Страница 8 от 36 ПърваПърва ... 67891018 ... ПоследноПоследно
Резултати от 106 до 120 от общо 531
Like Tree109Одобрявам
Hisense телевизори (инфо на първа страница)
    #106
    Отговор: Hisense телевизори (инфо на първа страница)
    Hisense 55A7500F vs Samsung UE55TU7020 vs Sony KD-55X7055 vs LG 55NANO816NA
    https://tweakers.net/reviews/8510/be...derd-euro.html
    Hisense 55A7500F: VA panel,50/60Hz,no Wide Color Gamut
    Samsung UE55TU7020 : VA panel,50/60Hz,no Wide Color Gamut
    Sony KD-55X7055:VA panel,50/60Hz, Wide Color Gamut ("Triluminos" color technology)
    LG 55NANO816: IPS panel,50/60Hz, Wide Color Gamut ("NanoCell" color technology)
    Hisense 55A7500F
    Hisense 55A7500F uniformity of the backlight
    The Hisense has an option in the menu that should improve viewing angles. Samsung already used this trick on the QLED models before. The idea behind this function is that with VA panels, the viewing angles are better the harder the sub-pixels are driven. Less saturated colors are therefore controlled more brightly and to compensate for the too bright sub-pixels, other pixels are driven much less. This creates a chessboard pattern of bright and dark pixels. This is clearly visible in the photos below; on the left you can see how the pixels are controlled normally and on the right you can see how the pixels are controlled with viewing angle enhancement enabled.
    The structure of the photos is also easy to see with your own eyes and therefore detracts from the image quality. However, if you look from a somewhat greater distance, the structure is soon less noticeable and from a distance it is no longer visible at all. However well this technique works in theory, in practice its effect is disappointing. As expected, there is no difference at all with very saturated colors, but the difference is also very small with less bright colors. If we look at the photo in the center of the test image, we only see a subtle improvement in the colors. The difference is so small that it is hardly noticeable under normal circumstances.
  3. Junior Member
    Nov 2020
    #107
    Цитат Първоначално публикувано от fabolous Виж публикацията
    Благодаря за мнението. Конкретно при 24фпс контент, например филм, как се държи от гледна точка на motion processing-а? Имаш ли наблюдения? Ясно ми е, че няма да е перфектно, но все пак да е приемливо, да не се набива на очи и да не дразни.
    Бих казал че всичките проблеми на телевизора са от процесинг.
    Ако влезеш в темата на американския вариант който е по-хубав, ще видиш че на 2-3 замяна на дъното се вижда хардуерна промяна!
    Не казвам че не може да уцелиш хубава бройка, но като погледнеш очакваните цени на моделите които заменят сегашните и се очертава друга картинка.
    За да са осезаемо по-скъпи при почти същите харектеристики, предполагам са вложени пари точно в дъното/процесора и picture processing (и новия HDMI предполагам).
    От повече от година чета и избирам - всичко FALD на което не пише SONY е лотария. Даже Sony-to но уж в по-малка степен.
    Ако поправят моя U65Q8 мога да ти го продам на хубава цена. Работил е общо няма 50 часа.
    Jan 2018
    #108
    Цитат Първоначално публикувано от Neuromancer23 Виж публикацията
    Благодаря за мнението. 65 инча идва голям, мога да напасна максумим 50 инча към момента.
    #109
    Тази сутрин Hisense даде някои визуализации на новите продукти, които ще бъдат представени през април и които ще пристигнат в магазините между май и септември. Сред най-интересните новини е връщането на OLED технологията, която ще бъде представена от два модела с диагонал 55 "и 65", с VIDAA 5.0 операционна система, сертификация за сателитна телевизия също за UHD 4K канали с разделителна способност и съвместимост с Amazon Alexa. Google Assistant. VIDAA 5.0 също ще донесе със себе си приложението за Disney +, но „кога“ все още не е обявено. Двата нови OLED ще пристигнат между края на май и началото на юни. Цените и характеристиките ще бъдат съобщени по-късно.
    Също толкова интересно е обявяването на телевизор от висок клас с LCD технология и подсветка с 10 000 miniLED, панел с квантови точки , пикова яркост до 2000 NITs, 1280 различни зони . Новият телевизор ще бъде само в разрез от 75 "и ще бъде оборудван с операционната система VIDAA 5.0. Цената и характеристиките ще бъдат обявени по-късно, докато появата на пазара се очаква след лятото.
    https://www.dday.it/redazione/38323/...da-120-pollici
    https://dday.imgix.net/system/upload...ompress&w=594&
    Този пост е редактиран от hristoslav2; 28-01-21 в 20:04.
    #110
    Hisense Lifestyle TV Mural
    https://www.hxosplus.gr/vision/hisense-lifestyle/
    Hisense 8K ULED U80G TV is here (first look – mini review)
    https://www.gadgetguy.com.au/hisense...k-mini-review/
    #111
    Списък на сертифицираните по HDR10+ модели 2021
    55U8GQ,55U80GQ,55U81GQ,55U82GQ,55U86GQ,55U87GQ
    65U8GQ,65U80GQ,65U81GQ,65U82GQ,65U86GQ,65U87GQ
    https://hdr10plus.org/certified-products
    TV Display Hisense Visual Technology Co., Ltd. 55U6+G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U60G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U60GS 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U60GSV 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U68G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U6G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U6G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U7+G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U70G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U70GS 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U70GSV 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U78G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U7G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U7G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U80GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U80GQCH 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U80GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U81G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U81GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U81GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U82GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U82GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U86GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U86GQCH 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U86GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U87GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U87GQCH 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U87GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U88G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U88GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U88GQNE 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U89GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U89GQNE 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U8G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U8G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U8GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U8GQCH 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U8GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U8QFTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55U8QG 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55Z770KP 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 55Z770KT 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U6+G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U60G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U60GS 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U60GSV 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U68G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U6G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U6G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U7+G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U70G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U70GS 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U70GSV 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U78G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U7G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U7G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U80GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U80GQCH 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U80GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U81G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U81GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U81GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U82GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U82GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U86GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U86GQCH 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U86GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U87GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U87GQCH 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U87GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U88G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U88GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U88GQNE 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U89GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U89GQNE 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U8G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U8G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U8GQ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U8GQCH 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U8GQTUK 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65U8QG 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65Z770KP 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 65Z770KT 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75H8G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U6+G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U68G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U6G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U6G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U7+G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U78G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U7G 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U7G+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U9+DG+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U9DG 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U9DG+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75U9XG+ 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. 75Z770KP 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. DK50X9500 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. DK55X9500 2021 4K ULED TV
    TV Display Hisense Visual Technology Co., Ltd. DK65X9500 2021 4K ULED TV
    https://www.avcesar.com/actualites-t...hisense-55u8gq
    Този пост е редактиран от hristoslav2; 21-02-21 в 17:56.
    #112
    Jul 2016
    #113
    Един съвет към тези, които си купуват Хисенсе!
    Ходете и гледайте преди да го купите, аз такава сапунена опера никога не съм гледал на телевизор.
    Тотален провал с обработката на кадрите, всичко е изключено, но сякаш гледам филми с настройка за спорт.
    #114
    Това са бюджетни телевизори с евтин хардуер......дотолкова са го окастрили, че захранващият блок и майн борда в някои модели са събрани в една платка.
    Софтуера според руснаците е пълен с бъгове.
    Test TV Hisense 55U7
    https://www.avmagazine.it/articoli/4...hdr_index.html
    Този пост е редактиран от hristoslav2; 06-03-21 в 09:07.
    #115
    Jul 2016
    #116
    Hisense 43A7500F, това е ТВ-то, не е от ниските класове на марката.
    Хем си знам, че не трябва да купувам подобни марки, но се подведох по уж добрите отзиви, същата работа и с ТCL-a.
    tolostoi одобрява това.
    #117
    Hisense TV U7G PRO се нарежда на второ място в последната класация за качество на телевизора
    https://www.znds.com/tv-1192598-1-1.html
    Тест на китайският Hisense U7G-PRO - с процесор MediaTek9652, Cortex-A73, 3G + 128G, WiFi-6, 1600 nits, 97% DCI-P3
    https://zhuanlan.zhihu.com/p/355679044
    Забелязах, че има някои прилики между U8GQ и китайския U7G, както виждаме в горният китайски тест, както и в това презентационно видео, публикувано преди това от 3,24 минути:
    Приликите: - една и съща рамка (предна повърхност) - същата задна телевизионна повърхност (т.е.: субуфер, високоговорител...и т.н.) - същия брой зони (120 за 65 "и 90 за 55") няма 144hz за U8GQ (запазено само за U7GQ ЕС), а и няма външна камера!
    от друга страна не знаем дали е същият панел или не (това е ADS панел, произведен от BOE, еквивалентен на IPS панел, който е инсталиран в китайския U7G-Pro):
    Този пост е редактиран от hristoslav2; 13-03-21 в 17:25.
  16. Senior Member Аватара на inches9
    Aug 2020
    #118
    Ето и заключенията от крайното ревю на HDTV Polska за HISENCE U8QF,най-добрия сайт за прегледи в Европа,заедно с FLATpanelsDK,но последния прави много малко.Тъй като много от''знаещите '' казваха,че не бил същия като в САЩ.Дори не знаех на очите си ли да вярвам или на форумни експерти,вкл. тези в avforums.Та:
    В средата на миналата година на уебсайта на Media Expert се появиха първите няколко продукта, включително LCD моделите ULED U7QF и U8QF, обявени за добър клас. Никой обаче не очакваше, че ще бъдем толкова положително изненадани от доброто утро. И не само с цената, но и с качеството на изображението и функциите, предлагани от телевизорите на гиганта от Китай. В нашата редакция тествахме и двете, но започваме с модел, който предизвика объркване на лицата ни, когато видяхме филмови материали в 4K Ultra HD върху него.
    Контраст във филмите (повече - по-добре) средна: 30 700: 1 макс: 47,200: 1 мин: 12,200: 1
    Заглушаването в Hisense се основава на 180 независими зони за осветление. Той има много потенциал и е безпрецедентен в този ценови диапазон! Всъщност броят на зоните е дори по-голям, отколкото във водещия телевизор на добре позната корейска марка.
    Резултатите също говорят сами за себе си - черното беше страхотно дори в най-взискателната сцена номер 2, както и във всяка друга сцена, където черната повърхност не беше толкова голяма. Това е наистина страхотна новина за феновете на киното и филмите. Има много общо с OLED телевизора. За да не пишете в суперлативи, е необходимо да споменете недостатъците на загасващия алгоритъм - понякога той причинява диспропорции на яркостта на екрана (винетки) или ефект на ореол. Това обаче е очевидно на LCD телевизор със загасване.
    Резултатите от HDR яркостта са просто невероятни. Със средно 750 нита, Hisense може да се конкурира с топ моделите на престижни марки и това е друга много положителна изненада
    Картографиране на движението Hisense U8QF е оборудван с 120Hz матрица и система за втечняване, която подобрява както движението във филми, така и динамичното спортно съдържание. И в двете телевизора се справя много добре.
    Предимства Най-доброто съотношение цена-производителност на пазара в 65 и 55 инча Матрица в Direct LED технология
    Сензационен контраст благодарение на 180 зони с подсветка - изпреварващи други LCD телевизори не само в тази ценова категория, но и много по-високи
    Феноменална яркост в HDR - средна за филми или игри до 750 нита, максимум 1400 нита!
    Много висока яркост SDR 610 нита - идеална за много слънчеви дневни
    Много добро покритие на цветовата палитра - 96% DCI P3 (квантова точка)
    Поддръжка на технологията Dolby Vision, която значително подобрява качеството, например в Netflix 120Hz матрица, подходяща за филми и спорт Обширни опции за калибриране - вярно цветопредаване Много ниско забавяне на входа (14ms) - добър избор за играчите
    Бързодействащ интерфейс Независима патентована мултимедийна система VIDAA 4.0 Висококачествена изработка и много елегантен външен вид Звук с добро качество, поддържан от високоговорители JBL
    Недостатъци Няма HDMI 2.1 и функции за плейъри, свързани с този порт, включително 120Hz, дори в Full HD
    Лоши ъгли на видимост (поради използваната VA матрица без допълнителни ъглови филтри) Проблеми с обработката на RGB сигнал По време на писането на теста няма видео приложения като Player, IPLA или HBO GO (те ще се появят скоро)
    Присъда
    Телевизорът ULED Hisense U8QF е голяма, много положителна изненада. Продуктът на неизвестна марка в Полша се оказа мощен хит за премиум и дори от висок клас сегмент, като същевременно беше по-достъпен. Трудно е да се посочи друг телевизор, който предлага толкова висока яркост в HDR и в същото време толкова добри черни. И дори да посегнем към водещите LCD модели от марки като Sony, Samsung или TCL, ще се окаже, че те са много по-скъпи (два или три пъти?). Hisense е чудесна алтернатива тук, предлагаща подобно качество на изображението за много, много по-ниска цена. Така че вече няма смисъл да купувате други телевизори? Със сигурност не бих отишъл на такова изявление.
    Първо трябва да се уверите, че ви харесва собствената операционна система (VIDAA 4.0), използвана от производителя, и, дали има всички приложения, желани от купувача. Също така си струва да се провери дали описаните недостатъци на софтуера няма да вземат своето, като липсата на 120Hz в конзолата / компютъра въпреки матрицата от 120Hz. Hisense U8QF ще бъде добър избор за играчите от гледна точка на забавяне на входа. Дори хората, които играят професионално на конзолата, няма да го усетят. За съжаление му липсват HDMI 2.1 портове или дори функции като VRR или ALLM. Е, не можете да имате всичко на тази цена. Очакванията ни за линията на производителя за 2021 г. обаче бяха повишени до прекомерно ниво, защото вече знаем какво може да направи.
    https://hdtvpolska.com/jakosc-telewi...w-hdr-w-120hz/
    Сега ще оставя на всички знаещи да обясняват и да сравняват тези оценки с другите на сайта.
    И да продължат със собствените си разсъждения за ''евтини'' ,''бюджетни''марки.
    Приятна дискусия
    Този пост е редактиран от inches9; 15-03-21 в 11:54.
    #119
    Цитат Първоначално публикувано от inches9 Виж публикацията
    да пробваме
    https://hdtvpolska.com/wp-content/up...2000-ocena.png
    https://service.hisense.de/service/downloads/
    Hisense LTDN40K220WSEU - Сортиране на списъци с канали / списък за изтегляне
    https://www.nachtfalke.biz/f275-sons...oad-liste.html
    https://www.nachtfalke.biz/500-sende...d-36102-a.html
    Този пост е редактиран от hristoslav2; 14-03-21 в 22:00.
  18. Senior Member Аватара на inches9
    Aug 2020
    #120
    [QUOTE=hristoslav2;996891]да пробваме
    Всичко е ок.Кой е стигнал до HZ2000,да му е честито,няма кво да чете форуми.
    А сега да продължим ли с пробите или тази долната ще е последна.....Мисля,че продълженията са излишни.Меко казано.
  1. Гаснене на телевизор HISENSE
    От tvbe във форум Hisense телевизори
    Отговори: 10
    Последно: 12-10-19, 14:38
  2. Помощ за Hisense 12-ка
    От alonecrewbg във форум Всичко за климатиците
    Отговори: 25
    Последно: 20-11-17, 20:10
  3. Малко помощ за hisense
    От waradin във форум Климатици Hisense, Gree, Chofu, Bard
    Отговори: 36
    Последно: 24-01-17, 21:12
  4. HISENSE AS-09UR4SVGVQ5 за охлаждане
    От ops5 във форум Климатици Hisense, Gree, Chofu, Bard
    Последно: 07-07-15, 13:30
  5. HISENSE KFR-3502G/BPE
    От presar във форум Климатици Hisense, Gree, Chofu, Bard
    Последно: 21-10-10, 03:19
