | | | | Да | Да | Да |
| Цифров хоризонт | | | | | | | | | | | Да | Да |
| Формат на видео запис | VGA | VGA | 720p HD | 720p HD | 720p HD | Full HD
1080 50i | Full HD
1080 50i | Full HD
1080 50i | 720p HD | Full HD
1080 50i | Full HD
1080 50p | Full HD
1080 50p |
| Оптична стабилизация с Активен режим | | | | | Да | Да | Да | Да | Да | Да | Да | Да |
| Автоматични режими за видео | | | | | | 33 сцени | 33 сцени | 36 сцени | | 33 сцени | 44 сцени | 44 сцени |
| Двоен запис: възможност за снимка по време на възпроизвеждане на видео | | | | | | Да | Да | Да | | Да | Да | Да |
| Възможност за снимка по време на възпроизвеждане на видео | | | | | | | | | | | Да | Да |
| Арт ефект за снимка / видео | 4 / 0 ефекта | 0 / 0 ефекта | 4 / 0 ефекта | 4 / 0 ефекта | 4 / 0 ефекта | 9 / 4 ефекта | 9 / 4 ефекта | 7 / 4 ефекта | 4 / 0 ефекта | 9 / 4 ефекта | 9 / 4 ефекта | 9 / 4 ефекта |
Фото креативност
(видео и снимки) | | | | | | | | | | Да | Да | Да |
| Режим панорамна снимка | Да (Вкл. 360 градуса) | Да (Вкл. 360 градуса) | Да (Вкл. 360 градуса) | Да (Вкл. 360 градуса) | Да (Вкл. 360 градуса) | Да | Да | Да | Да (Вкл. 360 градуса) | Да | Да | Да |
Режим панорама с висока резолюция
(43 мегапиксела) | | | | | | Да | Да | Да | | Да | Да | Да |
| 3D Панорама и 3D снимка | | | | | | Да | Да | Да | | Да | Да | Да |
Отговор: Sony камери и фотоапарати / FAQ -на първа страница, обсъждания, мнения
Мисля че си дал недостатъчно, или конкретно за определена серия. Например HDR-AX2000E или по-големия брат снабден с навигация HXR-NX5E, или бюджетните-HXR-MC50E и HVR-MC2000E. Разбира се това са вече стари модели , а в момента сони налягат или рекламират/незнам точно коя е правилната дума/ на 2-4 К и синеалта видеокамери. За фотоапаратите - серията Алфа 99 е върха на сладоледа, като най- нов модел и борещ за бъдещ процент от продажби от доминацията и легендата MARK на канон. Би ли обеснил при фотоапарати сони, когато са със две и три цифри каква е разликата?
Не съм експерт..Просто направих таблица в помощ на тези които избират. Идеята е, да има отделни теми с таблици за всяка марка.
Здравейте, интересува ме за 320лв дали мога да си купя нещо по добро от това-Sony DSC-QX10. Имам в предвид отделен фотоапарат ли да си купя или това върши същата работа като фотоапарат за тези пари.Благодаря предварително
Бих помогнал с някой жокер, но мисля, че въпроса не му е много тук мястото. По-добре отделен фотоапарат. В този бюджет влизат добри безогледални апарати втора ръка. :)
Добре ще пусна нова тема.Извинявам се за спама
Може ли да ми предложите качествени съвместими резервни батерии на Sony NP-FW50? За зарядно съм се ориентирал към Nitecore USN1, добър избор ли е?
Някой знае ли дали си заслужава да си взема уеб камера за стриймване, или е по добре да снимам с телефона ?
Не знам дали това е правилната тема. Имам Sony CyberShot DSC WX350. Като качество на снимките долу горе бива. Харесва ми бързината на снимане. Има обаче няколко разочарования. Най-главното е разпиляната организация на файловете на картата. Имам по-стар Canon, на който по дати има папки и вътре влизат всички снимки и клипове. Имената на папките са датите (месеци). При Sony имената са почти дати, не много ясни, но как да е. Само че в папките слага снимките, а клиповете ги навира на други места и за капак на всичко, ако копирам и изтрия даден клип апаратът продължава да помни, че го има и дава някаква празна позиция. Трябва да се почисти и някакъв спомагателен файл. Пробвах да прехвърлям снимките през Wifi - много недодялана работа. Очаквах апаратът да шарва папките си по мрежата, а той всъщност ги качва на сървър. Нямам ясен контрол какво е качил и какво предстои - трябва да разчитам, че помни правилно. Отделно, че май не може да трие прехвърлените неща - трябва едно по едно с копче да трия... Затова предпочитам да си го местя ръчно от картата или през USB. Има ли някаква алтернативна програма за тази цел, която е по-добре направена?
Не знам лично, никога не съм пробвал този модел.
