Здравейте,имам интерес към съответният модел телевизор.Моля които има впечатления да напише.Благодаря предварително...
Samsung UE40JU6670: Review
SAMSUNG UE40JU6670 - 101 cm (UE 40JU6670 UXZF), fiche technique, prix et avis consommateurs
Сигурен ли си, че искаш 40" UltraHD телевизор ?
Samsung 2015 Product LCD Type
____________10bit or 8bit
panelLCD matrix
Refresh RateHDR
Support
________________Backlight Type
_____________________
Local DimmingWide Color Gamut
Support
_______________________HDMI 2.0a Inpits
_________HDCP 2.2 Support
________HEVC (H.265) Decoding
_____________________________________________Flat or Curved
______________UltraHD Streaming Services Tuner
________________Wi-Fi & Smart TV Picture Accuracy Out-of-the-Box (score out of 10)
_______________Samsung JS9500
(65", 78", 88")SVA 10bit 100Hz Full
335 cd/m²FALD
YesYes
94,0% DCI P3
75,0% Rec.2020
(Quantum Dots)2.0a yes HEVC поддържа само MKV/MP4/TS.
- H.264 FHD до ниво 4.1.(FMO/ASO/RS неподдържан)
- H.264 UHD до ниво 5.1
- HEVC FHD до ниво 4.1
- HEVC UHD до ниво 5.1Curved
(4200R)yes Double tuner
DVB-T/T2/C/S2
DiSEqC version 1.0yes
a/ac/b/g/nSamsung JS9000
(48", 55")SVA 10bit 100Hz Full
480 cd/m²Edge Led
yesYes
95,5% DCI P3
74,0% Rec.2020
55" (4200R)
48" (3000R)yes Double tuner
DVB-T/T2/C/S2
a/ac/b/g/nSamsung JS8500
(48", 55")SVA 10bit 100Hz Yes
480 cd/m²Edge Led Yes
92-95% DCI P3
74,0% Rec.2020
(Quantum Dots)2.0a Yes HEVC поддържа само MKV/MP4/TS.
- H.264 FHD до ниво 4.1. (FMO/ASO/RS неподдържан)
55" (4200R)
48" (3000R)Yes Double tuner
DVB-T/T2/C/S2
DiSEqC version 1.0Yes
a/ac/b/g/n65" - 8
55" - 8Samsung JS8000
(55")SVA
55" - IPS10bit 100Hz Limited Edge Led Yes
(Quantun Dots)yes yes HEVC поддържа само MKV/MP4/TS.
- HEVC UHD до ниво 5.1Flat yes Double tuner
DVB-T/T2/C/S2
a/ac/b/g/nSamsung JU7500 SVA 8bit 100Hz No Edge Led Yes
80% DCI P3
(Quantum Dots)No Yes Yes Curved
78,65,55 (4200R)
DVB-T/T2/C/S2
a/ac/b/g/n9 Samsung JU7000 SVA 8bit 100Hz No
380 cd/m²Edge Led No
83,2% DCI P3
60,1% Rec.2020No Yes Yes Flat yes Double tuner
DVB-T/T2/C/S2
a/ac/b/g/nSamsung JU6800 VA 8bit 50Hz No Edge Led Yes
94,6% DCI P3
72,8% Rec.2020
(Quantum Dots)? Yes Yes Flat DVB-T/T2/C/S2
a/ac/b/g/nSamsung JU6600 VA 8bit 50Hz No Edge Led
(flashing backlight)No 2,0 Yes Yes Curved
55" (4200R)
48,40" (3000R)DVB-T/T2/C/S2
a/ac/b/g/nSamsung JU6500 VA 8bit 50Hz No Edge Led
80% DCI P32.0 yes yes Curved
55" (4200R)
a/ac/b/g/nsamsung JU6400 VA 8bit 50Hz No 55" Direct led
Edge Led
(flashing backlight)No 2.0 yes yes Flat DVB-T/T2/C yes
a/b/g/nSamsung JU6000 VA
55" - IPS8bit 50Hz No Edge Led No ? Flat No DVB-T/T2/C yes
a/b/g/nSony 2015 Prоduсt LСD Type
(Maker)10bit оr 8bit LСD mаtrix
Rеfresh RаtеHDR
ЅupportВасkligh Type
Local DimmingWidе Colоr Gаmut
SupportHDMI 2.0a Inputs
HDCP 2.2 Suppоrt
НЕVС (H.265) Decoding Flаt оr Сurvеd UltraHD Streaming Services Tunеr Wi-Fi & Smаrt TV Picture Accuracy Out-of-the-Box (score out of 10)
Sony X9405C
(75")
MVA 10bit 100Hz Full 75" FALD (80,areas)
55", 65" Edge Led91% DCI P3
(Quantum Dots)? Yes Yes Flat Yes Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n9 Sony X9305C
(55", 65")MVA 10bit 100Hz Full Edge Led
Frame Dimming91% DCI P3
(Quantum Dots)2.0a yes yes Flat yes Double tuner
DVB-T/T2/C/S2
a/ac/b/g/nSony X9105C
(75")MVA 10bit 100Hz Limited Edge Led
Frame DimmingYes
(Quantum Dots)2.0a yes yes Flat Yes Double tuner
DVB-T/T2/C/S2
a/ac/b/g/nSony X9005C
(55", 65")IPS
(55",65")10bit 100Hz Limited Edge Led
Frame DimmingYes
DVB-T/T2/C/S2
a/ac/b/g/nSonу X8505C
(55", 65", 75")MVA 8bit 100Hz Limited Edge Led
Frame Dimming85,3% DCI P3
69,4% Rec.2020
(Quantum Dots)2.0a Yes Yes Flat Yes Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n8 Sony X8305C
(43", 49")IPS 8bit 100Hz No Dynamic Edge Led
Frame Dimming73.5% DCI P3 2.0 Yes Yes Flat Yes Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n7 Sony X8005C
(49", 55")IPS 8bit 50Hz No or
Limited ?Full Led Simple
Frame DimmingNo 2.0 Yes Flat Double tuner
DVB-T/T2/C/S2
a/ac/b/g/nPanasonic 2015 Product LCD Type
(Maker)10bit or 8bit LCD matrix
Refresh RateHDR
SupportBacklight Type
SuppоrtHDMI 2.0a Inputs HDCP 2.2 Support HEVC (H.265) Decoding Flat or Curved UltraHD Streaming Services Tuner Wi-Fi & Smart TV Picture Accuracy Out-of-the-Box (score out of 10) Panasonic CZ950E
(65")Oled
(LG)10bit 100Hz ST2084 и ST2086 SMPTE стандарти - 90% DCI P3 4x2.0a Yes Yes Curved Yes Twin
DVB-T/T2/C/S2
съвместими с MPEG4-AVC[H.264]?
a/b/g/n65" - 9 Panasonic CR850E
(55", 65")MVA
(Samsung or AUO?)8bit 100Hz ST2084 и ST2086 SMPTE стандарти
(Необходима е актуализация на фърмуера)
360 cd/m²Full Array Local Dimming 88.1% DCI P3
67.8% Rec.2020
(improved phosphorus Leds)2.0a Yes Yes Curved Yes Twin
DVB-T/T2/C/S2
DVB през IPyes
a/b/g/n9 Panasonic CX800E
(50", 55", 65")S-MVA
(Innolux)
(IPS in Japan)8bit 100Hz ST2084 и ST2086 SMPTE стандарти
340 cd/m²65"
55" Direct Led(9x2,zones)
50" EdgeLed(Down)97.6% DCI P3
81.7% Rec.2020
(improved phosphorus Leds)2.0a Yes Yes Flat Yes Twin
DVB-T/T2/C/S2
DVB през IPyes
a/b/g/n9
50" - 8Panasonic
CX750E & CX740E
(49", 55")IPS 10bit 100Hz No
259 cd/m²Edge Led (improved phosphorus leds) 2.0 Yes Yes Flat Yes 750 -Twin
DVB-T/T2/C/S2
DVB през IPyes
a/b/g/nPanasonic
CX700E
(40", 50", 55", 60")S-MVA
(Innolux)
V500DK1-KS510bit ? 100Hz No
470 cd/m²55" Direct Led(4x2,areas)
50", 40" - Edge led(Down)
Local Dimming95.0% DCI P3
74.0% Rec.2020
(improved phosphorus Leds)2.0 Yes Yes Flat Yes DVB-T/T2/C
DVB през IPyes
a/b/g/nPanasonic CX680E
(40", 50", 55")S-MVA 8bit 50Hz No
400 cd/m²55" - Direct Led
50" - Edge Led(Down)
Local DimmingNo
50% DCI P3
(improved phosphorus Leds)No Yes Yes Flat Yes DVB-T/T2/C yes
a/b/g/nРаnasonic CX400E
(40", 48", 55")MVА 8bit 50Hz Nо 48", 55" Direct Led Nо No Yes Yes Flаt DVВ-T/T2/С Yes
а/b/g/nLG 2015 Product LCD type
(Maker)10 or 8bit LCD matrix refresh rate
_________HDR Support Backlight
TypeWide Color Gamut Support HDMI 2.0a Inputs HDCP 2.2 Support HEVC (H.265) & VP9 Decoding Flat or Curved UltraHD Streaming Support Tuner Wi-Fi & Smart TV Picture Accuracy Out-of-the-Box (score out of 10) LG EG960V Oled 10bit 100Hz Yes - Yes
63.49% Rec.20202.0 Yes Yes - Yes Curved DVB-T/T2/C/S2 yes
a/b/g/nLG ЕF950V Оlеd 10bit 100Hz Yes - Yes
88% DCI P3
58.93% Rec.20202.0a Yes Yes - Yes Flat DVВ-T/T2/С/S2 Yesа/b/g/n 65" - 9 LG EG930V Oled 10bit 100Hz Yes - Yes
87% DCI P3
61.43% Rec.20202.0 Yes Yes - Yes Curved DVB-T/T2/C/S2 yes
a/b/g/nLG UF950V
UF940VS-IPS 8bit 100Hz No Edge Led
(Down)Yes
(бели светодиоди с подобрен фосфор, плюс оптимизиран цветен филтър)No Yes Yes - Yes Flat Yes DVB-T/T2/C/S2 yes
a/b/g/n55" - 9 LG UF870V
UF860VS-IPS 8bit 100Hz No Edge Led Yes
(Quantum Dots)No Yes Yes - Yes Flat Yes DVB-T/T2/C/S2 Yes
a/ac/b/g/nLG UF850V S-IPS 10bit 100Hz No Edge Led Yes
53.86% Rec.2020No Yes Yes - Yes Flat DVB-T/T2/C/S2 Yes
a/b/g/n65" - 8 LG
UF830VS-IPS 8bit 100Hz No Edge Led No No Yes Yes - Yes Flat DVB-T/T2/C/S2 Yes
a/b/g/nLG UF770V S-IPS 8bit 100Hz ?
43" - 50HzNo Edge Led
Local DimmingNo
75% DCI P3
50,35% Rec.2020No Yes Yes - Yes Flat DVB-T/T2/C/S2 yes
a/b/g/nLG UF690V S-IPS 8bit 50Hz No Edge led No No
2,0Yes Yes - Yes Flat DVB-T/T2/C/S2 yes
a/b/g/nLG UF680V
като резолюция не е пълноценен UltraHDS-IPS RGBW subpixel structure
(RGB + White)8bit 50Hz No Edge led No
51.83% Rec.2020No
2,0yes No - Yes Flat DVB-T/T2/C/S2 yes
a/b/g/nLG UF670V S-IPS 8bit 50Hz Nо Еdgе lеd Nо No Yes Nо Flаt DVВ-T/T2/С/S2 Yes
а/b/g/nLG UF640V S-IPS 8bit 50Hz No Edge Led No No Yes No Flat No DVB-T/T2/C/S2 Yes
a/b/g/nPhilips 2015 Product LCD Type
(Маkеr)10bit or 8bit LCD matrix
Refresh RateHDR Support Backligh Type Wide Color Gamut
SupportHDMI 2.0a Inputs HDCP 2.2 Support HEVC (H.265) & VP9 Decoding Flat or Curved UltraHD Streaming Services Tuner Smart TV Picture Accuracy Out-of-the-Box (score out of 10) Philips PUS9600
(65", 75")
March 2016MVA ?
(AUO?)10bit 100Hz Yes
1000 cd/m²Full Array Local Dimming
256, areasYes 2.0a Yes Yes - Yes Yes Double tuner
DVB-T/T2/C/S2
DiSEqC version 1.0Yes Philips PUS8700
(55", 65")MVA 10bit? 100Hz ? Edge Led Yes
Color Booster с вътрешна обработка на цветовете 17 бита2.0 Yes Yes - Yes Curved (8700) Yes Double tuner
DVB-T/T2/C/S2
b/g/nPhilips PUS8601
(55", 65")MVA? 10bit? 100Hz Yes? Edge Led Yes
Color Booster с вътрешна обработка на цветовете 17 бита2.0 Yes Yes - Yes Flat Yes Double tuner
DVB-T/T2/C/S2
a/ac/b/g/nPhilips PUS7600
(48", 55", 65")MVA 10bit 100Hz No Edge Led Yes
81.2% DCI P3
Color Booster с вътрешна обработка на цветовете 17 бита2,0 Yes Yes- Yes Flat Yes but only 1080p... Double tuner
DVB-T/T2/C/S2
b/g/nPhilips
PUS7100
PUS7120
PUS7150
PUS7170
PUS7180IPS 8bit 50Hz No Edge led No 2,0 Yes Yes - Yes Flat Yes but
only 1080p...DVB-T/T2/C/S2
DiSEqC version 1.0
7170&7180
Double TunerYes
b/g/nPhilips PUT6400
(40", 50", 55")MVA 8bit 50Hz No Direct led No
75% DCI P32,0 Yes Yes - Yes Flat Yes but only 1080p... DVB-T/C Yes
b/g/n50" - 8 Philips
PUS4900
PUK4900
PUT4900IPS 8bit 50Hz No No No Yes No Flat No DVB-T/C No Sharp 2015/2016 Prоduсt LСD Type
Rеfresh RаtеHDR Support Васklight Type Widе Colоr Gаmut
SuppоrtHDMI 2.0a Inputs HDCP 2.2 Support НЕVС (H.265) & VP9 Decoding Flаt оr Сurvеd UltraHD Streaming Services Tunеr Smаrt TV Picturе Accuracy Оut-оf-thе-Box (scorе оut оf 10) Sharp
XUE8982
XUE8882
XUE8772
(43",49",55'',60'',65'')S-IPS
(RGBW)
4K Resolution100Hz Nо Nо Yes Yes Flаt Nо DVВ-T/T2/С/S2 Yes
b/g/nSharp
CUF8682
(60",70",80")UV²A
UltraHD100Hz No No Yes Yes Flat DVB-T/T2/C/S2 Sharp CUF8382
(43",49",55")IPS
CUF8462
CUE8462
(43",49",55")IPS
UltraHD8bit 50Hz No No 2.0 Yes Yes Flat DVB-T/T2/C/S2
Забележки:`
Panasonic 2015
(09.10.2015): За информация относно вида подсветка в серия CX400, Panasonic даде две различни информации по имейл, първо "Edge LED" после "Direct LED" (и техния уебсайт показва Direct LED).
Допълнителната яркост при panasonic ще дойде по-късно тази година, когато 8-ма серия ще получи актуализация на фърмуера, за да се добави поддръжка за High Dynamic Range (HDR).
Sony 2015
С актуализация на фърмуера v2605(13.10.2015) е активиран HDR, а PVR ще бъде активиран преди 24 декември.
За да получите възможност за хрома4:4:4, задайте режим Game или Graphics.
Update: С новият фирмуерен ъпдейт PKG2.463.0010NAB, сега телевизорите поддържат 4k@60Hz@4:4:4. За да получите тази възможност отидете на Home button - Settings - External Inputs - HDMI Signal Format - Enhanced (new).
Samsung 2015
JS9500/JS9000 не поддържат 1080p@120fps, което е малко разочароващо. За да получите 4k@60Hz@4:4:4, трябва да зададете тип устройство PC mode и включите UHD Color. Ако не проработи - си сменете кабела.
LG 2015
UF9/UF8 не поддържат 1080p@120 кадъра в секунда, но поддържа наситеност 4:4:4, ако се постави етикет на входа като PC. За да получите 4k@60Hz@4:4:4, вие също ще трябва да включите "HDMI Ultra HD Deep Color".
UF85 е същият като UF77, но с 3D
UF77 - 100Hz
UF76 - 50Hz
UF68 - http://i.rtings.com/images/reviews/u...xels-large.jpg
Всички 40" и 70" варианти на LG, са с VA матрица.
Sharp 2015/2016
Имат модели обявени като 4K, което е малко объркващо. Разликата в резолюцията е следната - UltraHD (3840х2160) и 4K (4096х2160)
http://www.gedsa.gr/sites/default/fi..._catalogue.pdf
⭐ƎƂƆƀƊƌżƍƀƄƍ 2015/2016
UHD Alliance
http://www.uhdalliance.org/wp-conten...ss-Release.pdf
Ultra HD Blu-ray in numbers
От таблицата нищо не можах да разбера.Какво му е на този модел
БРАВО на @hristoslav2 за грандиозния труд
и тази уникално-редактирана информация в горната таблица!!!
Има разлика м/у двата модела :
http://www.technopolis.bg/bg/compare
Здравейте отново,след като близо месец търсих и разглеждах най-накрая се сдобих със съответният телевизор Самсунг,модела е UE40JU6670 за сега съм много доволен
Честито и дълго да му се радваш :Drinks:нищо че не ме послуша
Честито и от мен. Аз съм с 48h6670 от около година и съм много доволен до момента, абсолютно никакви проблеми.
