Отговор: Philips телевизори 2016
48", 55", 65" / PUS7601 - моделът ще се появи през втората четвърт на 2016 година
philips7601f - HostingPics.net - H
Features Philips PUS7601:
Reminder key features of the Philips series PUS7600:
• Direct LED backlight system on the Global Dimming 55 and 65 '
• Backlight System Edge LED Local Dimming on the 48 ''
• Ultra Video Processing Pixel Precise HD Engine
• Treatment Micro Dimming Pro
• 3D motion compensation Natural Motion
LCD Panel • Ultra HD Certified Ultra HD Premium
• Full Led Backlight (240 zones - 65")
• Video Processing 2400 Hz PMR
• 3D Ready
• Active 3D
• Full Screen Gaming Fashion to play two on a game with a full screen image, for each player on the same TV
• Native 10 Bit LCD Panel 100Hz VA
• Color Booster Technology (17-bit internal processing for 2,250 trillion colors)
• Function Ultra Resolution
• Dual tuner DVB-T2 / DVB-C / DVB-S2
• Compatibility HEVC (broadcast / IP)
• Compatibility Miracast
• Compatibility HBBTV
• Smart Screen Function
• Smart Android TV?
• Google Cast Functionality
• 16 GB built-in Flash memory for installing applications (expandable to 128 GB via USB)
• Access to services Les Echos, Video Futur VOD, Netflix, Spotify, Catch-Up TV ...
• Cloud Explorer function (Dropbox)
• Connect Spotify Certification
• UPnP media gateway function (DLNA)
• Quad Core Processor
• An HDMI 2.0
• HDCP compatibility 2.2
• Ambilight Spectra 3 system (active right, left and top of the screen)
• Ambilight + Function Hue
• Ambilight modes Gaming Mode (extremely short latency) and Ambilight Music
• Total power 30 W RMS
• Remote control with keyboard, touch pad central button for direct access to Netflix and microphone to use the Voice Search function
Source:
CES 2016*– Philips 55PUS7601, une série 7600 en Full LED
Hi all . Взех си 48pus7600 . първи ден - всичко ок, вързах го с wifi ъпдетна се без проблеми. Втори ден - натискам дистанционното сутринта ,стендбай индикатора премигва два пъти и нищо , нито звук нито картина , каквото и дс натисна на дистанционното само това двоино премигване и нищо друго . изключих захранващия за 1 мин , после всичко си е нормално , стартира се без проблем . Трети ден сутринта , пускам го и всичко нормално .Четвърти ден (днес) отново проблема от ден втори . пак извадих захранването и после се включи без проблем . преинсталирах , върнах фабрични настройки и сега ще видя утре сутрин какво ще се случи . някакви предложения какво да правя ако проблема продължи ? Благодаря предваритрелно
https://www.philips.bg/c-m/consumer-..._AND_VISION_GR
Дрънни им на централата и директно попитай "къде е копчето за лампата" - демек, к'во го предизвиква в същност това шашкане.
Телевизори
http://www.philips.bg/c-dam/b2c/suj/...W_TV_GR_GB.jpg
Обадете ни се +359 2 4916273 (Национален номер*)
- Понеделник до Петък 09:00 - 17:00
Иначе модела е един път от всякъде!!!
Тея са такива ламери! По добре не им се обаждай. Веднъж се наложи и ме мотаха полвин час с празни приказки.
murphymet
Звънях !!! И си прав. След 15 минутен разговор с крайно не любезна и не възпитана кака , получих номера на сервиза към които да се обърна . обаче реших , че съм по тарикат и отидох до магазина от които купих тв . В крайна сметка и след малко разправия , телевизора беше сменен с нов и за сега да чукна на дърво , проблеми няма . от сервиза все пак ми казаха, че да ъпдейтвам софта било голяма грешка ... Както и да е, този още не съм го ъпдейтнал .
Здравейте, от доста време не бях писал, но ми се появи проблем. Телевизора ми е 40PFL5507K/12. Кой дявол ме накара да го ъпдейтна до последната излязла версия 105. Сега при включване и опит за да вляза в интернет или справочника на канали първо ми изписва, че не е намерен сървър на Филипс. При вторият или третият опит успява да се свърже. При предишната версия - товзи проблем не съществуваше. Свързан е през Wi-Fi с домашният рутер. Не че е кой знае какво, но е дразнещо.
Дали и някой друг се е сблъскал с такъв проблем?
След ъпдейта e необходимо да разкачиш мрежовият кабел, от контакта. Изчакай 1 минута и после включи захранващият кабел отново. След това може да включиш ТВ по обичайният способ.
Программное обеспечение Версия: 000.105.000.000. Опыт использования.
Technical feedback - 0.105.0.0 - 40X7, 43X7 & 50X7, 55X7
И да се само-цитирам за други проблеми
Изключването не помага, така си е, просто знаеш, че е такъв проблема и цъкаш бутона втори път. Септември го ъпнах, до сега нищо не ми се е случило , че го натискам още един път.
Stoianovs
Абсолютно същата ситуация, влиза в смарт-а задължително от втория път. По руските форуми пишат, че чакат оправяне с поредния ъпдейт, но едва ли вече ще има такъв за модели 2012.
Кога се очаква новата 9-та серия?:) Единственият модел на Филипс, който да си струва да се види.
Последната информация беше за началото на Април...
Philips PUS7600 Review - Inleiding - Tweakers
ТВ Филипс вече трябва да имат достъп до Netflix
Enjoy Netflix on any Philips Smart TV - TP Vision Global
The Netflix application is available now on all of these Philips TV models:
Supported Smart TV models:
Linux (non-Android) based Smart TVs
- 2012 MTK Latam TVs: 5007 upto 7007 models
- 2013 MTK EU TVs: 3208 upto 5038 models
- 2013 MTK Latam TVs: 35×8, 4508, 4908, 5×08, 7008 and 8008 models
- 2013 MTK AP TVs: 4208, 5008 models
- 2013 Fusion AP TVs: 6008 and 8008 models
- 2013 Fusion R3 EU TVs: 6008 upto 9xx8 models
- 2014 MTK EU TVs: 4509 upto 7809 models
- 2014 MTK Latam TVs: 5109 upto 7459 models
- 2014 MTK AP TVs: 6509 upto 8609 models
- 2015 MTK EU TVs: 5300 models
- 2015 MTK Latam TVs: 5100, 6110, 6300 models
- 2015 MTK AP TVs: 5300, 6909, 8509 models
Android based Smart TVs:
- 2014 Android EU TVs: 7909 upto 9809 models
- 2015 Android EU TVs: 5500, 6400, 65×0, all 7xx0 and 8700 models
- 2015 Android Latam TVs: 6700, 7100 models
- 2015 Android AP TVs: 5500, 6200, 6800 models
- 2016 MTK Android EU TVs: 8601 and 8901 models
Реструктурирането на представителствата през миналата година.
https://forum.setcombg.com/attachmen...id=19165&stc=1
Тази година иновационите подразделения бяха допълнително съкратени - това в Айндховен и това в Брюксел бяха слети...Някои от офисите по продажби отговарят за две държави. Например това в Италия отговаря и за Гърция. България - за Македония..за Сърбия не знам за сега.
TP Vision is concentrating its manufacturing capacity with TPV Technology resulting in the closure of its Székesfehérvár TV production site - TP Vision Global
Искам да попитам два въпроса за PHILIPS 43PUS7100, че го купих преди няколко дни и вече съм на път да го върна в магазина...
- как да изкарам субтитри от USB-плеъра? Въртях всички менюта и нищо не се получава. С MX плеъра ги показва, ама картината много накъсва, а VLC незнайно защо не вижда медийните файлове по флашките?!?
- Android-приложенията непрекъснато забиват. Докато гледам нещо и ми излизат съобщения от типа: "Приложението Settings спря да фунционира". И след като забие така, вече нищо не работи нормално - YouTube не тръгва, файловете от флашките не се четат... Трябва да изключвам ТВто от контакта и да се надявам че след 5-10 минути като го пусна всичко ще е ок. Инсталирах ъпдейтите на софтуера, но така започна да забива още по-често! Има ли някакво решение този проблем?
Този модел работи безупречно и няма нищо от споменатите проблеми. Мой познат го има, също и чичо му, който е доста стар. Когато съм ходел все гледат от флашка филми+субтитри, YouTube, Skype и разни му то приложения. Нещо не правиш както трябва. Повечето хора очакват новият им ТВ да е като стария. Включваш и готово. Вземи си прочети упътването! Всичко е обяснено като за детската градина.
Успех!!!
mgagov
След ъпдейт е препоръчително преинсталиране на телевизора. Там където има опция затваряй приложението и не отваряй безразборно няколко едно след друго и няма да имаш грижи.
За съжаление това са бъгове на Андроид тв платформата. Препоръчвам ти Archos Video.
