Проблем с .mkv файлове на Panasonic VIERA TX-L42E30E
  Защо някои .mkv файлове, плейъра на Panasonic VIERA TX-L42E30E не ги чете от флашка?
  Код:
 Чете:
The Devil's Double LIMITED 2011 720p BluRay x264-Counterfeit\ctf-the.devils.double.720.mkv (4,36gb) DTS
General
Complete name          :\The Devil's Double LIMITED 2011 720p BluRay x264-Counterfeit\ctf-the.devils.double.720.mkv
Format              : Matroska
File size            : 4.36 GiB
Duration             : 1h 48mn
Overall bit rate         : 5 738 Kbps
Encoded date           : UTC 2011-11-08 18:32:37
Writing application       : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 9 2011 11:55:43
Writing library         : libebml v1.2.2 + libmatroska v1.3.0
Video
Format              : AVC
Format/Info           : Advanced Video Codec
Format profile          : High@L4.1
Format settings, CABAC      : Yes
Format settings, ReFrames    : 5 frames
Muxing mode           : Container profile=Unknown@4.1
Codec ID             : V_MPEG4/ISO/AVC
Duration             : 1h 48mn
Bit rate             : 4 114 Kbps
Nominal bit rate         : 4 227 Kbps
Width              : 1 280 pixels
Height              : 544 pixels
Display aspect ratio       : 2.35:1
Frame rate            : 23.976 fps
Resolution            : 24 bits
Colorimetry           : 4:2:0
Scan type            : Progressive
Bits/(Pixel*Frame)        : 0.246
Stream size           : 3.13 GiB (72%)
Writing library         : x264 core 119 r2106 07efeb4
Encoding settings        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4227 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format              : DTS
Format/Info           : Digital Theater Systems
Codec ID             : A_DTS
Duration             : 1h 48mn
Bit rate mode          : Constant
Bit rate             : 1 510 Kbps
Channel(s)            : 6 channels
Channel positions        : Front: L C R, Surround: L R, LFE
Sampling rate          : 48.0 KHz
Stream size           : 1.15 GiB (26%)
Title              : english
Не чете:
Colombiana.2011.720p.BluRay.x264-TheWretched\wthd-colombiana.720p.mkv (4,35gb) DTS
General
Unique ID           : 237784377338194739309223124915586632207 (0xB2E39AF27884325EABE1E6DEFBA88A0F)
Complete name         :\Colombiana.2011.READNFO.720p.BluRay.x264-TheWretched\wthd-colombiana.720p.mkv
Format             : Matroska
Format version         : Version 2
File size           : 4.35 GiB
Duration            : 1h 43mn
Overall bit rate        : 6 026 Kbps
Encoded date          : UTC 2011-11-26 05:00:30
Writing application      : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library        : libebml v1.2.1 + libmatroska v1.1.1
Video
Format             : AVC
Muxing mode          : Header stripping
Duration            : 1h 43mn
Bit rate            : 4 520 Kbps
Height             : 544 pixels
Frame rate           : 25.000 fps
Color space          : YUV
Chroma subsampling       : 4:2:0
Bit depth           : 8 bits
Bits/(Pixel*Frame)       : 0.260
Stream size          : 3.18 GiB (73%)
Encoding settings       : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4520 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language            : English
Audio
Format             : DTS
Codec ID            : A_DTS
Duration            : 1h 43mn
Channel positions       : Front: L C R, Side: L R, LFE
Bit depth           : 24 bits
Compression mode        : Lossy
Stream size          : 1.09 GiB (25%)
Language            : English
  Предварително благодаря за отговорите.
     Re:Проблем с .mkv файлове на Panasonic VIERA TX-L42E30E
  Може би е затова:
Изобщо не очаквай, че ще ти чете всички Mkv.
  При втория файл имаш:
което е т.нар. "header compression", което дори моя външен плейър не го поддържаше докато не му ъпдейтнаха фърмуера и като цяло е нещо проблематично.
Като не ти работи някой файл просто свали друг вариант и не го мисли много. Аз поне така правя.
За да разбереш дали точно това е проблема (за науката!), може да пробваш да ремукснеш файла, използвайки следните инструкции:
			It is the Muxing mode : Header stripping. This is also called "header compression". Though it doesn't save enough space to matter.
For some reason the Matroska developers made this mode the default earlier this summer. It doesn't work with most hardware players (including the EVA and also the WD Live).
You have to re-process the files to remove the header compression. This doesn't hurt the quality at all, and is a pretty fast operation. If you are comfortable running command line tools, you can either use mkWDclean.exe (found at
https://sourceforge.net/projects/mat...7.zip/download) or MKVMerge (found at
http://www.videohelp.com/tools/mkvtoolnix)
The command line strings are:
mkWDclean input.mkv output.mkv
mkvmerge -o output.mkv --compression -1:none input.mkv
There are two other ways that don't require opening a command line shell:
(a) You can use MKVMerge GUI, but it is tedious. You select every track (from the middle pane), select the "extra options" tab, and set "Compression:" to none. (blank is not good enough).
(b) You can download VID2EVA from
http://vid2eva.lefti.net. This is a freeware video conversion tool that I've put together. After installation you right click on the MKV and select "VID2EVA" then "transcode audio". For this particular file, it won't transcode since the audio is already AC3. But it will remove the header compression.
