Страница 60 от 81 ПърваПърва ... 1050585960616270 ... ПоследноПоследно
Резултати от 886 до 900 от общо 1214
Like Tree237Одобрявам
Samsung телевизори (инфо на първа страница)
    #886
    https://www.flatpanelshd.com/article...&id=1677051224
    https://www.avcesar.com/actu/id-3861...medium=twitter
    Gamme TV Samsung Neo QLED 2023 (Mini LED)
    • Samsung QN85C 2023
    - Samsung TQ55QN85C (55'', 140 cm, Ultra HD 4K) : 1 799 euros
    - Samsung TQ65QN85C (65'', 165 cm, Ultra HD 4K) : 2 299 euros
    - Samsung TQ75QN85C (75'', 191 cm, Ultra HD 4K) : 3 399 euros
    - Samsung TQ85QN85C (85'', 216 cm, Ultra HD 4K) : 4 499 euros
    • Samsung QN90C 2023
    - Samsung TQ43QN90C (43'', 109 cm, Ultra HD 4K) : 1 299 euros
    - Samsung TQ50QN90C (50'', 127 cm, Ultra HD 4K) : 1 499 euros
    - Samsung TQ55QN90C (55'', 140 cm, Ultra HD 4K) : 2 299 euros
    - Samsung TQ65QN90C (65'', 165 cm, Ultra HD 4K) : 2 999 euros
    - Samsung TQ75QN90C (75'', 191 cm, Ultra HD 4K) : 4 199 euros
    - Samsung TQ85QN90C (85'', 216 cm, Ultra HD 4K) : 5 499 euros
    Моделът Samsung QE98QN90A остава в каталога и тази година, на ориентировъчна цена от 7999 евро.
    • Samsung QN95C 2023
    - Samsung TQ55QN95C (55'', 140 cm, Ultra HD 4K) : 2 799 euros
    - Samsung TQ65QN95C (65'', 165 cm, Ultra HD 4K) : 3 499 euros
    - Samsung TQ75QN95C (75'', 191 cm, Ultra HD 4K) : 4 999 euros
    - Samsung TQ85QN95C (85'', 216 cm, Ultra HD 4K) : 6 399 euros
    • Samsung QN700C 2023
    - Samsung TQ55QN700C (55'', 140 cm, Ultra HD 8K) : 2 499 euros
    - Samsung TQ65QN700C (65'', 165 cm, Ultra HD 8K) : 3 299 euros
    • Samsung QN800C 2023
    - Samsung TQ65QN800C (65'', 165 cm, Ultra HD 8K, One Connect) : 3 999 euros
    - Samsung TQ75QN800C (75'', 191 cm, Ultra HD 8K, One Connect) : 5 499 euros
    - Samsung TQ95QN800C (85'', 216 cm, Ultra HD 8K, One Connect) : 7 999 euros
    • Samsung QN900C 2023
    - Samsung TQ65QN900C (65'', 165 cm, Ultra HD 8K, One Connect) : 5 999 euros
    - Samsung TQ75QN900C (75'', 191 cm, Ultra HD 8K, One Connect) : 7 999 euros
    - Samsung TQ85QN900C (85'', 216 cm, Ultra HD 8K, One Connect) : 10 999 euros
    Gamme TV Samsung QD Oled 2023
    • Samsung S90C 2023
    - Samsung TQ55S90C (55'', 140 cm, Ultra HD 4K) : 1 999 euros
    - Samsung TQ65S90C (65'', 165 cm, Ultra HD 4K) : 2 799 euros
    - Samsung TQ77S90C (77'', 196 cm, Ultra HD 4K) : 3 999 euros
    • Samsung S95C 2023
    - Samsung TQ55S95C (55'', 140 cm, Ultra HD 4K, One Connect) : 2 499 euros
    - Samsung TQ65S95C (65'', 165 cm, Ultra HD 4K, One Connect) : 3 299 euros
    - Samsung TQ77S95C (77'', 196 cm, Ultra HD 4K, One Connect) : 4 799 euros
    https://fwd.nl/beeld/samsung-smart-h...je-moet-weten/
    Този пост е редактиран от hristoslav2; 22-02-23 в 22:44.
    Jul 2014
    #887
    Frost и sasho1bs харесват това.
    #888
    На светло пак е сив...
    Apr 2020
    #889
    Пълни глупости!
    Понеже обичаш да правиш, преразкази по картинки, ето ти още една в напълно осветена стая, като една от лампите, свети директно в панела от 1.5 метра.
    За сравнение, при същите условия на С1 не се виждаше почти нищо, от ТВ съдържанието, но пък много добре виждах отраженията на осветлението и мебелите в стаята.
    Jan 2017
    #890
    А останалите как да сме сигурни, че твоето не е преразказ по картинки? Не е като да не си пристрастен в мненията си относно този бранд
    Jun 2002
    #891
    Снимката е актуална - от мача в четвъртък за Лига Европа - Ман.Юнайтед-Барселона по БТВ Action. Това е снимка от гледащ в момента човек, а не като на Х2 копи-пейстовете от знайни и незнайни сайтове.
    #892
    Пуснете му малко контраст на този ОЛЕД, няма да избледнее. Чак пък толкова да го пестите
    Apr 2020
    #893
    От този ти пост, става ясно, че нито знаеш, как е изглеждало студиото снощи, нито какво прави контраста. Сега върни БТВ Екшън до мача, и виж как беше студиото. Да не окаже, че на теб ще ти трябва повече „контраст“?!
    Това беше най-тъмната сцена на която попаднах, с идеята да се покаже „сивото“.
    #894
    tvbox
    Има разлика при гледане фронтално и леко под ъгъл.
    Samsung 2023 "Ambilight TV" by using the Philips Hue Sync TV app | HW-Q990C and 65S90C
    Samsung 2023 QD-OLED & Neo QLED TV Lineup - 5 Things You Need to Know
    We explain 5 things you need to know about Samsung's 2023 TV lineup, covering the Samsung S95C & S90C QD-OLED, the QN900C & QN800C 8K Neo QLEDs, as well as the QN95C & QN90C 4K Neo QLED TVs.
    Timestamps:
    0:05 Samsung S95C vs S90C
    3:00 4x HDMI 2.1 vs Sony QD-OLED
    4:55 Fix to Avoid 8K TV Ban
    7:12 This Feature Nuked on 4K Neo QLED
    7:55 Samsung QN95C vs QN90C
    Disclaimer: This video was published to the best of our knowledge based on information given by Samsung spokespeople on the ground at the European Tech Seminar in Frankfurt, Germany, where miscommunication can easily happen. We are awaiting written confirmation from Samsung, which unfortunately may not be forthcoming due to the sensitive nature of the technical details requested.
  12. Junior Member
    Aug 2010
    #895
    Някой да обобщи ще има ли нов топ модел на Samsung 55 или не.
    Кои и ще има ли новости или ще гледаме като при SONY излагации.
    Jan 2017
    #896
    Е горе в пост №887 има линк с клипче точно по този въпрос.
  15. lrn
    lrn е офлайн
    Member
    #897
    Може ли да се активира функцията TimeShift (запис на някоя програма на USB-памет/HDD) на телевизор 50QN90B при положение, че за България не е достъпна (официален отговор на Samsung). Достъпна е за доста други европейски държави примерно Белгия, Германия, Австрия и доста други? Ако все пак е възможно, въпоса е как :-) ? Съмненията са ми, че вероятно трябва да "бръкне" надълбоко по сервизни менюта, а това вероятно ще е свързано с гаранцията. Възможно е първоначално някъде да се укаже друга държава, но тогава дали няма да имам проблеми с гледането на канали с многоезична поддръжка.
    Надявам се да има някой, който го е "играл този филм", въпреки, че такива динозаври като мен, които предпочитат "коаксиала" едва ли са много (но това е отделна тема).
    Благодаря на отзовалите се!
    Този пост е редактиран от lrn; 06-03-23 в 16:46. Причина: Добавяне на информация
    #898
    може би трябва да върнеш заводските настройки и в началният екран да избереш държава в която се поддържа.
    руснаците имаха един форум....
    https://sur.ly/i/forum.samez.eu/
    https://wiki.samygo.tv/index.php?title=Main_Page
    https://forum.samygo.tv/
  17. lrn
    lrn е офлайн
    Member
    #899
    Благодаря Христослав,
    Прегледах доста теми от форумите и се оказва (по мое мнение), че борбата ще е "безмилостно жестока" и "победата" ако изобщо се получи нещо ще е пирова.
    Ако успея изобщо да подкарам записа (PVR , TimeShift), вероятно ще имам проблеми с българския на многоезичните програми, поне това се коментира, та едва ли ще се захващам при неясен резултат.
    Ами това е положението, бъдещето е "безтунерно", което е очевидно, дразни ме само идеята, че реално нямаш избор, но да не навлизаме във философските дебри.
  18. Junior Member
    Oct 2016
    #900
    В Техномаркет започват преордери на новите модели: https://www.technomarket.bg/produkti...r;s=price_desc
  1. Samsung телевизори 2019
    Отговори: 493
    Последно: 29-01-20, 07:06
  2. Samsung телевизори 2017
    Отговори: 1079
    Последно: 01-01-18, 05:34
  3. Samsung телевизори 2016
    Отговори: 821
    Последно: 01-01-17, 16:42
  4. Samsung Телевизори 2015
    Отговори: 1121
    Последно: 02-01-16, 08:17
    Последно: 21-10-14, 22:00
