| Samsung 2015 |
| Product | LCD Type
____________ | 10bit or 8bit
panel | LCD matrix
Refresh Rate | HDR
Support
________________ | Backlight Type
_____________________
Local Dimming | Wide Color Gamut
Support
_______________________ | HDMI 2.0a Inpits
_________ | HDCP 2.2 Support
________ | HEVC (H.265) Decoding
_____________________________________________ | Flat or Curved
______________ | UltraHD Streaming Services | Tuner
________________ | Wi-Fi & Smart TV | Picture Accuracy Out-of-the-Box (score out of 10)
_______________ |
Samsung JS9500
(65", 78", 88") | SVA | 10bit | 100Hz | Full
335 cd/m² | FALD
Yes | Yes
94,0% DCI P3
75,0% Rec.2020
(Quantum Dots) | 2.0a | yes | HEVC поддържа само MKV/MP4/TS.
- H.264 FHD до ниво 4.1.(FMO/ASO/RS неподдържан)
- H.264 UHD до ниво 5.1
- HEVC FHD до ниво 4.1
- HEVC UHD до ниво 5.1 | Curved
(4200R) | yes | Double tuner
DVB-T/T2/C/S2
DiSEqC version 1.0 | yes
a/ac/b/g/n | |
Samsung JS9000
(48", 55") | SVA | 10bit | 100Hz | Full
480 cd/m² | Edge Led
yes | Yes
95,5% DCI P3
74,0% Rec.2020
55" (4200R)
48" (3000R) | yes | Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n | |
Samsung JS8500
(48", 55") | SVA | 10bit | 100Hz | Yes
480 cd/m² | Edge Led | Yes
92-95% DCI P3
74,0% Rec.2020
(Quantum Dots) | 2.0a | Yes | HEVC поддържа само MKV/MP4/TS.
- H.264 FHD до ниво 4.1. (FMO/ASO/RS неподдържан)
55" (4200R)
48" (3000R) | Yes | Double tuner
DVB-T/T2/C/S2
DiSEqC version 1.0 | Yes
a/ac/b/g/n | 65" - 8
55" - 8 |
Samsung JS8000
(55") | SVA
55" - IPS | 10bit | 100Hz | Limited | Edge Led | Yes
(Quantun Dots) | yes | yes | HEVC поддържа само MKV/MP4/TS.
- HEVC UHD до ниво 5.1 | Flat | yes | Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n | |
| Samsung JU7500 | SVA | 8bit | 100Hz | No | Edge Led | Yes
80% DCI P3
(Quantum Dots) | No | Yes | Yes | Curved
78,65,55 (4200R)
DVB-T/T2/C/S2
a/ac/b/g/n | 9 |
| Samsung JU7000 | SVA | 8bit | 100Hz | No
380 cd/m² | Edge Led | No
83,2% DCI P3
60,1% Rec.2020 | No | Yes | Yes | Flat | yes | Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n | |
| Samsung JU6800 | VA | 8bit | 50Hz | No | Edge Led | Yes
94,6% DCI P3
72,8% Rec.2020
(Quantum Dots) | ? | Yes | Yes | Flat | | DVB-T/T2/C/S2
a/ac/b/g/n | |
| Samsung JU6600 | VA | 8bit | 50Hz | No | Edge Led
(flashing backlight) | No | 2,0 | Yes | Yes | Curved
55" (4200R)
48,40" (3000R) | | DVB-T/T2/C/S2
a/ac/b/g/n | |
| Samsung JU6500 | VA | 8bit | 50Hz | No | Edge Led
80% DCI P3 | 2.0 | yes | yes | Curved
55" (4200R)
a/ac/b/g/n | |
| samsung JU6400 | VA | 8bit | 50Hz | No | 55" Direct led
Edge Led
(flashing backlight) | No | 2.0 | yes | yes | Flat | | DVB-T/T2/C | yes
a/b/g/n | |
| Samsung JU6000 | VA
55" - IPS | 8bit | 50Hz | No | Edge Led | No | | | ? | Flat | No | DVB-T/T2/C | yes
a/b/g/n | |
| Sony 2015 |
| Prоduсt | LСD Type
(Maker) | 10bit оr 8bit | LСD mаtrix
Rеfresh Rаtе | HDR
Ѕupport | Васkligh Type
Local Dimming | Widе Colоr Gаmut
Support | HDMI 2.0a Inputs | HDCP 2.2 Suppоrt | НЕVС (H.265) Decoding | Flаt оr Сurvеd | UltraHD Streaming Services | Tunеr | Wi-Fi & Smаrt TV | Picture Accuracy Out-of-the-Box (score out of 10) |
Sony X9405C
(75") | MVA | 10bit | 100Hz | Full | 75" FALD (80,areas)
55", 65" Edge Led | 91% DCI P3
(Quantum Dots) | ? | Yes | Yes | Flat | Yes | Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n | 9 |
Sony X9305C
(55", 65") | MVA | 10bit | 100Hz | Full | Edge Led
Frame Dimming | 91% DCI P3
(Quantum Dots) | 2.0a | yes | yes | Flat | yes | Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n | |
Sony X9105C
(75") | MVA | 10bit | 100Hz | Limited | Edge Led
Frame Dimming | Yes
(Quantum Dots) | 2.0a | yes | yes | Flat | Yes | Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n | |
Sony X9005C
(55", 65") | IPS
(55",65") | 10bit | 100Hz | Limited | Edge Led
Frame Dimming | Yes
DVB-T/T2/C/S2
a/ac/b/g/n | |
Sonу X8505C
(55", 65", 75") | MVA | 8bit | 100Hz | Limited | Edge Led
Frame Dimming | 85,3% DCI P3
69,4% Rec.2020
(Quantum Dots) | 2.0a | Yes | Yes | Flat | Yes | Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n | 8 |
Sony X8305C
(43", 49") | IPS | 10bit ? | 100Hz | No | Dynamic Edge Led
Frame Dimming | 73.5% DCI P3 | 2.0 | Yes | Yes | Flat | Yes | Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n | 7 |
Sony X8005C
(49", 55") | IPS | 8bit | 50Hz | No or
Limited ? | Full Led Simple
Frame Dimming | No | 2.0 | Yes | | Flat | | Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n | |
| Panasonic 2015 |
| Product | LCD Type
(Maker) | 10bit or 8bit | LCD matrix
Refresh Rate | HDR
Support | Backlight Type
Suppоrt | HDMI 2.0a Inputs | HDCP 2.2 Support | HEVC (H.265) Decoding | Flat or Curved | UltraHD Streaming Services | Tuner | Wi-Fi & Smart TV | Picture Accuracy Out-of-the-Box (score out of 10) |
Panasonic CZ950E
(65") | Oled
(LG) | 10bit | 100Hz | ST2084 и ST2086 SMPTE стандарти | - | 90% DCI P3 | 4x2.0a | Yes | Yes | Curved | Yes | Twin
DVB-T/T2/C/S2
съвместими с MPEG4-AVC[H.264] | ?
a/b/g/n | 65" - 9 |
Panasonic CR850E
(55", 65") | MVA
(Samsung or AUO?) | 8bit | 100Hz | ST2084 и ST2086 SMPTE стандарти
(Необходима е актуализация на фърмуера)
360 cd/m² | Full Array Local Dimming | 88.1% DCI P3
67.8% Rec.2020
(improved phosphorus Leds) | 2.0a | Yes | Yes | Curved | Yes | Twin
DVB-T/T2/C/S2
DVB през IP | yes
a/b/g/n | 9 |
Panasonic CX800E
(50", 55", 65") | S-MVA
(Innolux)
(IPS in Japan) | 8bit | 100Hz | ST2084 и ST2086 SMPTE стандарти
340 cd/m² | 65"
55" Direct Led(9x2,zones)
50" EdgeLed(Down) | 97.6% DCI P3
81.7% Rec.2020
(improved phosphorus Leds) | 2.0a | Yes | Yes | Flat | Yes | Twin
DVB-T/T2/C/S2
DVB през IP | yes
a/b/g/n | 9
50" - 8 |
Panasonic
CX750E & CX740E
(49", 55") | IPS | 10bit | 100Hz | No
259 cd/m² | Edge Led | (improved phosphorus leds) | 2.0 | Yes | Yes | Flat | Yes | 750 -Twin
DVB-T/T2/C/S2
DVB през IP | yes
a/b/g/n | |
Panasonic
CX700E
(40", 50", 55", 60") | S-MVA
(Innolux)
V500DK1-KS5 | 10bit ? | 100Hz | No
470 cd/m² | 55" Direct Led(4x2,areas)
50", 40" - Edge led(Down)
Local Dimming | 95.0% DCI P3
74.0% Rec.2020
(improved phosphorus Leds) | 2.0 | Yes | Yes | Flat | Yes | DVB-T/T2/C
DVB през IP | yes
a/b/g/n | |
Panasonic CX680E
(40", 50", 55") | S-MVA | 8bit | 50Hz | No
400 cd/m² | 55" - Direct Led
50" - Edge Led(Down)
Local Dimming | No
50% DCI P3
(improved phosphorus Leds) | No | Yes | Yes | Flat | Yes | DVB-T/T2/C | yes
a/b/g/n | |
Раnasonic CX400E
(40", 48", 55") | MVА | 8bit | 50Hz | Nо | 48", 55" Direct Led | Nо | No | Yes | Yes | Flаt | | DVВ-T/T2/С | Yes
а/b/g/n | |
| LG 2015 |
| Product | LCD type
(Maker) | 10 or 8bit | LCD matrix refresh rate
_________ | HDR Support | Backlight
Type | Wide Color Gamut Support | HDMI 2.0a Inputs | HDCP 2.2 Support | HEVC (H.265) & VP9 Decoding | Flat or Curved | UltraHD Streaming Support | Tuner | Wi-Fi & Smart TV | Picture Accuracy Out-of-the-Box (score out of 10) |
| LG EG960V | Oled | 10bit | 100Hz | Yes | - | Yes
63.49% Rec.2020 | 2.0 | Yes | Yes - Yes | Curved | | DVB-T/T2/C/S2 | yes
a/b/g/n | |
| LG ЕF950V | Оlеd | 10bit | 100Hz | Yes | - | Yes
88% DCI P3
58.93% Rec.2020 | 2.0a | Yes | Yes - Yes | Flat | | DVВ-T/T2/С/S2 | Yesа/b/g/n | 65" - 9 |
| LG EG930V | Oled | 10bit | 100Hz | Yes | - | Yes
87% DCI P3
61.43% Rec.2020 | 2.0 | Yes | Yes - Yes | Curved | | DVB-T/T2/C/S2 | yes
a/b/g/n | |
LG UF950V
UF940V | S-IPS | 8bit | 100Hz | No | Edge Led
(Down) | Yes
(бели светодиоди с подобрен фосфор, плюс оптимизиран цветен филтър) | No | Yes | Yes - Yes | Flat | Yes | DVB-T/T2/C/S2 | yes
a/b/g/n | 55" - 9 |
LG UF870V
UF860V | S-IPS | 8bit | 100Hz | No | Edge Led | Yes
(Quantum Dots) | No | Yes | Yes - Yes | Flat | Yes | DVB-T/T2/C/S2 | Yes
a/ac/b/g/n | |
| LG UF850V | S-IPS | 10bit | 100Hz | No | Edge Led | Yes
53.86% Rec.2020 | No | Yes | Yes - Yes | Flat | | DVB-T/T2/C/S2 | Yes
a/b/g/n | 65" - 8 |
LG
UF830V | S-IPS | 8bit | 100Hz | No | Edge Led | No | No | Yes | Yes - Yes | Flat | | DVB-T/T2/C/S2 | Yes
a/b/g/n | |
| LG UF770V | S-IPS | 8bit | 100Hz ?
43" - 50Hz | No | Edge Led
Local Dimming | No
75% DCI P3
50,35% Rec.2020 | No | Yes | Yes - Yes | Flat | | DVB-T/T2/C/S2 | yes
a/b/g/n | |
| LG UF690V | S-IPS | 8bit | 50Hz | No | Edge led | No | No
2,0 | Yes | Yes - Yes | Flat | | DVB-T/T2/C/S2 | yes
a/b/g/n | |
LG UF680V
като резолюция не е пълноценен UltraHD | S-IPS RGBW subpixel structure
(RGB + White) | 8bit | 50Hz | No | Edge led | No
51.83% Rec.2020 | No
2,0 | yes | No - Yes | Flat | | DVB-T/T2/C/S2 | yes
a/b/g/n | |
| LG UF670V | S-IPS | 8bit | 50Hz | Nо | Еdgе lеd | Nо | No | Yes | Nо | Flаt | | DVВ-T/T2/С/S2 | Yes
а/b/g/n | |
| LG UF640V | S-IPS | 8bit | 50Hz | No | Edge Led | No | No | Yes | No | Flat | No | DVB-T/T2/C/S2 | Yes
a/b/g/n | |
| Philips 2015 |
| Product | LCD Type
(Маkеr) | 10bit or 8bit | LCD matrix
Refresh Rate | HDR Support | Backligh Type | Wide Color Gamut
Support | HDMI 2.0a Inputs | HDCP 2.2 Support | HEVC (H.265) & VP9 Decoding | Flat or Curved | UltraHD Streaming Services | Tuner | Smart TV | Picture Accuracy Out-of-the-Box (score out of 10) |
Philips PUS9600
(65", 75")
March 2016 | MVA ?
(AUO?) | 10bit | 100Hz | Yes
1000 cd/m² | Full Array Local Dimming
256, areas | Yes | 2.0a | Yes | Yes - Yes | | Yes | Double tuner
DVB-T/T2/C/S2
DiSEqC version 1.0 | Yes | |
Philips PUS8700
(55", 65") | MVA | 10bit? | 100Hz | ? | Edge Led | Yes
Color Booster с вътрешна обработка на цветовете 17 бита | 2.0 | Yes | Yes - Yes | Curved (8700) | Yes | Double tuner
DVB-T/T2/C/S2
b/g/n | |
Philips PUS8601
(55", 65") | MVA? | 10bit? | 100Hz | Yes? | Edge Led | Yes
Color Booster с вътрешна обработка на цветовете 17 бита | 2.0 | Yes | Yes - Yes | Flat | Yes | Double tuner
DVB-T/T2/C/S2
a/ac/b/g/n |
Philips PUS7600
(48", 55", 65") | MVA | 10bit | 100Hz | No | Edge Led | Yes
81.2% DCI P3
Color Booster с вътрешна обработка на цветовете 17 бита | 2,0 | Yes | Yes- Yes | Flat | Yes but only 1080p... | Double tuner
DVB-T/T2/C/S2
b/g/n | |
Philips
PUS7100
PUS7120
PUS7150
PUS7170
PUS7180 | IPS | 8bit | 50Hz | No | Edge led | No | 2,0 | Yes | Yes - Yes | Flat | Yes but
only 1080p... | DVB-T/T2/C/S2
DiSEqC version 1.0
7170&7180
Double Tuner | Yes
b/g/n | |
Philips PUT6400
(40", 50", 55") | MVA | 8bit | 50Hz | No | Direct led | No
75% DCI P3 | 2,0 | Yes | Yes - Yes | Flat | Yes but only 1080p... | DVB-T/C | Yes
b/g/n | 50" - 8 |
Philips
PUS4900
PUK4900
PUT4900 | IPS | 8bit | 50Hz | No | | No | No | Yes | No | Flat | No | DVB-T/C | No | |
| Sharp 2015/2016 |
| Prоduсt | LСD Type
Rеfresh Rаtе | HDR Support | Васklight Type | Widе Colоr Gаmut
Suppоrt | HDMI 2.0a Inputs | HDCP 2.2 Support | НЕVС (H.265) & VP9 Decoding | Flаt оr Сurvеd | UltraHD Streaming Services | Tunеr | Smаrt TV | Picturе Accuracy Оut-оf-thе-Box (scorе оut оf 10) |
Sharp
XUE8982
XUE8882
XUE8772
(43",49",55'',60'',65'') | S-IPS
(RGBW)
4K Resolution | | 100Hz | Nо | | Nо | | Yes | Yes | Flаt | Nо | DVВ-T/T2/С/S2 | Yes
b/g/n | |
Sharp
CUF8682
(60",70",80") | UV²A
UltraHD | | 100Hz | No | | No | | Yes | Yes | Flat | | DVB-T/T2/C/S2 | |
Sharp CUF8382
(43",49",55") | IPS
Sharp
CUF8462
CUE8462
(43",49",55") | IPS
UltraHD | 8bit | 50Hz | No | | No | 2.0 | Yes | Yes | Flat | | DVB-T/T2/C/S2 | | | | | |
