Резултати от 1 до 7 от общо 7
Debian:: Помощ
    Mar 2004
    Debian:: Помощ
    Здравейте!
    Имам следният проблем на Дебиана. Този флууд ме дразни вече няколко дена. Незнам какво става...
    Код:
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32163 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32165 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32168 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32170 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32174 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32179 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32183 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32190 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32199 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32204 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32210 PROTO=2
    IN=eth0 OUT= MAC=01:00:5e:00:00:01:00:13:8f:89:92:7a:08:00 SRC=85.217.208.212 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=32219 PROTO=2
    Това е вече повече от месец. Незнам това ли е причината /dev/hda1 почти постоянно да е на 100% full. Трих логове нагласях logrotate и какво ли още не.
    Бихте ли били така добри да ми обясните за какво става въпрос и АКО може да ми помогнете да го оправя.
    Благодаря
    Jun 2002
    Re: Debian:: Помощ
    214.0.0.1 e Multicast съобщение до всички машини в подмрежата.
    Според мен най-добре е просто да се drop-ва всичко от адрес 85.217.208.212.
    Feb 2003
    Re: Debian:: Помощ
    като гледам това IP 85.217.208.212 ако не е твоето, е на някоя машинка от доставчика ти, сигурно добре натъпкана с буби, ама може и да греша.
    Nov 2002
    Re: Debian:: Помощ
    Прегледай файъруола и разкарай логинга.
    Mar 2004
    Re: Debian:: Помощ
    Звънях до ISP-то и казаха че ще оправят проблема. А един въпрос относно syslog.conf. Значи в момента е така
    Код:
    auth,authpriv.*         /var/log/auth.log
    *.*;auth,authpriv.none     -/var/log/syslog
    #cron.*             /var/log/cron.log
    daemon.*            -/var/log/daemon.log
    kern.*             -/var/log/kern.log
    lpr.*              -/var/log/lpr.log
    mail.*             -/var/log/mail.log
    user.*             -/var/log/user.log
    uucp.*             /var/log/uucp.log
    # Logging for the mail system. Split it up so that
    # it is easy to write scripts to parse these files.
    mail.info            -/var/log/mail.info
    mail.warn            -/var/log/mail.warn
    mail.err            /var/log/mail.err
    ако го направя така...
    Код:
    #daemon.*            -/var/log/daemon.log
    #kern.*             -/var/log/kern.log
    #lpr.*              -/var/log/lpr.log
    #mail.*             -/var/log/mail.log
    #user.*             -/var/log/user.log
    #uucp.*             /var/log/uucp.log
    #mail.info            -/var/log/mail.info
    #mail.warn            -/var/log/mail.warn
    #mail.err            /var/log/mail.err
    ще спрат ли да се правят гадните логове ?
    Nov 2002
    Re: Debian:: Помощ
    Принципно ще се оправят, ама няма причина да разкарваш логинга. Оправи си файъруола, както вече казах.
    Mar 2004
    Re: Debian:: Помощ
    ок Фори ще видя да го оправя.
    Благодаря!
  1. Проблем с мрежа между Debian и Win XP
    От grgeorgiev във форум Мрежи
    Последно: 16-05-07, 09:11
  2. Audio driver / Debian
    От BerkStock във форум Linux
    Последно: 22-12-04, 13:14
  3. Debian apt sources - mirrors in Bulgaria
    От KOKOSH във форум Linux
    Последно: 17-06-04, 05:45
  4. Debian for Desktop
    От krasi във форум Linux
    Последно: 13-02-04, 17:18
  5. Debian - download
    От Go_Play във форум Linux
    Последно: 26-12-03, 23:10
