Samsung QE65Q95T
https://www.homecinemamagazine.nl/20...led-televisie/
...the Q95T series is the top 4K model, with a Full Array backlight with local dimming of 15 x 8 (120) segments. That is significantly less than the 480 segments that we found on the Q90R (2019), although we also see that the Q95T is considerably cheaper than the Q90R . You see it better as a successor to the Q85R . More segments are now only available in Samsung's 8K models...
...The Q90T, Q95T and 8K models are equipped with a very good anti-reflection film and wide viewing angle. The new viewing angle film is a bit less compared to last year but still delivers a good result. The viewing angle is now closer to that of Sony's X-Wide Angle. From 20-30 ° you can see the gamma value drop, making midtones a bit brighter. In extreme HDR images, the zone boundaries become more visible. The color reproduction remains very good. The screen temperes reflections well, but they do get a somewhat wider smeared effect...
VA panel is equipped with Samsung's Ultra Viewing Angle film
Picture settings:
General:
Picture Mode: Movie
Picture Format Settings: 16: 9 Default
Fit to Screen: On
Expert settings:
Brightness: 20
Contrast: 45
Sharpness: 5
Color: 25
Tint (G / R): 0
Local Dimming: Standard
Contrast Enhancement : Off or Low
Film Mode: Auto Color
Tone: Warm 2
Gamma: BT.1886 / 0 Shade
Detail: 0
RGB Mode: Off
Color space: Auto
Sharpness Settings:
Adjusted:
Blur. : 10
Vibration reduction: 6-8
Led Clear Motion: Off
Noise reduction: Auto or Off
