Страница 49 от 72 ПърваПърва ... 39474849505159 ... ПоследноПоследно
Резултати от 721 до 735 от общо 1080
Like Tree203Одобрявам
Samsung телевизори 2017
    Haskovo
    #721
    Отговор: Samsung телевизори 2017
    Той е наличен от повече от седмица в други държави,за БГ излезе преди 3-4 дена.Имам го свален,но точно в това гадно време не смея да го кача с флашка.Какъвто съм си карък,точно тогава ще вземе да спре тока
    #722
    https://nl.hardware.info/reviews/742...beter-dan-oled
    QE55Q7F: subpixel panel structure RGB,(за съжаление нидерландците не са направили снимка с поне 50 кратно увеличение за да видим точнта структура- MVA)
    ...viewing Angles
    What we find particularly interesting is how Samsung has managed to improve the viewing angles. This is not so much seems to be a change in the panel technology, but rather in the way the panels are controlled. The QLED TVs, namely, fit a foreign kind of dithering, in which pixels are located next to each other and to-be brighter and less bright displayed. The viewing angle of pixels 'full open' stand is in fact better than that of pixels partially pinched. Through to quarter-to control, there are more pixels with high brightness, resulting in improved viewing angles of the screen. In practice, the effect of this control hardly visible, only if you close to plain gray surface looks can clearly see that not all pixels illuminate same. A realistic viewing distance it is virtually invisible effect, though, the effective resolution is of course by off. Possibly for this reason, the TV does not always dithering mode. Depending on what is being displayed on the screen, the screen sometimes chooses to send to the panel in a traditional manner, with all the pixels so really work individually. During our test showed that the actual television to display video sources always worked in dither mode, while playing a desktop PC usually opted for the normal mode. In some cases, the TV turns off and switch to, we noticed that when playing HDR test patterns from an ultra-high definition Blu-ray disc...
    ...Although dithering method clearly something helps to improve viewing angles, is in our opinion a shame that you as a consumer have the choice to enable or disable this feature, the TV it always decides for himself. If you are always right screen is it - especially at smaller viewing distances - in our opinion better to have eliminated the dithering because it improves the image sharpness. Perhaps Samsung the option to enable or disable this feature manually adds later via a firmware update.
    source photo:[nl.hardware.info]
    Apr 2016
    #723
    Някой да е инсталирал 1180 за KS, че в youtube този твърди, че се влошава драстично качеството на картината след ъпдеита?
    https://www.youtube.com/watch?v=osyd1F0_CwI
  5. Super Moderator
    Dec 2000
    Sofia
    #724
    Аз инсталирах. Не виждам промяна в качеството на картината.
    kajos одобрява това.
    #725
    Модели 2016г получиха ли ъпдейт до Tizen 3.0 , че новите (2017) гледам ги дават с 3.0 ?
  7. Junior Member
    Sep 2013
    #726
    Къде точно гледате за ъпдейти, че днес моя се ъпдейтна, но не намирам информация за промените?
  9. Member Аватара на brabusbg
    Nov 2010
    #727
    Това реално ще се случи ли въобще??
    #728
    Ми аз за това и питах дали е получена . Реално не би трябвало да има пречки , щото повечето модели са същите хардуерно ... освен да послъгват в описанията - някой взел ли е нещо от 2017г да каже с коя версия са ?
  11. Super Moderator
    Dec 2000
    Sofia
    #729
    Самсунг не ъпдейтват версията на Tizen до актуалната в момента. Или поне не пипат по потребителският интерфейс. Така, че едва ли ще се случи. Който иска нова версия, да си купува новият модел ТВ
    #730
    Цитат Първоначално публикувано от mrowcp Виж публикацията
    За съжаление, Samsung са от малцината компании, които не публикуват списък на промените (changelog)
    Център за изтегляния | Samsung България
    Къде мога да намеря последната версия на фирмуеъра на моя телевизор?
    QE65Q7FAM - 65A1MU8XM
    http://www.vybortv.ru/forum-o-televi...art=170#p68422
    43MU6100 - 43L6AUOVM
    Този пост е редактиран от hristoslav2; 26-06-17 в 21:38.
  13. Member Аватара на brabusbg
    Nov 2010
    #731
    Firmware update 1180 fixes auto switch HDMI at last!And also the colours that flicker also once in a while
    Изпратено от моят SM-G950F с помощта на Tapatalk
  15. Junior Member
    Feb 2015
    #732
    Малко снимки на панели
    43MU6102 - IPS
    49MU6472 - IPS
    50MU6102 - VA
    55M5512 - VA
    Леко кофти се вижда вече с таз камера
    hristoslav2 и svetlio1 харесват това.
    #733
    Добре са, моите и по-лоши стават . Горните повече ми приличат на AMVA, отколкото на IPS
  17. Junior Member
    Feb 2015
    #734
    После пак ще мина през някой магазин да опитам нова снимка, но с такъв диагонал на 4К си е тегаво с циклопа, който ползвам.
    За 49-ката съм сигурен, че не е VA панел.
    Apr 2016
    #735
    Още един клип с предупреждение да не се ъпдейтва до 1180
    https://www.youtube.com/watch?v=D82GLKzpQfA
    Аз ъпдейтнах преди няколко дни и не виждам с нещо да ми е влошено качеството на картината, единствено при игра с hdr подръжка вече не излиза надписа с предупреждението, че се пуска hdr съдържание.
    Отговори: 14
    Последно: 08-06-19, 13:13
  2. Samsung телевизори 2016
    Отговори: 821
    Последно: 01-01-17, 16:42
  3. Samsung Телевизори 2015
    Отговори: 1121
    Последно: 02-01-16, 08:17
  4. Има ли пасивни 3D телевизори на Samsung?
    Последно: 21-10-14, 22:00
  5. Отговори: 6
    Последно: 16-08-11, 13:39
