mini LED FALD LCD,120Hz panel 8K:
QE85QN900B :
QE75QN900B :
QE65QN900B : 48x28 array, 1344 local dimming zones
QE85QN800B :
QE75QN800B :
QE65QN800B : FALD, 48 columns and 28 rows for a total of 1344 independent zones
mini LED FALD LCD,60Hz panel 8K:
QE75QN700B :
QE65QN700B :
QE55QN700B : 36 x 14 = 504 local dimming zones
mini LED FALD LCD,120Hz panel :
QE85QN95B :
QE75QN95B :
QE65QN95B : 40 x 18 = 720 local dimming zones, (you cannot switch off via the menus)
QE55QN95B : 36 x 16 = 576 local dimming zones in the 55-inch model, which is the same as in last year's QE55QN95A.
QE85QN90B :
QE75QN90B :
QE65QN90B : full array of 720 dimming zones in a 40 x 18 array
QE55QN90B :
QE50QN90B :
QE43QN90B :
QE85QN85B :
QE75QN85B : Direct, mini LED LCD, 45 horizontal zones and 20 vertical zones = 900 dimming zones
QE65QN85B : Direct, mini LED LCD, 40x18 = 720 dimming zones (low,medium,high)
QE55QN85B : Direct, mini LED LCD, 36 horizontally & 14 vertically = 504 dimming zones)
KQ43QNB90A : 30x12 = 360 local dimming
QN65Q80B : FALD (low,medium,high) : 4 x 12 array for 48 total dimming zones,note that you can't easily disable the local dimming on Samsung TVs, as you need to do it through the service menu
QE55Q80B : Direct LED LCD,FALD 50 dimming zones = 5 horizontal zones and 10 vertical zones, low,standard,high
