licq
Predvarielno se izvinqvam za pravopisa, no ne sum si opravil kirilizaciqta
Srestam maluk problem s pyskaneto na licq. Poneze sum v lan i inetrneta mi e prez proxy instaliram socks s nastroikite za prosyto:
/configure --with-default-server=172.16.1.1:3128
/make
/make install
Do tuk vsichko e tok i zici
Instaliram samoto licq:
./configure --enable-socks5
do tuk dobre
SOCKS5 support is enabled.
OpenSSL secure channel support is enabled.
obache sled kato napisha make mi se polu4ava slednoto:
make all-recursive
make[1]: Entering directory `/licq-1.0.2'
Making all in share
make[2]: Entering directory `/licq-1.0.2/share'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/licq-1.0.2/share'
Making all in src
make[2]: Entering directory `/licq-1.0.2/src'
c++ -DHAVE_CONFIG_H -I. -I. -I.. -Wall -I../include -DINSTALL_PREFIX=\"/usr/local\" -Wno-implicit -fPIC -DPIC -D_REENTRANT -O2 -fno-exceptions -fno-check-new -c main.cpp
main.cpp: In function `int main (int, char **)':
main.cpp:32: `SOCKSinit' undeclared (first use this function)
main.cpp:32: (Each undeclared identifier is reported only once for each
function it appears in.)
make[2]: *** [main.o] Error 1
make[2]: Leaving directory `/licq-1.0.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/licq-1.0.2'
make: *** [all-recursive-am] Error 2
[root@Matrix /licq-1.0.2]#
Kogato instaliram samoto licq bez socks5 supprot nqma nikakvi problemi - trugva, no estestveno ne moze da se conectne.
People can fly
licq
vuzmojno e proxy servera da ne podurja socks
ili da e razlichna versia v toia sluchai mojesh da konfigurirash Icq da polzva http proxy sushtoto koeto zadavash na brouzera..
Osven tova triabva da imash pone 1k koeto da ne minava prez proxyto inache niama da se vurje....
licq
Ами не знам, пробвай да смениш SOCKS 5, сложи по-нова или по-стара версия. А забравих, първо пробвай licq 1.0.3.
Може също да пробваш, ако е твой proxy сървъра, (какъв софтуер ползвате за proxy BTW?) да направиш redirection от 4000/udp до icq.mirabilis.com:4000/udp (като ползваш proxy_ip:4000 за ICQ сървър). Това в Линукс ще стане през настройките на xinetd, ако ползваш inetd можеш да сложиш xined да върви успоредно с inetd и да го ползваш само за port redirection. Ако ползвате Linux ми е чудно защо proxy, а не NAT?
Променено от exabyte на 05/10/2001 11:00:54
