Отговор: LG телевизори 2015
LG AN-MR600: Magic Remote Control with Voice Mate™ for Select 2015 Smart TVs | LG USA
SUMMARY
Input Capabilities Pointing, Drag & Drop, Wheel, Voice Recognition, Universal Remote, Number Key Pad
Compatible UHD 4K Models - UF7700, UF8500, UF9400, UF9500
Compatible OLED Models - EF9500, EG9600, EF9800
Compatible LED LCD Models - LF650, LF630
LG AN-MR500: Smart Magic Remote Control for LG Smart TVs | LG USA
Моделът е 100Hz
Real
Refresh Rate | Samsung
Piqture Quality Index | LG
Picture Mastering Index | Sony
MotionFlow | Panasonic
Real Motion Rate
Backlight Motion Rate | Philips
Picture Motion Rate | Sharp
Active motion |
50 Hz | 50 (1080p)
100 (1080p)
200 (1080p)
400 (1080p)
800 (4k)
900 (4k)
1000 (4k)
1200 (4k) | 100 (1080p)
300 (1080p)
400 (1080p)
450 (1080p)
800 (1080p)
700 (4k)
900 (4k)
1000 (4k)
1300 (4k) | 100 (1080p)
200 (1080p)
200 (4k) | 200 RMR (1080p)
400 RMR (1080p)
100 BMR (1080p)
200 BMR (1080p)
200BMR (4k) | 100 (1080p)
200 (1080p)
400 (4k)
700 (4k)
800 (4k) | 100 (720p)
100 (1080p)
200 (1080p) |
| 100 Hz | 800 (1080p)
1300 (4k)
1400 (4k)
1900 (4k) | 900 (1080p)
1400 (4k)
1500 (4k)
1600 (4k) | 800 (1080p)
900 (1080p)
1000 (1080p)
900 (4k)
1000 (4k) | 400 BMR (1080p)
800 BMR (4k)
1000 BMR (4k)
1600 BMR (4k) | 500 (1080p)
800 (1080p)
1400 (4k)
1800 (4k) | 400 (1080p) |
200 Hz* | 2000 (4k)
2400 (4k) | 2000 (4k)
2300 (4k) | 1200 (4k) | 2000 (4k 2014)
3000 (4k 2014) | 2400 (4k) | 800 (1080p)
800 (4k) |
Благодаря! A 49LF630V e 800pmi, респективно 50Хз, нали така?
Боян Александров
В LF63хх до 40 инча слагат 50/60Hz матрици, а в тези от 43 до 65 инча - 100/120Hz.
LG 32LF630V
LC320DUE-FHA1 FHD 32INCH 1920X1080 300CD COLOR 68% 16/9 1200:1 60Hz Inverter N LED 2D With T-con, 35.7W/29.7W/6.0W, 8Bit, 10000K, 178/178, GTGBW 9ms, LVDS 2ch, Carbon Titan LG Display Co., Ltd.
LG 43LF630V
LC430EUE-FHM1 FHD 43INCH 1920X1080 300CD COLOR 68% 16/9 1200:1 60Hz Inverter N LED 2D With T-con, 47.6W/43.4W/4.2W, 8Bit, 10000K, 178/178, GTG BW 9ms, LVDS 2ch, Carbon Titan LG Display Co., Ltd.
LG 49LF630V
LC490EUE-FHM1 FHD 49INCH 1920X1080 300CD COLOR 68% 16/9 1200:1 60Hz Inverter N LED 2D With T-con, 51.1W/47W/4.1W, 8Bit, 10000K, 178/178, GTGBW 9ms, LVDS 2ch, Carbon Titan LG Display Co., Ltd.
LG 55LF640V
LC550DUE-MGP2 FHD 55.0INCH 1920X1080 330CD COLOR 68% 16/9 1200:1 60Hz Inverter N LED 3D(FPR) With T-con, 75W/67.6W.7.4W, 8Bit, 10000K, 178/178, GTG 6ms, LVDS 2ch, Mineral Silver(C/T) LG Display Co.
http://partsoutlet.ru/shop.php?cid=583
Пример на разчитане
1. 55.0INCH - това е диагонала в инчове - 55
2. 1920Х1080 - това е резолюцията на панела
3. 300CD - Яркост в кандели, в зависимост от диагонала може да достига до 500CD
4. COLOR 68% - това е цветовият обхват по NTSC(CIE1931), има модели с 72%, а при прилагане LG технологията Color Prime (Blue Chip + RED/Green Phoshor) повече от 100%
5. 16/9 - това е аспектът на дисплея
6.1200:1 - това е контрастът. Има модели с изписан 1300:1, 1400:1. Но не вярвайте на тази стойност - това е маркетинг. Реално матриците IPS достигат максимално контраст от 900:1. С локално затъмняване стигат и до 1400:1. За един зрител обаче важен е замереният ANSI контраст.
7.120Hz - честота на опресняване и работа на T-con борда
8. N Led(Nitrite Led) - стандартни светодиоди без подобрения.
9. 3D(FPR) - това е приложената 3D технология на LG - FPR(Film-type Patterned Retarder)
10. With T-con - показва , че панела има собствен T-con - това е платката управляваща матрицата
11. 8Bit - Битност на цветовата кодировка, има модели с изписани 10Bit, но това 8 битова + рендериране на цветоветe (8bit + dithering)
12.10000K - това е цветовата температура в келвини
13. 178/178 - зрителни ъгли, но не вярвайте и на тези стойности. Реално при IPS са около 120 градуса.
14. GTG 6ms - това е времето за реакция от един нюанс на сивото до друг. Няма нищо общо с реално измереният от черно до бяло и обратно - там показателите са 11-12ms.
15. EPI - това е интерфейсът, има и LVDS с брой канали, по новият е V-by-One (характеризира се с количеството сигнални линии и скоростта на предаване на данни по тях)
https://forum.setcombg.com/attachmen...id=18347&stc=1
https://forum.setcombg.com/attachmen...id=18361&stc=1
Здравейте. Въпросът ми е коя е последната версия на firmware за телевизор lg49uf852v. Същият в момента е с версия 4.00.15 а на сайта на lg e 3.20.05. Благодаря предварително.
Нулирах настройките на LA690S и не мога вече да си настроя универсално дистанционно за да управлявам Булсат приемника си, което е проблем много удобно ми беше. И преди намерих е писано за същия проблем, но никой не отговаря дано сега се намери.. някой.
axander
Страна,Полша-други-скаймастер-дистанционно номер 7.
Е браво благодаря много стана.
4 Прикачен файл(ове)
Gena_bs
Има ли "фирмена" клавиатура от този тип за LG 2015?
На сайта им само Magic remote рекламират и нищо друго. А за цената му не ми се коментира.
Пробвах Rapoo 9080 и Logitech K400 на мои приятели, но не покрива повече от 20-30% от функциите на телевизора.
А да купя подобната на Microsoft и да не ми върши работа е безсмислено.
е нали за целта клавиатурата трябва да е пригодена за телевизора и лично аз не съм чувал за модел който да отговаря на това условие, а LG нямат фирмена клавиатура за телевизори.
Аксессуары для webOS-телевизоров
lg tv webos bluetooth keyboard - webOS Nation Forums
https://itunes.apple.com/us/app/smar...991626968?mt=8
За меджик дистанционните
LG TV аксесоари | ТВ аксесоари от | LG Bulgaria
| AN-MR600 | AN-MR500 | AN-MR400 | AN-MR300 |
| 2015 | 2014 | 2013 | 2012 |
AN-MR600
https://forum.setcombg.com/attachmen...id=18454&stc=1
Дистанционно за телевизори 2015 година - серии (UF, LF, EG, EF) съвместимо с модели:
UF77x, UF85x, UF95x, UG87x, EF98х, EG96х, EF95х, EG92х, UF94х, UF86х, UF83х, UF69х, UF68х, LF65х, LF64х, LF63х
Поддържа гласови команди, управление с курсор, има скрол.
AN-MR500
https://forum.setcombg.com/attachmen...id=18455&stc=1
Дистанционно за телевизори 204 година серии LB, съвместимо с модели:
LB63xx, LB65xx, LB67xx, LB68xx, LB69xx, LB72xx, LB73xx, LB86xx, LB87xx
По функционалност е аналогично на модели 2015 година.
AN-MR400
https://forum.setcombg.com/attachmen...id=18457&stc=1
Дистанционно за телевизори 2013 година за модели от серии LA, LN, PH, PN съвместимо с модели: LA660V, LA662V, LA669V, LA690V, LA691V, LA692V, LA741V, LA790V, LA860V, LA868V[/FONT]
- AN-MR400P: LM860V, LM960V,
- AN-MR400G: LA667V, LA667V, LA710V, LN655V, 27MT93V, PH670V, PH672V
AN-MR300
https://forum.setcombg.com/attachmen...id=18458&stc=1
Дистанционно за Smart TV за телевизори 2012 година от серии:
TM2792,, LM660, LM670, LM670T, LM760, LM761, PM690, PM970
Благодаря!
Logitech K400 и M230 май беше, в ръководството на телевизора ги пишат като съвместими или нещо подбно.
Обаче в действителност нещата не са точно така.
Здравейте,дано не бъркам темата.Харесах си един модел-LG49UF695V.Гледах го в ТМ и много ми хареса картината и дизайна.Няма 3Д и образа ми се стори по-ясен и контрастен.Пише,че е 1200Hz.имате ли представа с каква матрица е? Благодаря!
