Тези Q900R дето са по магазините (Plesio, Technopolis, etc) от няколко месеца, имат ли Ultra Wide Viewing Angle? интересно ми е да разбера за какво става дума?
Ето ти няколко ревюта
Review: Samsung Q900R
https://www.flatpanelshd.com/review....&id=1544593461
Samsung QE75Q900R test
https://www.avcesar.com/test/ecran_p...0r/page-1.html
Samsung 75QE900R
https://www.lesnumeriques.com/tv-tel...5819/test.html
Samsung Q900R
https://www.pocket-lint.com/tv/revie...-q900-led-85in
Samsung QN85Q900R
https://hdguru.com/review-samsung-8k...th-brightness/
Test Labo du Samsung 65Q900R
http://labo.fnac.com/tv/televiseur-t...msung-65q900r/
Test Samsung QE75Q900R
https://www.01net.com/tests/test-sam...eant-6096.html
Samsung Q900R (QE75Q900R) review
https://www.t3.com/reviews/samsung-q...qled-tv-review
Test Samsung QE65Q900R
https://www.avforums.com/review/sams...d-review.15596
Samsung QE75Q900R review
https://www.homecinemamagazine.nl/20...ra-hd-qled-tv/
source photo:[homecinemamagazine.nl]
Този пост е редактиран от hristoslav2; 13-02-19 в 21:06.
Q900R - модел 2018
Q950R - модел 2019 (с нов One Connect Box)
От гледна точка на дизайна, Q950R е идентичен с Q900R
https://www.homecinemamagazine.nl/20...ed-tv-line-up/https://www.dday.it/redazione/29725/...ibilita-prezzi
https://hdtvpolska.com/znamy-wszystk...-rynek-polski/
Не всички изброени серии и размери ще бъдат налични в България!
Samsung LCD TV 2019 Line-up Type 8K Quantum Dots Quantum Dots UltraHD Quantum Dots Lifestyle Ultra HD LCD - UltraHD Series______________________ Q950R____________________ Q90____________________ Q85____________________ Q80____________________ Q70____________________ Q60____________________ The Frame____________________ The Serif____________________ RU80____________________ RU73____________________ RU71____________________ Models QE-98Q950R
QE-85Q950R
QE-82Q950R
QE-75Q950R
QE-65Q950R
QE-55Q950R QE-82Q90R
QE-75Q90R
QE-65Q90R
QE-55Q90R QE-75Q85R
QE-65Q85R
QE-55Q85R QE-65Q80R
QE-55Q80R QE-82Q70R
QE-75Q70R
QE-65Q70R
QE-55Q70R
QE-49Q70R QE-82Q60R
QE-75Q60R
QE-65Q60R
QE-55Q60R
QE-49Q60R
QE-43Q60R QE-65LS03R
QE-55LS03R
QE-49LS03R
QE-43LS03R QE-55LS01R
QE-49LS01R
QE-43LS01R
QE-32LS01R UE-82RU8000
UE-75RU8000
UE-65RU8000
UE-55RU8000
UE-49RU8000 UE-65RU7300
UE-55RU7300
UE-49RU7300 UE-82RU7100
UE-75RU7100
UE-65RU7100
UE-55RU7100
UE-49RU7100
UE-43RU7100Design Solid Q Q - Solid - - Stylish Q New Edge - - New Edge Curved - Frame Color
Stand Type (Color)BlackSleek
Simple (Black)Carbon Silver
Bending Plate- - Slate Black
Simple StandCharcoal Black - - Titan GrayFlat Foot Simple - - Display Manifacturer - Samsung Display Samsung Display Samsung Display Samsung Display Samsung Display Samsung Display - - - - Composition / Type a-Si TFT LCD, MVA + Quantum Dots a-Si TFT LCD, MVA Dot Resolution 7680 x 4320, (QUHD) 3840 x 2160, UHD 3840 x 2160 3840 x 2160, UHD 3840 x 2160, UHD 3840 x 2160, UHD 3840 x 2160, UHD 3840 x 2160, UHD 3840 x 2160, UHD 3840 x 2160, UHD 3840 x 2160 Antiglare Filter Ultra Black Elite Ultra Black No No No No No Ultra Viewing Angle New LCD panel structure that improves viewing angles. No No No No No No No Backlight Local Dimming FALD (16x)
82" - (19z34) 646 zones
75" - (18x32) 540 zones
65" - (16x30) 480 zonesFALD (16x)
82" - (19x34) 646 zones
55" - (12x26) 312 zonesFALD (8x)
75" - (14x24) 336 zones
65" - (12x20) 240 zones
55" - (10x16) 160 zonesFALD (8x)
55" - (10x16) 160 zonesFALD (4x)
82" - (14x18) 252 zones
75" - (12x16) 192 zones
65" - (10x12) 120 zones
55" - (8x10) 80 zones
49" - (6x8) 48 zonesEdge LED Edge LED Edge LED Edge LED Edge LED Edge LED Luminance (cd/m²) 75"↑- 1000 - 400065" - 700 - 3000 Maximum - 2000 Maximum - 1500 Maximum - 1500 Maximum - 1000 - - - - - - Contrast 6300:1 - - - - - - - - - - Color Bit 10-bit 8-bit + FRC 8-bit + FRC 8-bit + FRC 8-bit + FRC 8-bit + FRC - Color Gamut 93% - DCI P367% - Rec. 2020 - - - - - - - - - - Frame Rate All - 120/100 Hz 55" and ↑ - 120/100 Hz,
49" - 60/50 Hz55" and ↑ - 120/100 Hz,
43" and 49" - 60/50 Hz55" and ↑ - 120/100 Hz,
43" and 49" - 60/50 Hz55" - ?
32, 43, 49" - 60/50Hz55" and ↑ - 120/100 Hz,
49" - 60/50 HzAll - 60/50Hz, CPU & GPU Marketing Name - - - - - - - - - - - CPU - - - - - - - - - - - CPU Cores 4 4 4 4 4 4 - - - - - CPU Bit - - - - - - - - - - - ROM - - - - - - - - - - - RAM - - - - - - - - - - - OS & Smart Tizen OS Version 5.0 App Access,
Full Web BrowserYesYes No ?No ? Airplay 2 Yes iTunes App Yes Bixby 2.0,
Google Assistant,
Alexa Support,YesYesYes YesYesYes NoYesYes NoYesYes - Screen Miroring Yes Picture Interpolation (FRC),
Auto Motion Plus,up to 8K 120fps up to 4K 120fps - - - - - - - - - HDR HDR 10, HDR10+, HLG -- - - - - - - - - - - - -- - - - - - - - - - - - Audio Audio Power Output 3x26 W + 2x10 W (RMS) 4 x 10W + Sub 2 x 10W - - 2 x 10W + Sub 20W 20W - - 2 x 10W - - Speaker configuration (3.2ch)Tweeter x 3
Woofer x 24.2 chTweeter x 2
? x 2
Wooger x 2- - 2.1 ch
Tweter x 2
Woofer x 12.0 ch
Full Range x 2- - 2.0 chFull Range x 2 - - Speaker Type - - - - - - - - - - - ARC Output Format Two channel linear PCM: 48 kHz 16 bits, Dolby Digital, Dolby Digital Plus - - - - - - - - - - Digital audio out(Optical) format Two channel linear PCM: 48 kHz 16 bits, Dolby Digital(AAC / PCM / AC3) - - - - - - - - - - AI Sound Analyzes the type of content and tries to enhance it in various ways. There are also built-in microphones that analyze surroundings. - - - - No No Dolby Audio Support Dolby Digital Plus - - - Dolby Digital Plus Gaming AMD FreeSync,
Variable Refresh Rate,1080p@ 48-120Hz, 3840p@ 48-60Hz,
(maximum bandwidth of 120 fps at 2.5K resolution)2019 Q9 will have “higher-bandwidth” HDMI ports but it did not elaborate other than saying that it will be capable of receiving 4K120 (at 4:2:0 chroma) & 8K60No No Input Lag 15.4 ms No No Auto Low Latency Mode (ALLM) YesALLM automatically switches to game mode. - - - - - No No Game Mode Yes (Auto Game Mode, Game Motion Plus, Dynamic Black EQ, Game Enhancer) No No No No Медия плейър Източници: Ethernet мрежа (кабелна) • Wi-Fi мрежа (безжична) • USB порт Файлови системи: Телевизорът поддържа файловите системи FAT, exFAT и NTFS USB входящи сигнали: Входен сигнал - Размер картина
USB (720p) 16:9 стандартно, По избор, 4:3
USB (1080i/p @ 60 Hz) 16:9 стандартно, По избор, 4:3
USB (3840 x 2160p @ 24/30 Hz) 16:9 стандартно, По избор
USB (3840 x 2160p @ 60 Hz)
USB (4096 x 2160p @ 24/30/60 Hz) 16:9 стандартно, По избор
*USB (7680 x 4320p @ 24/30/60 Hz) 16:9 стандартно, По изборВидео: • Файлови разширения: 3GP ASF AVI FLV M2TS MKV MOV MP4 MPEG MPG MTS RMVB SVI TP TRP TS VOB VRO WEBM WMV Формати / Контейнери: 3GP • ASF • AVI • FLV • MKV • MOV • MP4 • PS • RMVB • SVAF • TS • VOB • VRO • WEBM Видео кодеци : H.263 SORRENSON • H.264 BP / MP / HP • HEVC (H.265) • MICROSOFT MPEG-4 V1 / V2 / V3 • JPEG MOTION • MPEG1 • MPEG2 • MPEG4 SP / ASP • MVC • RV8 / 9/10 (RV30 / 40) • VP6 • VP8 • VP9 • WMV7 • WMV8 • WMV9 (VC-1) H.263 • H.264 (BP / MP / HP) • HEVC / H.265 • ДВИЖЕНИЕ JPEG • MPEG-4 • MPEG1 • MPEG2 • MPEG4 (SP / ASP) • MVC • RV8 / 9/10 • VP6 • VP8 • VP9 • WMV (V7 / V8) • WMV9 (VC1) • Аудио кодеци: AAC • AC-4 • ADPCM (IMA / MS) • DOLBY DIGITAL • DOLBY DIGITAL PLUS • G.711 (A-LAW / U-LAW) • HE-AAC • LPCM • MPEG (MP3) • MPEG-H • OPUS • REAL AUDIO 6 • VORBIS • WMA AAC • AC-4 • ADPCM • DOLBY DIGITAL • DOLBY DIGITAL PLUS • G.711 • HE-AAC • LPCM • MPEG • MPEG-H • OPUS • REALAUDIO 6 • VORBIS • WMA Друга информация: 3840 x 2160 резолюция в Motion JPEG и VP9 (Профил 0 и 2) Аудио: • Файлови разширения: AAC • AIF • AIFF • APE • FLAC • M4A • MID • MIDI • MP3 • MPA • OGG • WAV • WMA • Формати / Контейнери AIFF • ALAC • APE • FLAC • MIDI • MPEG • MPEG4 • OGG • WAV • WMA • Кодеци: AAC • AIFF • ALAC • APE • FLAC • MIDI • MP3 • VORBIS • WAV • WMA Друга информация: WMA1 и WMA без загуби не се поддържат WMA без загуби не се поддържа
FLAC и OGG до 2
USB MIDI канали самоСнимки: • Файлови разширения: BMP • JPEG • JPG • DFO • PNG • Формати: BMP • JPEG • DFO • PNG • Друга информация: Файлово разширение - Формат - Разделителна способност
*.jpg*.jpeg - JPEG - 15360 x 8640
*.png - PNG - 4096 x 4096
*.bmp - BMP - 4096 x 4096
*.mpo - MPO - 15360 x 8640Частично поддържан формат MPO (без 3D)
JPEG и MPO до 15360 x 8640
PNG и BMP до 4096 x 4096Субтитри: Настройки: Настройките са за размер, синхронизация, кодировка, кант/сянка и цвят на канта/сянката
• Файлове: ASS • SMI • SRT • SSA • SUB • TTXT • TXT • XML ASS • AVI • MKV • MP4 • SMI • SRT • SSA • SUB • TTXT • TXT • XML • Външни формати: Име - Формат
MPEG-4 Timed text - .ttxt,
SAMI - .smi,
SubRip - .srt
SubViewer - .sub
Micro DVD - .sub или .txt,
SubStation Alpha - .ssa,
Advanced SubStation Alpha - .ass,
SMPTE-TT Text - .xml• Вътрешни формати: Име - Контейнер
Xsub - AVI,
SubStation Alpha - MKV,
Advanced SubStation Alpha - MKV,
SubRip - MKV,
VobSub - MKV,
MPEG-4 Timed text - MP4,
TTML при гладко поточно предаване - MP4,
SMPTE-TT TEXT - MP4,
SMPTE-TT PNG - MP4,Други ограничения: ● Телевизорът поддържа само USB устройства от тип MSC (Mass Storage Class). MSC е обозначение за класза устройства за съхранение. Типовете MSC устройства включват външни твърди дискове, четци на флашкарти и цифрови фотоапарати. (USB концентратори не се поддържат.) Тези видове устройства трябвада се свързват директно към USB порта на телевизора. Възможно е телевизорът да не разпознае USBустройството или да не прочете файловете от него, ако устройството е свързано чрез USB удължителенкабел. Не изключвайте USB устройството, докато прехвърля файлове.
● При свързването на външен твърд диск, използвайте порта USB (HDD). Препоръчваме да използватевъншен твърд диск със собствено захранване.
● Определени видове цифрови камери и аудио устройства може да не са съвместими с този телевизор.
● Ако има няколко USB устройства, свързани към телевизора, той може да не разпознае всичкиустройства. USB устройства, които използват силен входящ ток, трябва да се свързват към USB порта [5 V, 1 A].
● Телевизорът поддържа файловите системи FAT, exFAT и NTFS.
● След сортиране на файлове в режим "Вид на папка" може да показва до 1 000 файла на папка. Ако USBустройството съдържа повече от 8 000 файла и папки, някои файлове и папки може да не са достъпни.
● Някои файлове, в зависимост от това как са кодирани, може да не се възпроизвеждат на телевизора.
● Някои файлове не се поддържат от всички модели.
● Съдържание с UHD Video Pack не се поддържа на UHD телевизори Samsung от 2017 г. или по-късни модели.
● Кодеците DivX и DTS не се поддържат от модели телевизори Samsung, пуснати на пазара през 2018 г
● Кодеците могат да не функционират правилно, ако има проблем със съдържанието.
● Ако има грешка в съдържанието или контейнера, видео съдържанието няма да се изпълни или няма да се изпълни правилно.
● Звукът или видеото може да не работят, ако имат стандартни побитови скорости/скорости на кадритенад съвместимите с телевизора.
● Ако таблицата на индекса е грешна, функцията Търсене (Прескачане) не се поддържа.
● В противен случай, когато изпълнявате видеоклип през мрежова връзка, той може да не се изпълнигладко поради скорости на предаване на данните.
● Някои USB устройства/цифрови камери може да не са съвместими с телевизора.
● Кодекът HEVC е наличен само в контейнерите MKV, MP4, TS.
● MVC кодекът се поддържа частично.
Видео декодери
● H.264 UHD се поддържа до ниво 5.1 и H.264 FHD се поддържа до ниво 4.1. (Телевизорът не поддържа FMO,ASO, RS)
● HEVC UHD се поддържа до ниво 5.1 и HEVC FHD се поддържа до ниво 4.1.
● HEVC 8K се поддържа за до ниво 6.1. " Тази спецификация е налична само за модели от серията Q900R.
● VC1 AP L4 не се поддържа.
● GMC 2 или нагоре се поддържа.
Аудио декодери
● WMA се поддържа до 10 Pro 5.1 канала, профил M2.
● Не се поддържат WMA1, WMA без загуби / глас
● QCELP и AMR NB / WB не се поддържат.
● Vorbis се поддържа за до 5.1 канала.
● Dolby Digital Plus се поддържа за до 5.1 канала.
● Поддържаните скорости на семплиране са 8, 11,025, 12, 16, 22,05, 24, 32, 44,1 и 48 KHz и се различаватспоред кодека.Other Features USB - HDD Rec Some HDDs may not be available - Smart Hub Yes (incl. Sports, Music and TV Plus) - Apps Platform Smart TV with Bixby Voice, Apps and Full Web Browser - ConnectShare Yes - Ambient Mode Yes - - - - - TV to Mobile - MirroringMobile to TV - Mirroring YesYes - - Connectivity One Connect 75-98-inch models come bundled with a significantly larger box. Yes Yes No No No Yes No No No No Remote Control TM1950C - - - TM1950A - - HDMI Ports 4 x Ver. 2.0b
Използвайте кабели с дължина до 3 м, за да получите най-доброто качество на гледане UHD.
Не разкачайте и свързвайте HDMI кабели при включени устройства! За тази цел, първо изключете устройствата от захранването, изчакайте 15-ина секунди и тогава разкачете кабелите.
● Много компютърни графични адаптери нямат HDMI порт, а вместо това имат DVI порт. Ако компютърът не поддържа HDMI видео изход, свържете компютъра с HDMI-DVI кабел.- 4 - - - 3 x 2.0 Anynet+™ (HDMI-CEC) Automatic Input Switching,
Power on link,
Power off link,
Speaker control,
Link control only with the TV’s remote control,
Unselected device auto off (for available equipment only),
Automatic lip-sync function,
Energy saving mode (with Quick Start mode),
Audio Return Channel (ARC) is a function that enables digital sound signals to be sent via an HDMI cable back from the TV to a connected audio device.
Устройствата, поддържащи Anynet+ (HDMI-CEC), могат да се свързват към телевизора чрез HDMI кабел. Имайте предвид, че някои HDMI кабели може да не поддържат Anynet+ (HDMI-CEC).
" Можете да конфигурирате универсалното дистанционно управление на телевизора, така че да управлява кабелни приставки, Blu-ray плейъри и системи за домашно кино от други доставчици, които не поддържат HDMI-CEC. За
повече информация вж. "Управляване на външни устройства с Дистанционно Samsung Smart – използване на универсалното дистанционно управление".
" Anynet+ не може да се използва за управление на външни устройства, които не поддържат HDMI-CEC.
" Дистанционното управление на телевизора може да не работи при определени условия. В такъв случай, все пак настройте устройството като поддържащо Anynet+ (HDMI-CEC) устройство.
Anynet+ (HDMI-CEC) работи само с външни устройства, които поддържат HDMI-CEC, и само когато тези устройства са или в режим на готовност, или включени.
" Anynet+ (HDMI-CEC) може да управлява до 12 съвместими външни устройства (до 3 от един вид), с изключение на системите за домашно кино. Anynet+ (HDMI-CEC) може да управлява само една система за домашно кино.
" За да слушате 5.1-канален звук от външно устройство, свържете устройството към телевизора чрез HDMI кабел и свържете 5.1-каналната система за домашно кино директно към изходния конектор за цифрово аудио на външното устройство.
" Ако външно устройство е настроено едновременно за Anynet+ и за универсално дистанционно управление, то може да се управлява само с универсалното дистанционно управление.- HDMI - PC формати Когато свържете телевизора към компютър, настройте разделителната способност на видео картата на една от стандартните разделителни способности, посочени по-долу. Телевизорът ще се настрои на избраната от вас разделителна способност. Отбележете, че оптималната и препоръчителна разделителна способност е 3840 x 2160 при 60 Hz. Избирането на разделителна способност, която не е включена долу, може да доведе до празен екран или включване само на индикатора за захранване.
Направете справка в ръководството за потребителя на графичната карта за съвместими разделителни способности.
Максималната разделителна способност е 3840 x 2160 при 60 Hz, с HDMI UHD Color зададено на Вкл.
VESA DMT
640 x 480 - 60/72/75 Hz
800 x 600 - 60/72/75 Hz
1024 x 768 - 60/72/75 Hz
1152 x 864 - 75 Hz
1280 x 720 - 60 Hz
1280 x 800 - 60 Hz
1280 x 1024 - 60/75 Hz
1366 x 768 - 60 Hz
1440 x 900 - 60 Hz
1600 x 900 - 60 Hz
1680 x 1050 - 60 Hz
1920 x 1080 - 60 Hz
VESA CVT
2560 x 1440 - 120 Hz
CTA-861
3840 x 2160 - 30/60 Hz
1920 x 1080 100/120 Hz
HDMI Input Video Signal
Поддържани разделителни способности за видео сигналиCTA-861
720 (1440) x 576i - 50 Hz
720 (1440) x 480i - 60 Hz
720 x 480 - 50/60 Hz
1280 x 720 - 50/60 Hz
1920 x 1080- 24/25/30/50/60/100/120 Hz
3840 x 2160 - 24/25/30/50/60 Hz
4096 x 2160 - 24/25/30/50/60 Hz
VESA Coordinated Video Timings
2560 x 1440/120 HzInstaPort S (HDMI Quick Switch) Yes No No USB
(HID Support)3 (Type A)
HIDP (Human Interface Device Profile) - Mouse / Keyboard Connectivity
Възможно е функцията да не се поддържа за всички модели или географски региони.
Ако устройството ви не бъде открито, преместете клавиатурата близо до телевизора и изберете Обнови. Телевизорът отново сканира за достъпни устройства.
Ако свързвате мишка, тя е налична само в приложението Internet.3 3 2 2 2 (Type A)(usually connects keyboard, mouse or joystick) Ethernet 1 RJ-45
За свързването използвайте кабел CAT 7 (*тип STP). * Shielded Twist Pair
Телевизорът няма да се свърже с интернет, ако скоростта на мрежата ви е под 10 Mbps.W-Fi, Wi-Fi Direct 802.11 ac, Yes
Настройки - Общи - Мрежа - Отвори - Мрежови настройки - Безжичен
Проверете настройките за SSID (име) и парола на безжичния рутер, преди да опитате свързване. Името на мрежата (SSID) и кодът за защита се намират на екрана за конфигурации на безжичния рутер. Вж. ръководството за безжичния рутер за повече информация.
Ако не е намерен безжичен рутер, изберете Добавяне мрежа в края на списъка и въведете името на мрежата (SSID). Ако безжичният рутер има бутон WPS или PBC, изберете Използване на WPS в края на списъка, след което натиснете бутона WPS или PBC на рутера за около 2 минути. Телевизорът ще се свърже автоматично.Digital Audio Out 1 - Ex-Link (RS-232C) 1 - BluetoothHeadset Support HIDP profileBluetooth enabled (headphones, speakers) - - RF Terestrial 1 RF Satelite 1 - - DVB Tuners 2 x T/T2/C/S2 T/T2/C/S2 T2/C
Този пост е редактиран от hristoslav2; 17-02-19 в 19:51.
https://www.areadvd.de/tests/special...ng-forum-2019/
https://www.4kfilme.de/samsung-q950r...5-bis-98-zoll/
https://www.avcesar.com/actu/id-2675...rer-loled.html
https://developer.samsung.com/tv/dev...specifications
https://developer.samsung.com/tv/dev...v-model-groups
Media Specification
https://developer.samsung.com/tv/dev...tv_premium-uhd
Here are the Danish prices for Samsung's 2019 TV models.[/FONT][/COLOR]
Тук може да си конвертирате датските крони в левове
https://bg.coinmill.com/BGN_DKK.html
Series Model Price (kr) RU71 UE43RU7105 3990, - (1045 лв) RU71 UE50RU7105 4990, - (1308 лв) RU71 UE55RU7105 5990, - (1570 лв) RU71 UE58RU7105 6990, - (1832 лв RU71 UE65RU7105 7990, - (2094 лв) RU71 UE75RU7105 16.990, - (4453 лв) RU71 UE82RU7105 Not priced yet () RU73 UE49RU7305 5490, - (1439 лв) RU73 UE55RU7305 6490, - (1701 лв) RU73 UE65RU7305 8990, - (2356 лв) RU7405 UE43RU7405 4490, - (1177 лв) RU7405 UE50RU7405 5490, - (1439 лв) RU7405 UE55RU7405 6990, - (1832 лв) RU7405 UE65RU7405 9990, - (2618 лв) RU7415 UE43RU7415 4990, - (1308 лв) RU7405 UE50RU7415 5990, - (1570 лв) RU8005 UE49RU8005 7490, - (1963 лв) RU8005 UE55RU8005 7990, - (2094 лв) RU8005 UE65RU8005 11.990, - (3143 лв) RU8005 UE82RU8005 26.990, - (7075 лв) Q60 QE43Q60 5990, - (1570 лв) Q60 QE49Q60 7490, - (1963 лв) Q60 QE55Q60 9490, - (2487 лв) Q60 QE65Q60 13.490, - (3536 лв) Q60 QE75Q60 19.990, - (5240 лв) Q60 QE82Q60 29.990, - (7861 лв) Q70 QE49Q70 9990, - (2618 лв) Q70 QE55Q70 11.990, - (3143 лв) Q70 QE65Q70 16.990, - (4453 лв) Q70 QE75Q70 27.990, - (7337 лв) Q70 QE82Q70 34.990, - (9172 лв) Q80 QE55Q80 15.990, - (4191 лв) Q80 QE65Q80 19.990, - (5240 лв) Q85 QE55Q85 17.990, - 4715 лв) Q85 QE65Q85 21.990, - (5764 лв) Q85 QE75Q85 33.990, - (8910 лв) Q90 QE55Q90 19.990, - (5240 лв) Q90 QE65Q90 27.990, - (7337 лв) Q90 QE75Q90 39.990, - (10482 лв) Q950 QE65Q950 37.990, - (9958 лв) Q950 QE75Q950 52.990, - (13890 лв) Q950 QE82Q950 74.990, - (19657 лв) Q950 QE98Q950 Not priced yet SERIF QE43LS01 8990, - (2356 лв) SERIF QE49LS01 10.990, - (2880 лв) SERIF QE55LS01 12.990, - (3402 лв) FRAME QE43LS03 9990, - (2618 лв) FRAME QE49LS03 10.990, - (2880 лв) FRAME QE55LS03 12.990, - (3402 лв) FRAME QE65LS03 16.990, - (4453 лв)
Този пост е редактиран от hristoslav2; 16-02-19 в 19:10.
https://www.zambullo.de/fernseher/sa...q90r-q950.html
QE-85Q950R
QE-82Q950R
QE-75Q950R
QE-65Q950R
QE-75Q90R
QE-65Q90R
QE-55Q90R QE-75Q85R
QE-65Q85R
QE-55Q85R QE-65Q80R
QE-55Q80R QE-82Q70R
QE-75Q70R
QE-65Q70R
QE-55Q70R
QE-49Q70R QE-82Q60R
QE-75Q60R
QE-65Q60R
QE-55Q60R
QE-49Q60R
QE-55LS03R
QE-49LS03R
QE-49LS01R
QE-43LS01R
UE-75RU8000
UE-65RU8000
UE-55RU8000
UE-55RU7300
UE-75RU7100
UE-65RU7100
UE-55RU7100
UE-49RU7100
75" - (10x14) 140 zones
65" - (8x12) 96 zones
55" - (6x10) 60 zonesFALD (8x)
55" - (6x10) 60 zonesFALD (4x)
82" - (10x16) 160 zones
75" - (8x12) 96 zones
65" - (6x8) 48 zones
55" - (5x7) 35 zones
49" - (4x6) 24 zonesEdge LED Edge LED Edge LED Edge LED Edge LED Edge LED Luminance (cd/m²) 75"↑- 1000 - 400065" - 700 - 3000 Maximum - 2000 Maximum - 1500 Maximum - 1500 Maximum - 1000 - - - - - - Contrast 6300:1 - - - - - - - - - - Color Bit 10-bit 8-bit + FRC 8-bit + FRC 8-bit + FRC 8-bit + FRC 8-bit + FRC - Color Gamut 93% - DCI P367% - Rec. 2020 - - - - - - - - - - Frame Rate All - 120/100 Hz 55" and ↑ - 120/100 Hz,
Google Assistant,
? x 2
Tweter x 2
Woofer x 12.0 ch
FLAC и OGG до 2
SAMI - .smi,
SubRip - .srt
SubViewer - .sub
Xsub - AVI,
SubRip - MKV,
VobSub - MKV,
Видео декодери
Аудио декодери
Power on link,
Power off link,
Speaker control,
VESA DMT
1152 x 864 - 75 Hz
1280 x 720 - 60 Hz
1280 x 800 - 60 Hz
1366 x 768 - 60 Hz
1440 x 900 - 60 Hz
1600 x 900 - 60 Hz
1680 x 1050 - 60 Hz
1920 x 1080 - 60 Hz
VESA CVT
CTA-861
Този пост е редактиран от hristoslav2; 22-02-19 в 21:53.
https://nl.hardware.info/reviews/907...iveau-van-oled
Samsung Europe 2019 LCD tv line-up
QE Q90R
source photo:[nl.hardware.info]
https://hdguru.com/review-samsung-q9...es-ultra-wide/
Но с помощта на тестова HDR шахматна дъска, измереното ниво на черното е 0.04 и 898 нита за бяло. Това дава контрастно съотношение 22,450:1
(почти 100% от DCI-P3 в този случай), измерени в цветово пространство BT.2020. Преходите между цветовите нюанси изглеждаха много гладки с минимални стъпалови градации.
Този пост е редактиран от hristoslav2; 23-02-19 в 15:23.
https://www.tvhifipro.com/comparativ...ung-qled-2019/
https://www.4kfilme.de/preise-samsun...ernseher-2019/
49Q70R 1 499 €
55Q70R 1 799 €
65Q70R 2.399 €
75Q70R 3 999 €
82Q70R 4 999 €
55Q80R 2.299 €
65Q80R 2.799 €
75Q80R 4.499 €
82Q80R 7 999 €
55Q80R 2.299 €
65Q80R 2.799 €
75Q80R 4.499 €
82Q80R 7.999 €
55Q90R 2.999 €
65Q90R 3.999 €
75Q90R 5.499 €
82Q90R 8.899 €
55Q950R (Q HDR ???) 4.599 €
65Q950R (Q HDR 3000) 4.999 €
75Q950R 6.999 €
82Q950R 9.999 €
85Q950R (Nicht in DE) 12.999 €
98Q950R 19.999 €
Сигурно не му е тук мястото, но да не пускам нова тема... с какво почиствайте екраните? Аз лично с микрофибърна кърпа само, но остават петна които не се махат. Малкия като кихне два пъти върху ТВ-то... и няма.махане после.
Изпратено от моят SM-G950F с помощта на Tapatalk
Първо влажна, после със сухата - так процедирам аз ... и много светлина , че да видя кво правя . Отделно, че от микрофибърна кърпа до друга такава има голяма разлика .
Просто обикновен влажен парцал ли имаш предвид? Изчиства ли се перфектно със сухата кърпа след това?
С влажна микрофибърна минавам една лента вертикално (към педя) и после със суха микрофибърна минавам енергично (но без никакъв натиск) влажното място докато не останат следи... и после пак докато не обходя целият екран . Това за лъскавите панели - матовите по същия начин, но те по принцип се чистят по-лесно от пръски и петна.
https://www.guru3d.com/news-story/sa...-software.html
McAfee extended its contract to have McAfee Security for TV technology pre-installed on all Samsung Smart TVs produced in 2019. Along with being the market leader in the Smart TV category worldwide, Samsung is also the first company to pre-install security on these devices, underscoring its commitment to building security in from the start. McAfee Security for TV scans the apps that run on Samsung smart TVs to identify and remove malware.
Цените на моделите от 2019:
https://www.guru3d.com/news_story/sa...ed_series.html
