Как да конфигурирам courier демона да слуша само определен(от мен) интерфейс, а не всички, както е по подразбиране.
# Port to listen on for connections. The default is port 110.
# Multiple port numbers can be separated by commas. When multiple port
# numbers are used it is possibly to select a specific IP address for a
# given port as "ip.port". For example, "127.0.0.1.900,192.68.0.1.900"
# accepts connections on port 900 on IP addresses 127.0.0.1 and 192.68.0.1
# The ADDRESS setting is a default for ports that do not have a specified
# IP address.
Много благодаря!
