| Sony UltraHD TV 2017 - european models / Sony UltraHD TV 2017 - european models / Sony UltraHD TV 2017 - european models |
| Series | Certificates | HDR | Hardware & Software | Calibration | Picture Quality | Other | Series |
Series & Model _________________ | UHD Premium ______ | ISF ccc ____ ISFccc -
Certified
Calibration
Controls | THX ____ | Dolby Vision
VS10 _____ | Hybrid
Log Gamma
(HLG) ______ no metadata | HDR 10 ST2084
(EOTF PQ),
ST2086
(static metadata)
ST2094
(dynamic metadata) ________ | Advanced HDR Technicolor _______ | SoC / GPU / RAM _________________________ Plattform,
Central Processing Unit,
System on Chip,
Instruction set,
Graphic Processor Unit,
RAM,
Total memory | Software __________________________ Operating System,
Firmware version, | Videopanel _________________________Size class,
Type LCD/Oled matrix,
Resolution,
Pixel structure,
Bits of color,
Quantum dots,
Frequency of T-Con board,
Curvature,
Screen Uniformity,
Anti-reflective filter | Backlight Unit _______________Type backlight,
Local Dimming zone,
Type LED,
MEMC,
Backlight Scanning,
Black Frame Insertion,
Pulsе Wide Modulation | Opportunities for calibration _____________________ ISF ccc,
Color Menagment System,
White balance,
Gamma, | Internal Processing _______________________Scaling,
Interpolation,
Overscaninng,
Digital Noise reduction,
Deinterlacing (Video mode, Film mode),
-, | Color _______________________________DCI P3 coverage,
Rec.2020 coverage,
Delta E ,
Gamma,
Color Temperature | Brightness _______________________________Peak in HDR
Peak in SDR,
Average Picture Level,
Automatic Brightness Limiter, | Contrast ______________ANSI Contrast,
With local dimming,
Without local dimming,
White level,
Black level | Viewing angle _________ Horizontal & Vertical
(°cone) | Motion resolution ______________ | Input Lag ______________ | Audio _____________________________ | Built in Media Player Supported file systems
Image file formats
Audio file formats/codecs
Video file formats
Subtitles ______________________________ | Connectivity __________________ | Supported Resolutions __________________________Frame per seconds
24, 25, 30, 50, 60, 100, 120
Chroma subsampling
4:4:4
4:2:2
4:2:0 | Conectors __________________________________ | Tuners _________________________ | Note _____________________________________Pros & Cons | Series & Model
A1 (Oled) (Flat)
KD-77A1
KD-65A1
KD-55A1 no 3D
no HFR | ? | No | No | Yes - after software update. - in Internet video services, HDMI, USB port. | Yes - after
software update. | Yes | No | Plattform: FY16 HE
SoC: Mediatek MT5
Core Architecture: 4 x ARM Cortex A53
Instruction set: 64-bit ARM-A53
Operating at up to:
GPU:
Open GL
RAM:
Total memory: 16GB
Available memory:
Internal storage total space:
Internal storage free space: | OS: Android 6.0 -> 7.0 Nugat (Sony Edition)
(Google Cast, Voice Control, Google Play Apps & Games, Chrome Cast) PKG Super Bit Mapping 4K HDR (14-bit upsampling) | 77" - AM-OLED (Triple Stacked), 3840x2160, WRGB, 10-bit,
120/100Hz, Flat
Model: LC770LQD (LG Display) 65" - AM-OLED (Triple Stacked), 3840x2160, WRGB, 10-bit,
120/100Hz, Flat
Model: LC650LQD (LG Display) 55" - AM-Oled (Triple Stacked),
120/100Hz, Flat Model: LC550LQD (LG Display) Motionflow XR 1200 | No backlight | White balance- 2/10 points
Gamma - 10 points
ISF - no
3 gamuts (Rec.709, DCI, Rec.2020) but no CMS (Color Management System) to calibrate these gamuts | | 77" - 65" - 55" - | 77"- 65" - 55" - | 75" -° 65" -° 55" - ° | 75" - 65" - 55" - | 75"- 65" - 55" - | 75" - Game mode 65" - Game mode 55" - Game mode | Acoustic Surface - the entire screen resonates with rich sound emitted directly from the screen itself. 4 x Tweeter, 6om (20mm)
1 x Woofer (80mm) in the stand Speaker position - rear Dolby Digital,
Dolby Digital Plus,
Dolby Pulse,
DTS, | FAT16, FAT 32, NTFS and exFAT JPEG, GIF, PNG, MPO FLAC, | Lan (100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA 3.0
Bluetooth (NFC) Ver.4.1 HID/HOGP/3DSP/SPP(for keyboard and mouse, no Bluetooth audio) | | 2 x USB 2.0 (DC 5V MAX 500mA)
1 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0a - HDCP2.2 (ARC, CEC, MHL 3.0)
1 x AV Component In
1 x Optical Audio Out (AAC/PCM/AC3)
1 x 3.5mm Audio Out (Headphone)
1 x Antena (RF) (female)
1 x RS-232C - remote
1 x CI+ 1.3
1 x IR in remote
1 x IR Blaster - port for the infrared receiver. The latter therefore means that the infrared receiver is not present on the facade.
Only HDMI 3 support ARC | Twin tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, Timeshift & PVR
MPEG2,
MPEG4,
HEVC H.265,
VP9 Profile 2 | | AE1 |
ZD9 (Flat)
KD-100ZD9 BAEP
KD-75ZD9 BAEP
KD-65ZD9 BAEP active 3D
no HFR
model 2016 continues as model 2017 | No | No | No | Yes -
after software update - in Internet video services, HDMI, USB port. | Yes -
after
software update | Yes,
SMPTE standarts ST2084,
ST2086 | No | Plattform: BRAVIA_ATV2
SoC: MediaTek MT5891 (Cortex A53 - ARMv8)
Core architecture: 4 x Cortex A53
Operating at up to 1.1GHz
GPU: ARM Mali-T860 MP2
OpenGL ES 3.1 Mali-T860
RAM: 2GB
Total memory: 1593 MB
Available memory: 521 MB
Internal storage total space: 8358 MB
Internal storage free space: 8105 MB | OS: Android 6.0 -> 7.0 Nugat (Sony Edition)
(Google Cast, Voice Control, Google Play Apps & Games, Chrome Cast) PKG6.0614.001EUA Super Bit Mapping 4K HDR (14-bit upsampling) | 100" - ? , 3840x2160, 10-bit, 120/100Hz, Flat 75" - MVA, 3840x2160, 10-bit, 120/100Hz, Flat 65" - MVA, 3840x2160, 10-bit, 120/100Hz, Flat Motionflow XR 1200
Glossy
Protective layer of sapphire
Coated with low reflection for deep black and fluorite glass | 100" - FALD, 1508 clusters (52 x 29) ? 75" - FALD, 858 clusters (39 x 22) ? 65" - FALD, 646 clusters (34 x 19) Local DimmingMotion Clarity Frame InterpolationBlack Frame InsertionPWM - ? | White balance - 2/10 points
Gamma - 10 points
ISF - no
but no CMS (Color Management System) to calibrate these gamuts | | 100"- DCI/P3- 96% / Rec.2020 - 75"- DCI/P3 - 96% / Rec.2020 - 66% / 65"- DCI/P3 - 95% / Rec.2020 - 66% / Triluminos Display - phosphorus-based diodes for a wide gamut close to the DCI 4K(Blue Led + Red/Green phosphorus) | 100" - 75" - 65" - 3231:1 / 120cd/m2 / 0.003794cd/m2
| 100" - ° 75" - ° 65" - 65 °
| | 100" - 75" - 1080 Horizontal lines with MF 65" - 1080 Horizontal lines with MF400 without [Motion Flow]
| 100" - Game mode 75" - Game mode 65" - Game mode 42ms / by default 64ms
| 65ZD9, 75ZD9 - 2ch, Full Range (30 x 80 mm) x 2 /
100Z9D - 2ch, Two way speaker [Tweeter (30mm) + Woofer (40 x 100mm)] x2 Speaker Position - Down Firing Speaker Type - 65ZD9,75ZD9 - Bass Reflex / 100Z9D - Long Duct Dolby Plus, Dolby Pulse, DTS, Clear Phase Speaker Compatibility Wireless Subwoofer (SWF-BR100);
3D Glasses (TDG-BT500A)
65" only - Wallmount Bracket (SU-WL450 without tilt function)-Audio post-processing is powered by a dedicated ARM11 processor with L2 cache and two ADSPs. Its dedicated processor ensures always-ready performance for the latest Dolby MultiStream Decoders MS12 DAPv2 and DTS Studio Sound II (TheaterSound 3D ver 4) that encompasses the breadth of Dolby and DTS consumer audio formats. | FAT16, FAT32, NTFS and exFAT JPEG, GIF, PNG, MPO FLAC , M4A, MIDI, MP3, WMA, WAV, LPCM AVI, DivX, H.263H.264 / MPEG4 Part 10 / AVC VideoH.265 / MPEG-H Part 2 / HEVCMKV, Quick Time, M2TS, MP4, WebM, WMV, XviD .srt,
There is no possibility for setting the position and size. | Lan (100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
WiFi Direct
DLNA 3.0
Blietooth (NFC) Ver.4.1 HID/HOGP/3DSP/SPP(for keyboard and mouse, no Bluetooth audio)
Chromecast built-in
Voice search | 4096 x 2160 / 60P(displayed as 3840x2160)
4096 x 2160 / 24P(displayed as 3840x2160)
3840 x 2160 / 24P
3840 x 2160 / 25P
3840 x 2160 / 30P
3840 x 2160 / 50P
3840 x 2160 / 60P / 4:4:4
1920 x 1080 / 120Hz - ??
1920 x 1080 / 24P (Only HDMI)
1920 x 1080 / 30P (Only HDMI)
1920 x 1080 / 60P (HDMI / Component)
1920 x 1080 / 50P (HDMI / Component)
1920 x 1080 / 60I
1920 x 1080 / 50I
1366 x 720 / 24P (Only HDMI)-Up to 18Gbps
4K 60p, 4:4:4, 8bit
4K 60p, 4:2:2, 8,10,12bit
4K 60p, 4:2:0, 8,10bit
HDR included in HDMI 2/3 | 2 x USB 2.0 (DC 5V MAX 500mA)
2 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0 - (ARC, CEC, MHL 3.0)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub: F-type female)
1 x SCART1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.31 x RS.232- (Only inputs 2 and 3 are HDMI 2.0a which means they can accept 4K/60p, HDR and HDCP 2.2. The other two HDMI inputs are listed to 4K/30p)SW update to HDMI 2.1 | Twin Tuners DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4, HEVC H.265,
VP9-HEVC/VP9 10-bit color with HDR, up to 4K UHD 60 fps. This is suitable for internet TS/IPTV streams, Netflix or YouTube. Meanwhile worldwide demodulation capabilities include ATSC / DVB / DTMB / ISDBT. | | ZD9 |
XE9405 (Flat)
KD-75XE9405 BAEP successor model XD9405
no 3D
no HFR | No | No | No | Yes - after software update. - in Internet video services, HDMI, USB port. | Yes - after software update.
| Yes in Internet video services, HDMI, USB port.
ST2084, ST2086, 75" - probably close to 1500cd/m2 | No | Plattform: FY16 HE
SoC: Mediatek MT5
Operating at up to:
GPU:
Open GL
RAM:Total memory: 16GB
Available memory:
(Google Cast, Voice Control, Google Play Apps & Games, Chrome Cast) PKG6.0614.001EUA Super Bit Mapping 4K HDR (14-bit upsampling) | 75" - MVA, 3840x2160, 10-bit, 120/100Hz, Flat Flat Triluminos Display
Motionflow XR 1200 (with several modes, including an Expert mode that simulates a BFI display on 5 levels) | 75""- FALD,
(?) - clusters,
Local Dimming
Motion Clarity frame InterpolationBlack frame InsertionPWM - ? | White balance | | 75" - Triluminos Display | | 75" - ° | | | | 10W+10W+10W+10W+10W+10W Dolby Digital,
Dolby Digital Plus,
Dolby Pulse,
DTS, | FAT16, FAT32, exFAT, NTFS Image file formats:
JPEG, GIF, PNG, MPO Video file formats:
MPEG1: MPEG1, MPEG2PS: MPEG2, MPEG2TS (HDV,AVCHD), MPEG2, AVC, MP4 (XAVC S)
AVC, MPEG4, HEVC
AVI: Xvid, MotionJpeg, ASF(WMV): VC1, MOV: AVC, MPEG4, MotionJpeg, MKV: Xvid, AVC, MPEG4, VP8.HEVC, WEBM: VP8, 3GPP: MPEG4, AVC Audio file formats/codecs:
MP3, ASF(WMA), WAV, MP4AAC, FLAC, | Lan (100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth (NFC) Ver.4.1 HID/HOGP/3DSP/SPP/AVRCP - after update
Chromecast built-in
Voice Search | 4096 x 2160p (24, 50, 60 Hz),
3840 x 2160p (24, 25, 30, 50, 60 Hz),
1080p (30, 50, 60 Hz),
1080i (24, 50, 60 Hz),
720p (24, 30, 50, 60 Hz),
576p,
576i,
480p,
480i | 2 x USB 2.0 (DC 5V MAX 500mA)
1 x Ethernet RJ45
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out (hybrid - headphone & subwoofer)
1 x CI+ 1.3 | Twin Tuners
Analog-B/G,D/K,I (45,25MHz–863,25MHz)
DVB-T/T2 (VHF/UHF)
DVB-C (VHF/UHF)
DVB-S/S2 (950-2150MHz)
with function PVR, timeshifting,
PAP, PAT and PIP
MPEG2,
MPEG4,
HEVC H.265 (to 3840x2160/60p, 10bit)
VP9 Profile 2 | | XE9405 |
XE9305 (Flat)
KD-65XE9305 BAEP
KD-55XE9305 BAEP successor model XD9305
no 3D
no HFR | No | No | No | Yes - after software update. - in Internet video services, HDMI, USB port. | Yes after software update.
ST 2084, ST 2086 Pict. brightnes - 1300cd/m2 | No | Plattform: FY16 HE
SoC: Mediatek MT5
Operating at up to:
GPU:
Open GL
RAM:
Total memory: 16GB
Available memory:
(Google Cast, Voice Control, Google Play Apps & Games, Chrome Cast) PKG6.0614.001EUA Super Bit Mapping 4K HDR (14-bit upsampling) | 65" - MVA, 3840x2160, 10-bit, 120/100Hz, Flat 55" - MVA, 3840x2160, 10-bit, 120/100Hz, Flat Motionflow XR 1000 | Edge Led
Local dimming
Slim Backight Drive+
(quad edge led structure)
Edge Led backlight - 64 zones and 4 rows of diodes.
Above and below with 16 double sector. Left and right there are two sectors.
Up 16x2 -> 32 sectors
Down 16x2 -> 32 sectors | White balance | | | 65" - °
55" - ° | | | | - | 65" - 10W+10W+10W+10W+10W+10W
55" - 5W+5W+10W+10W+10W+10W Dolby Digital,
Dolby Digital Plus,
Dolby Pulse,
AVC, MPEG4, HEVC
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA 3.0
Chromecast built-in
576p,
576i,
480p,
1 x Ethernet RJ45
4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) HDCP2.2 for 1,2,3,4
1 x AV Composite In
1 x AV Component In
DVB-T/T2 (VHF/UHF)
DVB-C (VHF/UHF)
PAP, PAT and PIP
MPEG2,
MPEG4,
VP9 Profile 2 | | XE9305 |
XE9005 (Flat)
KD-75XE9005 BAEP
KD-65XE9005 BAEP
KD-55XE9005 BAEP
KD-49XE9005 BAEP successor model XD9005
no 3D
no HFR | No | No | No | No | ? | Yes in internet video services, HDMI, USB port.
ST 2084, ST 2086 Pic. brightnes close to 1000cd/m2 | No | Plattform: FY16 HE
SoC: Mediatek MT5
Operating at up to:
GPU:
Open GL
RAM:
Total memory: 16GB
Available memory:
(Google Cast, Voice Control, Google Play Apps & Games, Chrome Cast) PKG6.0614.001EUA Super Bit Mapping 4K HDR (14-bit upsampling) | 75" - ?, 3840x2160, ?-bit, 120/100Hz, Flat 64.5" - ?, 3840x2160, ?-bit, 120/100Hz, Flat 54.5" - ?, 3840x2160, ?-bit, 120/100Hz, Flat 48,9" - ?, 3840x2160, ?-bit, 120/100Hz, Flat Motinfow XR 1000 | Full Array Local Dimming | | | | 75" - °
65" - °
55" - ° | | | | | 2 x 10 Watt RMS
Magnetic Fluid Speaker & Clear Phase DTS Digital Surround
Dolby Digital Plus
Dolby Pulse | FAT16, FAT32, exFAT, NTFS Image file formats:
AVC, MPEG4, HEVC
WiFi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA 3.0
HID/HOGP/3DSP/SPP/AVRCP - agter update
(foe keyboard and mouse, no Bluetooth audio)
Chromecast built-in
Voice search | 4096 x 2160p (24, 50, 60 Hz),
576p,
576i,
480p,
1 x Ethernet RJ45
1 x AV Composite In
1 x AV Component In
Analog-B/G,D/K,I(45,25MHz–863,25MHz)
DVB-T/T2 (VHF/UHF)
DVB-C (VHF/UHF)
with function PVR, timeshifting, PAP, PAT and PIP
MPEG2,
MPEG4,
VP9 Profile 2 | | XE9005 |
XE85xx (Flat)
KD-75XE8599 BAEP
KD-75XE8588 BAEP
KD-75XE8577 SAEP
KD-65XE8599 BAEP
KD-65XE8588 BAEP
KD-65XE8577 SAEP
KD-55XE8599 BAEP
KD-55XE8588 BAEP
KD-55XE8577 SAEP
successor model XD85xx
no 3D
no HFR | No | No | No | No | ? | Yes in internet video services, HDMI, USB port. Pic. brightnes close to 1000cd/m2 | No | Plattform: FY16 HE
SoC: Mediatek MT5
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory: 16GB
Available memory:
Motion Compensation: Motionflow XR 800 (with several modes, including an Expert mode that simulates a BFI display on 5 levels)
ACE (Advanced Contrast Enhancer): improving the dynamics of the SDR as HDR image | 75" - MVA, 3840x2160, ?-bit,
120/100Hz, flat 65" - MVA, 3840x2160, ?-bit,
120/100Hz, Flat 55" - MVA, 3840x2160, ?-bit,
120/100Hz, Flat Triluminos Display
75" - Motionflow XR 1000
65" - Motionflow XR 800
55" - Motionflow XR 800 | Edge Led Frame Dimming
No Local Dimming | | | | 75" - °
65" - °
Dolby Digital Plus
AVC, MPEG4, HEVC
MP3, ASF(WMA), WAV, MP4AAC, FLAC, | | | 2 x USB 2.0 (DC 5V MAX 500mA)
1 x Ethernet RJ45
1 x AV Composite In
1 x AV Component In
DVB-T/T2 (VHF/UHF)
DVB-C (VHF/UHF)
MPEG2,
MPEG4,
VP9 Profile 2 | | XE85xx |
XE8005 (Flat)
KD-55XE8099 BAEP
KD-55XE8096
KD-55XE8088
KD-55XE8077 SAEP
KD-55XE8005 BAEP
KD-49XE8099 BAEP
KD-49XE8096
KD-49XE8077 SAEP
KD-49XE8005 BAEP
KD-43XE8099 BAEP
KD-43XE8096
KD-43XE8088
KD-43XE8077 SAEP
KD-43XE8005 BAEP successor model - XD8005
no 3D
no HFR | No | No | No | No | ? | HDR in internet video services, HDMI, USB port. | No | Plattform: FY16 HE
SoC: Mediatek MT5
Instruction set:
Operating at up to:
GPU:Open GL
RAM:
Total memory: 16GB
Available memory:
(Google Cast, Voice Control, Google Play Apps & Games, Chrome Cast) PKG6.0402.0001 Super Bit Mapping 4K HDR (14-bit upsampling) | 55" - S-IPS, 3840x2160, ?-bit,
60/50Hz, Flat 49" - S-IPS, 3840x2160, ?-bit,
60/50Hz, Flat 43" - S-IPS, 3840x2160, ?-bit,
60/50Hz, Flat 55" - Motionflow XR 400
49" - Motionflow XR 200
43" - Motionflow XR 200 | Edge Led | | | | | | 55" - °
49" - °
43" - ° | | | 2 x 10 Watt RMS DTS Digital Surround
Dolby Digital Plus
AVC, MPEG4, HEVC
MP3, ASF(WMA), WAV, MP4AAC, FLAC, | | | | DVB-T/T2/C/S2
MPEG2,
MPEG4,
HEVC H.265 (to 3840x2160/60p, 10bit) | | XE80 |
