https://www.youtube.com/watch?v=0LSBdqtDrvA
Как да излюча съобщение за налично обновление на системата? Появява се всеки път при включване.
Точно това са притесненията, да няма проблем след обновяването. Изключих интернет безжичната връжка и вече не се показва.
Имам четири LG-а, минали са десетки обновления и никога досега не е имало проблем след това.
Направих обновяването. Всичко работи без проблеми.
https://www.youtube.com/watch?v=Mf4ge_73buE
42C2 service menu_WBC
https://avclub.gr/index.php?attachme...bc-jpg.195494/
https://www.hdtvtest.co.uk/n/LGs-42-...el-but-not-yet
https://www.hdblog.it/tv/articoli/n5...essori-oledex/
42" LG C2 will get OLED EX panels after the second quarter.
https://www.flatpanelshd.com/news.ph...&id=1648718644
LG WRGB subpixel panel structure 65G1 vs 65G2
https://avclub.gr/index.php?attachme...g1-jpg.195770/
LG 65G2 vs 65G1 SPD_Spectral Power Distribution_WBE_EX plus heatsink vs WBE
https://avclub.gr/index.php?attachme...be-jpg.195771/
Peak light output : 929 nits (cd/m2) on a 10% window in Filmmaker mode ,out of box settings .
Peak light output : 172 nits (cd/m2) full field-100% window in Filmmaker mode,out of box settings.
източник
https://avclub.gr/index.php?threads/....176205/page-2
https://www.youtube.com/watch?v=bvih6RcDjdI
945cd/m
C2
https://www.lesnumeriques.com/tv-tel...c-n179513.html
804 cd/m2, delta E 2.1
не е лошо:, но G2 има малка преднина от първите тестове (930-950 cd/m2)
LG TV 2022 Display OLED QNED LCD
NOF sheet + Blue LEDQDEF LCD
LCD Resolution SUHD UHD SUHD UHD UHD SUHD UHD UHD FHD HD Series Z2 G2
C2B2 A2 QNED99
QNED96
QNED95QNED91
QNED90QNED87
QNED86
QNED85QNED82
QNED81
QNED80NANO99
NANO95
NANO90 NANO82
NANO80NANO78
NANO76
NANO75
UQ91
UQ90UQ80 UQ75 UQ70 LQ6300 LQ630B Backlight - - - - Mini LED Mini LED Mini LED Mini LED Edge LED - - - Edge LED Edge LED Direct LED Direct LED Direct LED Direct LED Direct LED Direct LED Panel Frequency 100/120Hz 100/120Hz 100/120Hz 50/60Hz 100/120Hz 50/60Hz 100/120Hz 100/120Hz 100/120Hz 100/120Hz ? 50/60Hz 100/120Hz 50/60Hz 50/60Hz 50/60Hz 50/60Hz 50/60Hz 50/60Hz 50/60Hz 50/60Hz Game Optmizer Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes no no HGiG (HDR Gaming Interest Group) Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes no no HDMI 2.1 (48 Gbps) 4x 4x 2x no 4x 4x 2x 2x 2x 4x 4x 4x no no no no no no no no HDMI 2.1 (40 Gbps) no no no no no no no no no no no no no no no no no no no no HDMI 2.0b (18 Gbps) no no 2x 3x no no 2x 2x 2x no no no 4x 3x 3x 3x 2x 2x 2x 1.4 2x 1.4 FRL (Fixed Rate Link) 12Gbps/4lines 12Gbps/4Lines 12Gbps/4lines no 12Gbps/4Lines 12Gbps/4Lines 12Gbps/4Lines 12Gbps/4Lines 12Gbps/4Lines 12Gbps/4lines 12Gbps/4lines 12Gbps/4lines no no no no no no no no eARC (Enhanced ARC) Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes no no no no ALLM (Auto Low Latency Mode) Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes no no VRR (HDMI Forum VRR) 20-120Hz 20-120Hz 20-120Hz no 40-120Hz 4K no 40-120Hz 40-120Hz 40-120Hz ? no 40-120Hz no no no no no no no no VRR (AMD FreeSync Premium) 20-120Hz 20-120Hz 20-120Hz no 40-120Hz 4K no 40-120Hz 40-120Hz 40-120Hz ? no 40-120Hz no no no no no no no no VRR (NVIDIA GSync) 20-120Hz 20-120Hz 20-120Hz no no no no no no ? no ? no no no no no no no no 4K HFR 120fps (10bit 4:4:4) 4K 120 & DV 4K 120 & DV 4K 120 & DV no 4K 120 & DV no 4K 120 & DV 4K 120 & DV 4K 120 & DV 4K 120 & DV no 4K 120 & DV no no no no no no no no 2K HFR Yes Yes Yes no Yes no Yes Yes Yes Yes no Yes no no no no no no no no QMS (Quick Media Switching) no no no no no no no no no no no no no no no no no no no no QFT (Quick Frame Transport) no no no no no no no no no no no no no no no no no no no no DSC (Display Stream Compresion) Yes Yes Yes no Yes Yes Yes Yes Yes ? ? ? ? no no no no no no no
Този пост е редактиран от hristoslav2; 03-04-22 в 22:44.
Консумацията на телевизора LG 65C2 Oled в режим Галерия
https://www.lesnumeriques.com/tv-tel...e-n179581.html
LG 65C2 наследява интегрираните микрофони от серията GX и G1 от 2020 г.: система, която позволява взаимодействие с телевизора, без да се налага да докосвате дистанционното управление.
Галерия – Режимът на възпроизвеждане на картини може да консумира до 180 W в зависимост от изображението, което се показва.
Консумация на различните режими "Галерия" и гласовия асистент
Режим на готовност с отворен микрофон за свободни ръце: 5 W
Показване на времето след гласова заявка: ≈38 W
Галерия – Режим на часовник: ≈34W
Gallery – Artwork Mode: между 67 и 180 W
Галерия – Режим на движение: между 40 и 160 W
Галерия – Режим на снимки: между 40 и 170 W
Галерия – Звукова палитра: между 40 и 150 W
LG потвърди, че тази година все още ще има някои обикновени модели NanoCell, но в дългосрочен план ще се стреми да ги премахне в полза на QNED.
Допълнение
LG 86NANO76 - 100Hz
LG 86NANO75 - 100Hz
LG 86UQ9100 - 100Hz
LG 86UQ8000 - 100Hz
[/QUOTE]
NOF sheet + Blue LEDNano Cell LCD
--LCD Resolution SUHD UHD SUHD UHD UHD SUHD UHD UHD FHD HD Series Z2 G2
C2B2 A2 QNED99
QNED96
QNED95QNED91
QNED90QNED87
QNED86
QNED85QNED82
QNED81
QNED80NANO99
NANO95
NANO90 NANO82
NANO80NANO78
NANO76
NANO75
UQ91
UQ90UQ81
UQ80UQ75 UQ70 LQ6300 LQ630B Backlight - - - - Mini LED Mini LED Mini LED Mini LED Edge LED - - - Edge LED Edge LED Direct LED Direct LED Direct LED Direct LED Direct LED Direct LED Panel Frequency 100/120Hz 100/120Hz 100/120Hz 50/60Hz 100/120Hz 50/60Hz 100/120Hz 100/120Hz 100/120Hz 100/120Hz 50/60Hz 100/120Hz 50/60Hz 50/60Hz 50/60Hz 50/60Hz 50/60Hz 50/60Hz 50/60Hz 50/60Hz Game Optmizer Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes no no HGiG (HDR Gaming Interest Group) Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes no no HDMI 2.1 (48 Gbps) 4x 4x 2x no 4x 4x 2x 2x 2x 4x 4x 4x no no no no no no no no HDMI 2.1 (40 Gbps) no no no no no no no no no no no no no no no no no no no no HDMI 2.0b (18 Gbps) no no 2x 3x no no 2x 2x 2x no no no 4x 3x 3x 3x 2x 2x 2x 1.4 2x 1.4 FRL (Fixed Rate Link) 12Gbps/4lines 12Gbps/4Lines 12Gbps/4lines no 12Gbps/4Lines 12Gbps/4Lines 12Gbps/4Lines 12Gbps/4Lines 12Gbps/4Lines 12Gbps/4lines 12Gbps/4lines 12Gbps/4lines no no no no no no no no eARC (Enhanced ARC) Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes no no no no ALLM (Auto Low Latency Mode) Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes no no VRR (HDMI Forum VRR) 20-120Hz 20-120Hz 20-120Hz no 40-120Hz 4K no 40-120Hz 40-120Hz 40-120Hz 40-120Hz no 40-120Hz no no no no no no no no VRR (AMD FreeSync Premium) 20-120Hz 20-120Hz 20-120Hz no 40-120Hz 4K no 40-120Hz 40-120Hz 40-120Hz 40-120Hz no 40-120Hz no no no no no no no no VRR (NVIDIA GSync) 20-120Hz 20-120Hz 20-120Hz no no no no no no ? no ? no no no no no no no no 4K HFR 120fps (10bit 4:4:4) 4K 120 & DV 4K 120 & DV 4K 120 & DV no 4K 120 & DV no 4K 120 & DV 4K 120 & DV 4K 120 & DV 4K 120 & DV no 4K 120 & DV no no no no no no no no 2K HFR Yes Yes Yes no Yes no Yes Yes Yes Yes no Yes no no no no no no no no QMS (Quick Media Switching) no no no no no no no no no no no no no no no no no no no no QFT (Quick Frame Transport) no no no no no no no no no no no no no no no no no no no no DSC (Display Stream Compresion) Yes Yes Yes no Yes Yes Yes Yes Yes ? ? ? ? no no no no no no no
https://www.avforums.com/threads/lg-...on-iq.2407387/
това Дистанционно LG Magic Remote AN-MR21GC
дали ще стане на LG 55UF950V
от 2015 година
IFF
Не. Виж таблицата в краят на първи пост.
https://en.tab-tv.com/?p=23731
https://www.carousell.sg/p/authentic...0a-1104537316/
We review the 42-inch LG C2 OLED TV which is marketed as "EVO", but because our retail unit uses an older WBC panel, we reached out to LG Electronics for comment.
Timestamps: ===========
0:00 Evo but older panel?
2:34 Improvement #1 vs C1
3:16 USP #1 of LG OLEDs
4:43 Downgrade #1 vs C1
6:22 Potential dealbreaker for some
7:51 Why OLED trumps LED LCD
11:12 Gaming tests
13:22 Is VRR flicker fixed?
14:35 Worst downgrade vs larger LG OLEDs
15:27 Why it's king for gaming
16:01 C2 vs C1 comparison
Our review sample is the OLED42C2 which we bought ourselves.
The LG C2 is also available in larger screen sizes of 48", 55", 65", 77" and 83", although due to their lower pixel aperture ratio, the 42C2 and 48C2 won't benefit from increased brightness.
