Няма "В клетки на паметта". "Т мемори" има. От Т се образуват В клетки (плазмоцити). И това е много просто обяснено. Като за 7-8 клас биология. Има и редица други елементи, взаимодействия и т.н.
Memory T cell subtypes
- Central memory T cells (TCM cells) express CD45RO, C-C chemokine receptor type 7 (CCR7), and L-selectin (CD62L). Central memory T cells also have intermediate to high expression of CD44. This memory subpopulation is commonly found in the lymph nodes and in the peripheral circulation.
- Effector memory T cells (TEM cells) express CD45RO but lack expression of CCR7 and L-selectin. They also have intermediate to high expression of CD44. Because these memory T cells lack the CCR7 lymph node-homing receptors they are found in the peripheral circulation and tissues.TEMRA stands for terminally differentiated effector memory cells re-expressing CD45RA, which is a marker usually found on naive T cells.
- Tissue resident memory T cells (TRM) occupy tissues (skin, lung, gastrointestinal tract, etc.) without recirculating. Some cell surface markers that have been associated with TRM are CD69 and integrin αeβ7 (CD103). However, it is worth noticing that TRM cells found in different tissues express different sets of cell surface markers. While CD103+ TRM cells are found to be restrictedly localized to epithelial and neuronal tissues, TRM cells localized in salivary glands, pancreas and female reproductive tracts in mice express neither CD69 or CD103. TRM cells are thought to play a major role in protective immunity against pathogens. Studies have also suggested a dual role for TRM cells in protection and regulation. Compared to TEM cells, TRM cells secrete higher levels of protective-immunity-related cytokines and express lower levels of the proliferation marker Ki67. It was proposed that these characteristics may help with long-term maintenance of TRM cells, as well as keeping a balance between quick response to antigen invasion and avoidance of unnecessary tissue damage. Dysfunctional TRM cells have been implicated in autoimmune diseases, such as psoriasis, rheumatoid arthritis, inflammatory bowel disease. Specific to TRM lymphocytes are genes involved in lipid metabolism, being highly active, roughly 20- to 30-fold more active than in other types of T-cells.
- Virtual memory T cells (TVM) differ from the other memory subsets in that they do not originate following a strong clonal expansion event. Thus, although this population as a whole is abundant within the peripheral circulation, individual virtual memory T cell clones reside at relatively low frequencies. One theory is that homeostatic proliferation gives rise to this T cell population. Although CD8 virtual memory T cells were the first to be described, it is now known that CD4 virtual memory cells also exist.
There have been numerous other subpopulations of memory T cells suggested. Investigators have studied Stem memory TSCM cells. Like naive T cells, TSCM cells are CD45RO−, CCR7+, CD45RA+, CD62L+ (L-selectin), CD27+, CD28+ and IL-7Rα+, but they also express large amounts of CD95, IL-2Rβ, CXCR3, and LFA-1, and show numerous functional attributes distinctive of memory cells
Tommorow
В дебелите книги пише следното:
С две думи - ваксъри, антиваксъри - както и да постъпиш, все шамари... .....
Абе прочети пак подписа ми под постовете и ще разбереш защо толкова години не го сменям.:-memnon
От 1 март до 24 септември са починали 10173 ,като от тях 78 са били ваксинирани, което прави 0.77%.
От 28 юли до 26 септември в болница са приети 20507, като от тях 1377 са били ваксинирани(6.7%).
Вчера е имало 496 новозаразени,като от тях 57 са ваксинирани(11.49%).
В болница са приети 165,като от тях 14(8.48%).
Умрели са 40,като от тях 4 са ваксинирани(10%).
0,77% от починалите от COVID-19 от март насам са били ваксинирани
Като говорите за общ брой починали - казвайте кой от какво.
Щото в един момент - всички ще умрем. Никой не е останал вечно.
нали знаеш вица....
- от какво почина тъщата ви?
- от тиган
- е как така от тиган?
- не искаше да яде гъбите, дато ѝ приготвих в него...
Ако ще броим "умрели", вече ви даваха статистиката по години. Няма значение от "записаната причина", от есента на 2020г. и през 2021г. общата смъртност за България бележи невиждани от много години назад пикове. Кръщавайте си ги "умрелите" от каквото искате. Може и от или с "тиган" ако ви харесва. Просто в този период в България, по някаква "неведома" причина се е "мряло доста по-яко" от предните години.
И съм писал, че лично бях от скептиците, които до последно не вярваха, че ще има подобни тенденции .Друг въпрос е дали има смисъл от това постоянно замерване с графики, схеми, таблици и т.н.
Между другото, в някои други форуми започнаха да заключват темата за "гъшата хуйня" както се нарича на места.
emil vasilev
Тая наша статистика взе да се доближава до "жълтата" статистика на британското държавно Public Health of England... лошо.
VanDan
А тези в кой клас се обясняват?!
Tommorow
Няма проблеми, живота си е твой. Ако обаче утре се окаже, че си надценил имунната си система, бъди така добър да си покриеш разходите за спасяването ти. Медицината ти дава средство, макар не съвършенно за да си намалиш главоболията, и то безплатно за самия теб, но ти решаваш, че ги разбираш повече тия неща. Там на леглото когато започнеш да дишаш като сом в един момент се оказва, че нямаш нищо против да ти влеят конски лекарства и други експериментални недоказани средства или такива с доста странични ефекти само и само да спреш пътуването към ловните полета... лицемерно...май всичко е според зора.....Няма лошо, живеем в свободна страна, но някакси ми се вижда справедливо да си поемеш разходите по свободната си воля....
Ама чЕкай сега !?!:
Тея където са лапали тлъсто свинско+винско, одили до 4'00 часа по кръчми и дискотеки, пушили са кат комините на ТЕЦ "Марица-Изток", живели са нездравословно, одили са по чуждо...те кат ги "метне инфаркта" или инсулта плащат ли си или чЕкат от вноските на другите да им плащат?
Ами тея където са одили по чуждо и ги е хванал СПИН, сифилис, трипер, те що не си плащат, а все ние плащаме?
Те си правили кеф с чуждо= ние плащаме.
ОТ КЪДЯ НА КЪДЯ БРЯ?!?
Очаквам FEAR ME да ви осветли относно "Теорията за микросмъртите" и как във връзка с поставянето на ваксината и най-вече на ваксиниралите се --> увеличава ли се вероятността от заболяване/преболедуване + ваксиниране с изкуствено създадена от корпорация извън човешкия организъм ваксина в сравнение само с преболедуване+ естествен/див имунитет(ваксиниране) придобит в резултат на преболедуване то...:)
Kaar
Май не е много "жълта" - просто тука вървим със закъснение, ще се покрие напълно.
Аман от спам. Почини си седмица.
mod. edit
Що умря тва младо момче Ангел? С кво го натровиха докторята? На кой беше неудобен?
Aaaa, разболял се от пневмония, но не са го приемали щото нямал ковид.
Ето така дами и господа се уморяват хората и се гони увеличаване на смъртността.
Сега викат, че е с ковид щото требват бройки, а човека обикновенна пневмония си е имал.
"...разболял се от пневмония преди около 10 дни, разказа пред Bulgaria ON AIR, че след като се почувствал зле, той е потърсил лекарска помощ, но няколко здравни заведения са му отказали такава, понеже не си е направил тест за Covid-19 и тъй като нямал нужните резултати, по думите им те не можели да го приемат."
https://life.dir.bg/zvezdi/godenitsa...olo-smartta-mu
Сега започваш ли да преосмисляш това ....тук ?
За това говорех, утре може да се случи със всеки от нас...
Лека му пръст, на младия човек и баща.
Кой ще разследва лекарските грешки? Всичко се приписва на ковид, айде аман вече.
Tommorow
Сега започваш ли да преосмисляш протеста си ....
тук ?
Нищо не преосмислям, преди хората се приемаха навреме в болница с пневмония и ги лекуваха навреме, а не ги размотаваха.
Колко сте бездушни само.
Какво ви е мнението за ваксината на Янсен?
Днес инцидентно реших да се бодна с нея, привлечен от еднократната доза и към момента не усещам някакви ефекти. Бяха минали 7 месеца , откакто изкарах вируса, не исках да излагам на риск старите хора от семейството. Пише,че пълна ефикасност се получава след 28 дни. Не знам дали не трябваше да заложа на Пфайзер.
