| Sony UltraHD TV 2016 - european models |
Product
________________ | UHD
Premium | Dolby
Vision | HDR _____________________ | Videopanel ___________________________________ | Backlight & Dimming ______________________________ | Contrast (native/ANSI)
White level
Black level
_____________________________ | Color Space ________________________________ | Viewing angle
(cone)
_______ | Input Lag _____________________________________
Leo Bodnar | Audio _____________________ | OS
Board
System on Chip ___________________________ | Network ______________ | Connectivity _____________________________ | Tuner
____________________ | Opportunities for calibration
_____________________ | Note _______________________________________ | Product |
ZD9 65" September 2016 | No
Informaly | Yes | 65" - max - 4000cd/m2 Yes
SMPTE standarts
ST2084, ST 2086 | 65"- MVA - 10bit ?, 120/100Hz + BLS + MCFI MCFI - Motion Clarity Frame Interpolation | 65" - Full Array Local Dimming
1000 zones (40 x 25) ? (Blue Led + RG phosphors) | 65" - 8000:1 ??
| 65"- DCI P3- 96% / Rec.2020 -
Quantum Dots
(Blue Led + RG phosphors) | 75" - °
| 65" - Game mode
| | Android 6.0 Marshmallow
Board:
Core architecture:
CPU:
GPU:
RAM:
Internal storage total space: | Lan
Wi-Fi
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
WiFi Direct
DLNA
Blietooth Ver.4.1 | 2 x USB 2.0 (DC 5V MAX 500mA)
1 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0 (ARC, CEC, MHL)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub: F-type female)
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x Optical Audio Out (Video+L/R)
1 x 3.5mm Audio Out (YPbPr+L/R)
1 x Antena (RF) (female)
1 x CI+ 1.3 | Twin Tuners
DVB-C/T2/S2
DiSEqC version 1.0 | White balance -
Gamma -
CMS -
ISF - | | ZD9 |
XD94 75" | No
informaly | No | 75"- max 1200cd/m2 Yes HDR10
SMPTE standarts
ST2084, ST 2086 | 75" - AMVA3, 10-bit, 120/100Hz + BLS + MCFI BLS - Backlight Scanning
Semi-mate | Full Array Local Dimming
80 zones ??? (8x10) (Blue Led + RG phosphors) PWM Freq. 120/100Hz | 75" - | 75"- DCI P3- 96% / Rec.2020 -
Quantum Dots +
| 75" - Game mode
| | Android 5.1.1 Lolipop
Board:
Core architecture:
CPU:
GPU:
RAM:
Wi-Fi
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth Ver. 4.1 | 2 x USB 2.0 (DC 5V MAX 500mA)
1 x Ethernet RJ45
1 x Satelite In (Main: F-type female)-
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x CI+ 1.3 | Twin tuners
DVB-C/T2/S2
DiSEqC version 1.0
PIP, Timeshift & PVR | White balance- 2/10 points
Gamma - 10 points
CMS - no
ISF - | | XD94 |
XD93 (9305) 65" (64.6),
55" | No | No | 65" - 2%-1045cd/m2(HDR)
65" - 5%-1153cd/m2(HDR)
65" - 387cd/m2 (SD) 55"-2%-987cd/m2(HDR)
55" - (SD) Yes HDR10
SMPTE standarts
ST2084, ST 2086 | 65" - AMVA3, 8-bit+FRC, 120/100Hz + MCFI 55" - AMVA3, 8-bit+FRC, 120/100Hz + MCFI BFI - Black Frame Insertion
Semi-mate | 65"- (4 columns x 8 rows) 32 zones 55"- (4 columns x 7 rows) 28 zones Edge led - Left & Right side
Horizontal Dimming
(Blue Led + RG phosphors) PWM Freq. 120/100Hz | 65" - 3334:1/ 0.036cd/m2 55" - 2600:1/ 0.046cd/m2
| 65"- DCI P3- 94.8% / Rec.2020-72% 55"- DCI P3- 88.0% / Rec.2020-64.2% Quantum Dots | 65" - 45° 55" - 32°
| 65" - Game mode 51.0ms/ 55" - Game mode 52.3ms/
| | Android TV : 5.1.1 Lolipop
Board : SVPDTV15
Core architecture:2x ARM Cortex-A17 (ARMv7)
Instruction Set : 32-bit ARMv7
CPU SoC:MediaTek MT5890 dual core
GPU:ARM Mali T624 triple core
RAM:1,5GB
Internal storage total space:8,36GB | Lan
Wi-Fi
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
DVB-C/T2/S2
DiSEqC version 1.0
Gamma - 10 points
CMS - no
ISF - | TV can not solve the very first step also correctly (17/255) | XD93 |
SD85 (CURVED) 65", 55" | No | No | 65" - max - 1000cd/m2 55" - max - 1000cd/m2 Yes HDR10
SMPTE standarts
ST2084, ST 2086 | 65" - AMVA3, (8-bit+FRC), 120/100Hz 55" - AMVA3, (8-bit+FRC), 120/100Hz MCFI - Motion Clarity frame Interpolation
Semi-mate | 65" - Edge Led (below) 55" - Edge Led (below) (Blue Led)
Frame Dimming | 65" - 55" -
| 65"- 55"- DCI P3- 85.94%/ Rec.2020-63.7% Quantum Dots
SBM (Super Bit Mapping) which upsample colors in 16-bit internal processing | 65" - ° 55" - °
| 65" - Game mode 55" - Game mode
Board : SVPDTV15
RAM:1,5GB
Wi-Fi
802.11 b
802.11 g
802.11 n
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
DVB-C/T2/S2
DiSEqC version 1.0
Gamma - 10 points
CMS - no
ISF - | | SD85 |
XD85 (8505, 8577, 8599) 85", 75", 65", 55"
копие на миналогодишният X85C, но с нов дизайн, с IPS панел и без 3D | No | No | 85" - 75" - 65" - 55"- Window 2%-369cd/m2 Limited | 85" - AS-IPS (8-bit+FRC), 120/100Hz 75" - AS-IPS (8-bit+FRC), 120/100Hz 65" - AS-IPS (8-bit+FRC), 120/100Hz 55" - AS-IPS (8-bit+FRC), 120/100Hz Semi-mate | 85" - Edge led (below) 75" - Edge Led (below) 65" - Edge Led (below) 55" - Edge Led (below) Quantum Dots (+ Blue Led)
Frame Dimming associated with a very efficient mode (HDR particularly and especially on IPS panels) ACE (Advanced Contrast Enhancer) or improving advanced contrasts. No PWM | 85" - 75" - 65" - 55" - native 850:1 / black 0.12cd/m2
1248:1/ 0.084cd/m2 | 85"- 75"- 65"- 55"- DCI P3- 86% / Rec. 2020 - 63% Quantum Dots
SBM(Super Bit Mapping) which upsample colors in 16-bit internal processing | 85" - ° 75" - ° 65" - ° 55" - °
| 85" - Game mode 75" - Game mode 65" - Game mode 55" - Game mode 34.6ms / by default 66.5ms
| As such, the audio rendering is quite above average, nothing special, but the advantage of being powerful enough to offer some serious and good reproduction of dialogue. I also appreciate the presence of a subwoofer output and many settings to improve the audio rendering, an EQ, a virtual surround mode, and especially the presence of Dolby Digital Plus and DTS decoders that can decode audio from MKV with DTS tracks and even send the DTS and Dolby stream Bitstream via HDMI or Optical ARC.
Subwoofer output (ie that you can also connect a wireless subwoofer Sony SWF-BR100) | Android TV : 5.1.1 Lolipop
Board : SVPDTV15
RAM:1,5GB
Wi-Fi
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
DVB-C/T2/S2
DiSEqC version 1.0
Gamma - 10 points
CMS - no
ISF - | In Europe it will exist in three design variants named
,KD-XD8505B (black) ,KD-XD8577S (silver) , ,KD-XD8588B (black) ,KD-XD8599B (black).
What differences between references XD8505, XD8577 and XD8599? Let me be clear: no! This is simply references marketed only to please some signs that make large volumes of sales, so they do not suffer from competition on the Internet. You will probably see a little difference, often on the index of fluidity XR1000 instead of XR800, but these are purely marketing indices. There is no visible difference between a Motionflow XR800 and XR1000. | XD85 |
XD80 55", 49", 43" | No | No | 55" - max - 49" - max - 43" - max - Limited | 55" - (8-bit+FRC), 120/100Hz 49" - (8-bit+FRC), 43" - (8-bit+FRC),
| 55" - Edge Led (below) 49" - Edge Led (below) 43" - Edge Led (below) (Blue Led) | 55"- 49"- 43"-
| 55"- 49"- 43"-
| 55" - ° 49" - ° 43" - °
| 55" - Game mode 49" - Game mode 43" - Game mode
| | Mediatek MT5890 2xARM Cortex-A17
ARM mali-624
Storage - 16GB
Android 5.1.1 Lolipop | Lan
Wi-Fi
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth Ver.4.1 | 2 x USB 2.0 (DС 5V MAX 500mА)
1 x USB 3.0 (max 0.9A) 1 х Еthеrnеt RJ45 4 х НDМІ 2.0 (АRС,СЕС,MHL) 1 х Ѕаtеlіtе іn(Маіn:F-tуре fеmаlе)-> 1 х ЅСАRТ 1 х Соmроѕіtе іn (Vіdео+L/R) 1 х Соmроnеnt іn (YРbРr+L/R) 1 х Орtісаl Аudіо Оut 1 х 3.5mm Аudіо Оut 1 х Аntеnа (RF) (Fеmаlе) 1 х СІ+1.3 | DVB-C/T2/S2
DiSEqC version 1.0 | | | XD80 |
SD80
(curved) 50" | No | No | 50" - max - Limited | 50" - MVA, 8-bit+FRC, 120/100Hz
| 50" - Edge led (below) (Blue Led) | 50" -
| 50"- Rec.2020- 64% / rec. 2020 -
| 50" - °
| 50" - Game mode
| | Mediatek MT5890
2xARM Cortex-A17
ARM Mali-624
Storage -
Wi-Fi
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth Ver.4.1 | 2 х UЅВ 2.0 (DС5 V МАХ500mА)
1 x USB 3.0 (max 0.9A) 1 х Еthеrnеt RЈ45 4 х НDМІ2.0 (АRС,СЕС,MHL) 1 х Ѕаtеlіtе іn(Маіn:F-tуре fеmаlе)-> 1 х ЅСАRТ 1 х Соmроѕіtе іn (Vіdео+L/R) 1 х Соmроnеnt іn (YРbРr+L/R) 1 х Орtісаl Аudіо Оut 1 х 3.5mm Аudіо Оut 1 х Аntеnа (RF) (Fеmаlе) 1 х СІ+1.3 | DVB - T/C | | | SD80 |
XD75 60" | No | No | 60" - No | 60" - ? , 8bit + FRC, 120/100Hz
| 60" -
| 60" -
| 60" - °
| 60" - Game mode
| - | - | Lan
802.11 b
802.11 g
802.11 n
Wi-Fi Direc
DLNA | 2 x USB 2.0 (DC 5V MAX 500mA)
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x CI+ 1.3 | | | | XD75 |
XD70 55", 49" | No | No | 55" - 49" - No | 55" - AS-IPS, 8bit+FRC, 60/50Hz ? 49" - AS-IPS, 8-bit+FRC, 60/50Hz
| 55" - Edge Led 49" - Edge Led
| 55"- 49"-
| 55"- 49"-
| 55" - ° 49" - °
| | - | Lan
Wi-Fi
802.11 b
802.11 g
802.11 n
Wi-Fi Direct
DLNA | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0 (ARC, CEC, MHL) 1 x Satelite In (Main: F-type female) 1 x SCART
1 x AV Composite In 1 x AV Component In 1 x Optical Audio Out (Video+L/R) 1 x 3.5mm Audio Out (YPbPr+L/R) 1 x Antena (RF) (female) 1 x CI+ 1.3 | | | | XD70 |
| Sony FullHD TV 2016 - european models |
Product
__________________ | UHD
Premium | Dolby
Vision | HDR _____________________ | Videopanel __________________________ | Backlight & Dimming __________________________ | Contrast & Black level
________________________________ | Color Space _____________________________________ | Viewing angle
(cone)
_______ | Input Lag _________________________________ | Audio ____________________________ | OS
Board
System on Chip ___________________________ | Network ________________ | Connectivity _______________________________ | Tuner
_____________________ | Picture Accuracy
Out-of-the-Box
(score out of 10) | Product |
WD7xx (750,755,756,757) 49", 43", 32" | No | No | 49" - max - 43" - max 32" - max No | 49" - 8-bit, Hz 43" - 8-bit, Hz ? 32" - 8-bit, Hz ?
| 49" - Edge Led 43" - Edge Led 32" - Edge Led Frame Dimming - BLB | 49" - 43" - 32" -
| 49" - 43" - 32" -
| 49"- ° 43"- ° 32"- °
| 49" - Game mode 43" - Game mode 32" - Game mode
| - | - | Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
Wi-Fi Direct
DLNA
Bluetooth - only 43↑ | 2 x USB 2.0 (DC5 V MAX500mA)
1 x Ethernet RJ45
2 x HDMI1.4 (ARC,CEC) in 43↑ 4xHDMI 1 x Satelite in(Main:F-type female) -> 1 x SCART
1 x Composite in (Video+L/R)
1 x Component in (YPbPr+L/R)
1 x Optical Audio Out 1 x 3.5mm Audio Out
1 x Antena (RF) (Female)
1 x CI+1.3 | 750 - DVBT/C
752/753 - DVB-T/T2/C 754/755/756/757/758/759
DVB-T/T2/C/S/S2
(+HEVC)
Analog (PAL,SECAM)
PVR + Time Shifting | | | WD75 |
WD6xx (600,605,653,655) 48", 40",
32"-WXGA | No | No | 48" - max 40" - max 32" - max 236cd/m2 No | 48" - MVA, 8-bit, 60/50Hz 40" - MVA, 8-bit, 60/50Hz 32" - IPS(AHVA), 8bit, 60/50Hz Semy-gloss | 48" - Direct Led / no local dimming 40" - Direct Led / no local dimming 32" - Direct Led / no local dimming Frame Dimmimg - BLB
Without Interpolation No PWM | 48" - 40" - 3397:1 / 0.032cd/m2 / 108.7cd/m2 32" - 955:1 / 0.116cd/m2
| 48" - 40" - DCI P3 XY: 73.93% / DCI P3 UV: 81.54%
Rec XY 2020: 53.13% / Rec UV 2020: 59.82% 32" -DCI P3 xy: 76.48 % / DCI P3 uv: 88.70 %
Rec 2020 xy: 54.88 % / Rec 2020 uv: 58.24 % | 48" - ° 40" - 13° 32" - 53°
| 48" - Game mode 40" - Game mode 42.3ms / by default 42.4ms 32" - Game mode 26.0ms / by default
| - | - | Lan
Wi-Fi
802.11 b
802.11 g
802.11 n
Wi-Fi Direct
DLNA
Miracast | 2 x USB 2.0 (DC5 V MAX500mA)
1 x Ethernet RJ45
2 x HDMI1.4 (ARC,CEC) 1 x Satelite in(Main:F-type female) ->
1 x SCART
1 x 3.5mm Audio Out
1 x CI+1.3 | 600/650 - DVB-T/C 653 - DVB - T/T2/C 605/655
DVB-T/T2/C/S/S2
(+HEVC)
Analog (PAL,SECAM) | | | WD60 |
RD4xx (430,433,435,450,455) 40", 32" | No | No | No | 40" - MVA, 8-bit, 60/50Hz 32" - IPS, 8-bit, 60/50Hz ? Semy-gloss | 40" - Direct Led 32" - Direct Led Without Interpolation | 40" - 32" -
| 40" - 32" -
| 40" - ° 32" - °
| 40" - Game mode 45.0ms / 32" - Game mode
| - | - | Lan
W-Fi
802.11 b
802.11 g
802.11 n | 2 x USB 2.0 (DC5 V MAX500mA)
1 x Ethernet RJ45
1 x SCART
1 x 3.5mm Audio Out
1 x CI+1.3 | 400/430/450
DVB-T/C 435/455
DVB-T/T2/C/S2
(+HEVC)
Analog (PAL,SECAM) | | | WD4xx |
